#86223 - 09/04/2002 12:32 Mercedes E install
f_devocht
Loc: Belgium
I finally got round to installing the empeg. Pics are up at http://users.pandora.be/frank.devocht1/english/empeg.htm
#86224 - 09/04/2002 13:43 Re: Mercedes E install [Re: f_devocht]
njdboy
Loc: San Jose, CA
never seen the empeg so low before, I kind of like it.
#86225 - 09/04/2002 14:03 Re: Mercedes E install [Re: f_devocht]
It looks like you may even have some unintended theft protection here. With the gearshift lever in Park, is it possible to remove the empeg? If not, then that is a Good Thing (tm) because you can't move the gearshift lever without the ignition keys.
#86226 - 09/04/2002 14:11 Re: Mercedes E install [Re: tanstaafl.]
njdboy
Loc: San Jose, CA
I didn't even think of that! That is clever (although probably not intended). Is the Good Thing (tm) referencing Martha Stewart? If so, it's a Good Thing (tm) you did that.
#86227 - 09/04/2002 14:41 Re: Mercedes E install [Re: tanstaafl.]
f_devocht
Loc: Belgium
I didn't intend it this way, I just look at it as a bonus
It's the perfect theft protection. In Park it cannot be removed. It only occured to me when I wanted to take it out after removing the keys (keys can only be removed in Park).
I'll make a pic with the gearshift in Park.
Frank
#86228 - 10/04/2002 02:06 Re: Mercedes E install [Re: njdboy]
jane
Loc: Copenhagen SW, Denmark
http://www.riocar.org/modules.php?set_albumName=album33&op=modload&name=gallery&file=index&include=view_album.php
Essential for a convertble. Protects the dsplay from the sun.
Marius (Escort Cab + Mark II)
#86229 - 22/04/2002 12:01 Re: Mercedes E install [Re: jane]
LaneStar
Loc: Portland Or, U.S.A.
That is a great point! I am getting ready to install my empeg into my Cadillac Catera and was going to have the empeg installed higher up to avoid the gear shift getting in the way. Now I have changed my mind so as to have the added protection from theft! Nice!
MKIIa 30gb in a 1998 Cadillac Catera
#86230 - 26/04/2002 15:42 Re: Mercedes E install [Re: f_devocht]
DuFF
Loc: ALhambra, CA
Could ya show more pictures on the aluminum piece of yours or describe it, how did you mount the sled to the car? Is there actually 2 pieces? ... and the aluminum is just the trim part? The reason is, i'm trying to avoid drilling anything at all, the car or sled and any ideas would be great for my install. Thanks.
#86231 - 27/04/2002 03:58 Re: Mercedes E install [Re: DuFF]
f_devocht
Loc: Belgium
I added a few pics and a bit more explanation on my site.
If something is not clear, don't hesitate to ask.
Frank
#86232 - 27/04/2002 11:00 Re: Mercedes E install [Re: f_devocht]
DuFF
Loc: ALhambra, CA
Aah, i get it now. Thanks. =) At first the pictures were at weird angles or maybe it was the lighting. But after you clarified up the 2nd frame as a spacer it makes sense. Nice job =). So how did you mount the empeg securely? With the tabs?
#86233 - 27/04/2002 17:13 Re: Mercedes E install [Re: DuFF]
f_devocht
Loc: Belgium
Yep, the sled is mounted in the frame like you would in a standard radio opening, using the tabs. I only bent 4 tabs IIRC. I prefer not to use all the tabs as it isn't necessary and it makes removal of the sled more difficult.
Frank
#86234 - 16/06/2002 05:42 Re: Mercedes E install [Re: f_devocht]
f_devocht
Loc: Belgium
Just to let you guys know that the URL changed to
http://users.pandora.be/miata/english/empeg.htm
Frank
