#319036 - 10/02/2009 18:54
Stuck player (stuck playlist)
Loc: Reading UK
Hi
I have this problem where my player boots and the front panel is locked out. Also the Ethernet and USB do not work.
I've had this before, the solution is to use the serial port and clear the playlist over RS232.
Thing is, I can't find a FAQ containing the RS232 settings (4800 and 115kbps are mentioned in other posts)
I also can't find the command to clear the playlist in the Serial Port FAQ. Can one of you Large Hadron Colanders [sic] help please?
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#319037 - 10/02/2009 19:04
Re: Stuck player (stuck playlist)
[Re: estocks]
Loc: Denmark, Odense
115200, 8N1, No Flow Control
but strange that network and usb do not work... but some guru might explain that
do you have the emplode software?
#319038 - 10/02/2009 19:13
[Re: estocks]
Instructions on how to make the player start with an empty playlist are here: How do I stop it from trying to play a bad track?This sub-links to the necessary serial port connection instructions.
#319040 - 10/02/2009 19:17
By the way, your symptoms aren't necessarily consistent with the the behavior of a bad track. But those steps are worth a try. If doing that procedure doesn't help, come back and we'll do more diagnostics.
#319077 - 11/02/2009 01:49
If a bad track/playlist is causing the player software to crash, then yes, the front panel, usb, and ethernet (emplode) interfaces won't work either.
But if the player had Hijack installed, then the ethernet and Hijack Menu would still be functional. For that matter, the automatic crash-recovery in Hijack might even auto-fix the problem for him.
#319251 - 13/02/2009 11:21
Loc: Reading UK
Hi
I can't find the part to edit to a prompt. Here is my log: empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #16 Mon Jul 25 18:54:48 BST 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read 9afffff0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101510) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005b80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e6 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k init player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000
Edited by estocks (13/02/2009 11:50)
#319254 - 13/02/2009 11:38
[Re: estocks]
Serial connection to the empeg requires a 3-wire serial cable (Tx, Rx, GND), with Tx/Rx crossed (simple null modem), and 115200 8N1.
#319256 - 13/02/2009 11:54
Loc: Reading UK
If I Cntrl-C I get
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace... empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #16 Mon Jul 25 18:54:48 BST 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read 9afffff0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101510) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005c80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e6 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k init player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000 Player received SIGINT, user interruption Switching to shell-player loop Starting bash. no shell! Shell exit player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000
And the player reboots.
Edited by estocks (13/02/2009 11:55)
#319257 - 13/02/2009 12:01
[Re: estocks]
Install the car2 developer image, plus hijack. Then try again. Best source for that is here.
#319259 - 13/02/2009 13:06
Loc: Reading UK
Thanks that has got it unstuck.
Is it safe to go back to V3 a11 hijack for my FLACs?
#319260 - 13/02/2009 13:16
[Re: estocks]
Sure, but keep Hijack on there: car2_v3a11_hijack.upgrade.
#319262 - 13/02/2009 14:17
Loc: Reading UK
Thanks, I have to rush out (POETS day), will definitely be good to have some sounds today. Thanks mlord and tfabris.
