#88932 - 17/04/2002 22:54 After Windoze 98 crash, all songs on Empeg GONE :(
CurlyKicker
Loc: Orange County, CA
I was uploading a long MP3 when Win98 crashed. I rebooted and tried starting Emplode again. And everytime I try to start up Emplode I get this error message:
Download failed while checking media. Error 0xc0041016
The player boots up fine but everything has been erased. Even the owner information is erased.
I'm running WIn98, with v2.0b11 with no Hijack. I need some advice ASAP. Anything would be greatly appreciated.
Curly
http://www.ubernet.org/
#88933 - 17/04/2002 23:15 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: CurlyKicker]
dionysus
Loc: San Francisco, CA
Doesn't sound good:( Can you hook it up to the serial prompt and capture the text that it's spitting out?
...Look here for steps on how to connect to the serial prompt if you don't already know how:
http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index&myfaq=yes&id_cat=7&categories=Upgrade%2C+customization%2C+and+third-party+software+questions#82
-mark
#88934 - 17/04/2002 23:25 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: dionysus]
CurlyKicker
OK, that was the first time I've done that. Here's what it said:
Mounting proc
EXT2-fs error (device ide0(3,4)): ext2_check_descriptors: Block bitmap for group
0 not in group (block 1396520500)!
Remounting filesystem read-only
EXT2-fs: group descriptors corrupted !
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplyStart
ing player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
#88935 - 17/04/2002 23:32 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: CurlyKicker]
dionysus
Not good - it's telling you that your drive is corrupted... equivilant of windows telling you to run scandisk..
can you get a shell prompt?
drop to a shell (press "q" when it says to), then try forcing a checkdisk...
umount /dev/hda4
fsck -f /dev/hda4
-m
#88936 - 17/04/2002 23:37 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: dionysus]
CurlyKicker
Ok I'm assuming I did it correctly. Here's the results:
empeg:/empeg/bin# umount /dev/hda4
umount: /dev/hda4: not found
empeg:/empeg/bin# fsck -f /dev/hda4
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
Group descriptors look bad... trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/hda4
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
empeg:/empeg/bin#
#88937 - 17/04/2002 23:39 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: dionysus]
CurlyKicker
I'm assuming that "empeg:/empeg/bin#_" is the prompt and "umount /dev/hda4" and "fsck -f /dev/hda4" are commands?
#88938 - 17/04/2002 23:43 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: CurlyKicker]
dionysus
>sigh< doesn't look good..
You might want to wait until someone from Empeg can verify what I'm recommending (or offer a better solution), but you might need to re-initialize that disk (wiping everything) then reload:(
-mark
#88939 - 17/04/2002 23:44 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: CurlyKicker]
dionysus
#88940 - 17/04/2002 23:45 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: dionysus]
CurlyKicker
OMG!!
#88941 - 18/04/2002 00:04 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: dionysus]
CurlyKicker
#88942 - 18/04/2002 00:22 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: CurlyKicker]
dionysus
I doubt it - if it was a disk drive problem, you wouldn't have gotten as far as you did with the bootup process...
Your drive (I'm assuming that it's a single-drive unit?) is split into seperate partitions; the partition that boot up the empeg is fine, the one holding the music isn't...
...In the case of a disconnected cable, the empeg just doens't boot...
-mark
#88943 - 18/04/2002 00:31 Re: After Windoze 98 crash, all songs on Empeg GONE :( [Re: dionysus]
CurlyKicker
Ok Mark, thanks for all the help.
I guess I'll just hit the sack and hopefully someone from Empeg, or another brilliant mind, will offer some more advice by the time I wake up
-Curly-
#88944 - 18/04/2002 03:11 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
tms13
Loc: Lochcarron and Edinburgh
Did you try its suggestion?
fsck -b 8193 -f /dev/hda4
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#88945 - 18/04/2002 03:15 Re: After Windoze 98 crash, all songs on Empeg GON [Re: tms13]
CurlyKicker
I have now. Here is the result:
empeg:/empeg/bin# fsck -b 8193 -f /dev/hda4
hda4 is mounted.
#88946 - 18/04/2002 04:02 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
Greetings!
OK. Relax. Don't Panic. Yet.
Please post a complete boot log.
Also, you might want to try the following:
1) - get to shell
2) swapon /swapfile
3) umount /drive0
4) umount /drive1 *
5) fsck -fay /
6) fsck -fay /dev/hda4
7) fsck -fay /dev/hdc4 *
8) swapoff
9) - reboot
* - if two drive model.
#88947 - 18/04/2002 04:03 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
tms13
Hmm, it looks like fsck doesn't pass the -b parameter through to e2fsck. Try running e2fsck directly:
e2fsck -b 8193 /dev/hda4
If that doesn't work, ask somebody else for ideas, as I'm out of them...
Toby Speight
#88948 - 18/04/2002 05:21 Re: After Windoze 98 crash, all songs on Empeg GON [Re: tms13]
Does mke2fs always put a backup superblock at 8193? Last I heard, its algorithm was pretty wyrd (all powers of 3 and 5, times some large factor that varies with the size of the drive). There isn't even a "mke2fs --dry-run" that tells you where it's putting them.
#88949 - 18/04/2002 06:14 Re: After Windoze 98 crash, all songs on Empeg GON [Re: peter]
tms13
Dunno - I admit to being on guesswork here.
