#319036 - 10/02/2009 18:54 Stuck player (stuck playlist)
estocks
Loc: Reading UK
Hi
I have this problem where my player boots and the front panel is locked out. Also the Ethernet and USB do not work.
I've had this before, the solution is to use the serial port and clear the playlist over RS232.
Thing is, I can't find a FAQ containing the RS232 settings (4800 and 115kbps are mentioned in other posts)
I also can't find the command to clear the playlist in the Serial Port FAQ. Can one of you Large Hadron Colanders [sic] help please?
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#319037 - 10/02/2009 19:04 Re: Stuck player (stuck playlist) [Re: estocks]
Boelle
Loc: Denmark, Odense
115200, 8N1, No Flow Control
but strange that network and usb do not work... but some guru might explain that
do you have the emplode software?
#319038 - 10/02/2009 19:13 Re: Stuck player (stuck playlist) [Re: estocks]
Instructions on how to make the player start with an empty playlist are here:
How do I stop it from trying to play a bad track?
This sub-links to the necessary serial port connection instructions.
#319040 - 10/02/2009 19:17 Re: Stuck player (stuck playlist) [Re: tfabris]
By the way, your symptoms aren't necessarily consistent with the the behavior of a bad track. But those steps are worth a try. If doing that procedure doesn't help, come back and we'll do more diagnostics.
#319077 - 11/02/2009 01:49 Re: Stuck player (stuck playlist) [Re: tfabris]
If a bad track/playlist is causing the player software to crash, then yes, the front panel, usb, and ethernet (emplode) interfaces won't work either.
But if the player had Hijack installed, then the ethernet and Hijack Menu would still be functional. For that matter, the automatic crash-recovery in Hijack might even auto-fix the problem for him.
#319251 - 13/02/2009 11:21 Re: Stuck player (stuck playlist) [Re: mlord]
estocks
Loc: Reading UK
Hi
I can't find the part to edit to a prompt. Here is my log:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #16 Mon Jul 25 18:54:48 BST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 10101510)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005b80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: WDC WD600VE-75HDT1, ATA DISK drive
hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e6
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
Edited by estocks (13/02/2009 11:50)
#319254 - 13/02/2009 11:38 Re: Stuck player (stuck playlist) [Re: estocks]
Serial connection to the empeg requires a 3-wire serial cable (Tx, Rx, GND), with Tx/Rx crossed (simple null modem), and 115200 8N1.
#319256 - 13/02/2009 11:54 Re: Stuck player (stuck playlist) [Re: mlord]
estocks
Loc: Reading UK
If I Cntrl-C I get
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0005c80).
Partition check:
Vcb: 0x4073a000
Player received SIGINT, user interruption
Starting bash.
no shell!
Shell exit
Vcb: 0x4073a000
And the player reboots.
Edited by estocks (13/02/2009 11:55)
#319257 - 13/02/2009 12:01 Re: Stuck player (stuck playlist) [Re: estocks]
Install the car2 developer image, plus hijack.
Then try again. Best source for that is here.
#319259 - 13/02/2009 13:06 Re: Stuck player (stuck playlist) [Re: mlord]
estocks
Loc: Reading UK
Thanks that has got it unstuck.
Is it safe to go back to V3 a11 hijack for my FLACs?
#319260 - 13/02/2009 13:16 Re: Stuck player (stuck playlist) [Re: estocks]
Sure, but keep Hijack on there:
car2_v3a11_hijack.upgrade.
#319262 - 13/02/2009 14:17 Re: Stuck player (stuck playlist) [Re: mlord]
estocks
Loc: Reading UK
Thanks, I have to rush out (POETS day), will definitely be good to have some sounds today. Thanks mlord and tfabris.
