#86951 - 11/04/2002 22:37 Player hangs during emplode startup
jmusick
When I start emplode and choose the player it hangs on the "rebuilding database" item with an error message of
Download failed while rebuilding database. An existing connection was forcibly closed by the remote host (error 0x80072746)
Meanwhile the player has "Building music databases..." showing on the screen, but just hangs there.
I haven't found any troubleshooting advice for this in the faq. Anyone experienced this problem...or is it a bug to be filed (after seeing what's going on by using the console I guess).
#86952 - 11/04/2002 22:41 Re: Player hangs during emplode startup [Re: jmusick]
jmusick
This looks like the same error that was discussed in a thread titled "Emplode 2.0B3 sync error 0x80072746".
I didn't see a fix for getting the player back up and running though
This is the beta11 software btw.
Thanks for any suggestions
#86953 - 11/04/2002 23:10 Here's the error messages [Re: jmusick]
jmusick
Should I delete the tags.cpp file?
And if so could someone point me at the correct place on this bb to find out how to do so?
Just got this player fairly recently.
Thank you!!
-J
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v225 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Sat Mar 2 09:22:29 EST
empeg-car player (hardware revision 9, serial number 40103876)
Command line: mem=16m
Memory: 14968k/16M available (1008k code, 20k reserved, 384k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
ttyS00 at 0xf8010000 (irq = 15) is a
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004480).
empeg RDS driver initialised
empeg power-pic driver initialised (
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP
4
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
hijack: removed menu entry: "Home/Work Location"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
hda: irq timeout: status=0xd0
ide0: reset: success
end_request: I/O error, dev 03:03 (hda), sector 9802
hda: status timeout: status=0xd0
hda: drive not ready for command
end_request: I/O error, dev 03:03 (hda), sector 9804
Loading dancefile: "/empeg/lib/visuals/breakdance.raw"
Loading dancefile: "/empeg/lib/visuals/stonkdance.raw"
Loading dancefile: "/empeg/lib/visuals/princedance.raw"
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
// The above portion took longer than it normall had in the past
// The following portion is when I attempted to start emplode
// and synchronize.
Adding Swap: 16596k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
hdc4 is mounted.
! playerdb.cpp : 182:Failed to build dynamic database (status=0xc004401a).
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
hdb: lost interrupt
// And it just hangs here indefinitely here
#86954 - 12/04/2002 02:28 Re: Here's the error messages [Re: jmusick]
hdb: lost interrupt
You have hardware problems: most likely either a loose IDE cable or loose jumpers on the drives.
#86955 - 12/04/2002 09:52 Re: Here's the error messages [Re: peter]
jmusick
Really?
The player works just fine when I'm not trying to do emplode synch (well, it takes a bit longer to startup...but I figured it all might be a related to the tags.cpp problem).
This sounds very similar to the synch problems that people described elsewhere....but I didn't see a definite "here's how to fix it" in those posts.
-J
#86956 - 13/04/2002 13:15 loose cable? [Re: jmusick]
jmusick
I checked to see if the cable/jumpers were loose. they appear to be fine. Or rather the cable appears to be fine...there's only a jumper on one HD as far as I can see.
Anyone else have ideas?
Thanks,
-J
#86957 - 14/04/2002 03:39 Re: loose cable? [Re: jmusick]
There should only be a jumper on the slave drive, so that's correct.
Maybe you've got the "badly crimped HD cable problem" that so many of us had. Just mail David at carsupport@empeg.com or carsupport@sonicblue.com and explain the problem to him. He'll send you a replacement cable free of charge.
#86958 - 29/04/2002 21:21 Re: loose cable? [Re: BartDG]
burdell1
I had the exact same problem....unfortunately, the only way I found to fix it was to reformat the hard drive.....