Here's what the e2fsck manpage on my workstation says:
-b superblock
Instead of using the normal superblock, use an alternative superblock specified by superblock. This option is normally used when the primary superblock has been corrupted. The location of the backup superblock is dependent on the filesystem's blocksize. For filesystems with 1k blocksizes, a backup superblock can be found at block 8193; for filesystems with 2k blocksizes, at block 16384; and for 4k blocksizes, at block 32768.
Additional backup superblocks can be determined by using the mke2fs program using the -n option to print out where the superblocks were created. The -b option to mke2fs, which specifies blocksize of the filesystem must be specified in order for the superblock locations that are printed out to be accurate.
If an alternative superblock is specified and the filesystem is not opened read-only, e2fsck will make sure that the primary superblock is updated appropriately upon completion of the filesystem check.
"man mke2fs" says:
-n causes mke2fs to not actually create a filesystem, but display what it would do if it were to create a filesystem.
Does that not tell you where the superblocks are going? What if you also use -v?
Also,looking at the mke2fs manpage, it mentions rebuilding the superblock if you know the right parameters, using the -S option. Anyone know what incantation to use this on the Empeg?
Toby Speight
#88950 - 18/04/2002 08:00 Re: After Windoze 98 crash, all songs on Empeg GON [Re: tms13]
OK, so all those numbers are worth a try for e2fsck -b number.
This is exactly what's needed, but didn't IIRC exist in the e2fsprogs 1.18 that car players are built with.
#88951 - 18/04/2002 10:55 Re: After Windoze 98 crash, all songs on Empeg GON [Re: pgrzelak]
CurlyKicker
Ok here's the boot log that Paul requested. This is all new to me so bare with me if I get things incorrect.
87016-EMPLODE.log (194 downloads)
#88952 - 18/04/2002 11:04 Re: After Windoze 98 crash, all songs on Empeg GON [Re: pgrzelak]
CurlyKicker
Ok here are the results from what Paul suggested to do:
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16596k swap-space (priority -1)
empeg:/empeg/bin# umount /drive0
umount: /drive0: not mounted
empeg:/empeg/bin# fsck -fay /
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1510/4096 files (0.5% non-contiguous), 9427/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
hda4 is mounted.
empeg:/empeg/bin# swapoff
usage: swapoff [-hV]
swapoff -a [-v]
swapoff [-v] [-p priority] special ...
swapoff [-s]
#88953 - 18/04/2002 11:07 Re: After Windoze 98 crash, all songs on Empeg GON [Re: tms13]
CurlyKicker
Here's the result from what Toby suggested:
empeg:/empeg/bin# e2fsck -b 8193 /dev/hda4
bash: e2fsck: command not found
#88954 - 18/04/2002 11:54 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
tms13
Oops - my bad! On the empeg, it's called fsck.ext2, not e2fsck. Sorry! Just change the name, and try again.
Toby Speight
#88955 - 18/04/2002 11:59 Re: After Windoze 98 crash, all songs on Empeg GON [Re: tms13]
CurlyKicker
here's the result:
empeg:/empeg/bin# fsck.ext2 -b 8193 /dev/hda4
hda4 is mounted.
empeg:/empeg/bin#
#88956 - 18/04/2002 12:00 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
tms13
Well, that's me out of ideas, then. Sorry.
Toby Speight
#88957 - 18/04/2002 12:07 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
Greetings!
I tried opening the log file, but it gave a 404 error. I remember seeing a similar superblock error when I was trying to fsck and was using the wrong device name.
A possibility - try reloading the default software. Use the upgrade empeg and the stock developer version. This will not do anything to the music partitions, but will reset your system software to a factory state. Also, are you still running hijack?
#88958 - 18/04/2002 12:09 Re: After Windoze 98 crash, all songs on Empeg GON [Re: tms13]
CurlyKicker
Maybe this will help someone. Here's the beginning of the what's displayed at HyperTerminal startup:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 9, serial number 10101453)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:a
d
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5chan
ge_root: old root has d_count=1
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComplStarti
ng player
Vcb: 0x4086d000
#88959 - 18/04/2002 12:20 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
Greetings!
Hmm... okay... the boot went through okay... filesystem...
What bothers me is that the fsck -fay looks like it attempted to use an alternative superblock and failed. Although, I just tested this on my empeg. The superblock error you are receiving is the NORMAL error if the command string contains an incorrect device. I remember seeing it before....
Hold...
Edit:
Never mind. The first lines for finding the bad descriptor are new. The superblock paragraph is common. Are you at the factory installation at this point?
Edited by pgrzelak (18/04/2002 12:25)
#88960 - 18/04/2002 12:21 Re: After Windoze 98 crash, all songs on Empeg GON [Re: pgrzelak]
CurlyKicker
I've never run Hijack. So should I uninstall 2.0b11 and reinstall 1.03? If so, is there a procedure to uninstall v2.0b11 from the player or that happens automatically when I install v1.03?
Also attatching log file again.
87060-EMPLODE.nfo (251 downloads)
#88961 - 18/04/2002 12:25 Re: After Windoze 98 crash, all songs on Empeg GON [Re: CurlyKicker]
CurlyKicker
go here for the log file: http://home.socal.rr.com/astroturf/EMPLODE.nfo
I changed the .log to .nfo
