#82841 - 21/03/2002 19:55 Hijack feature request: Dim the in-home display?
Can this be done?
Today I was informed by someone who knows a lot about VFDs that you can essentially eliminate the risk of burn-in by turning it down to 70-80 percent brightness.
The default player software only allows dimming of the display when it's in the car. Can Hijack dim the display when it's on AC power?
#82842 - 21/03/2002 20:44 Re: Hijack feature request: Dim the in-home display? [Re: tfabris]
spider
force dc and dim away
#82843 - 21/03/2002 21:22 Re: Hijack feature request: Dim the in-home display? [Re: spider]
Interesting idea, hadn't thought of that.
I'm asking on behalf of my friend Tod, who likes to keep his player in info:track mode but doesn't want burn-in. Maybe in his particular situation, forceDC is the right answer. Thanks.
#82844 - 22/03/2002 09:06 Re: Hijack feature request: Dim the in-home display? [Re: spider]
adavidw
Loc: Utah, USA
That wouldn't work for anyone who had different settings for AC that they wanted to use in the home. Therefore, I for one still think it would be a cool thing for Hijack to do.
-Aaron
#82845 - 22/03/2002 18:49 Re: Hijack feature request: Dim the in-home display? [Re: tfabris]
Sounds like a nice feature request to me. But I think it would make a cool request for the WISH forum for implementation directly into the player software.
Tony, use your powers of persuasion. If not, the next best thing would be for Mark to play around with it.
This functionality will be VERY useful for my alarm-clock setup. Both for burn-in prevention as well as keeping the ambient light in my room down at night.
#82846 - 22/03/2002 22:28 Re: Hijack feature request: Dim the in-home display? [Re: hybrid8]
It might be a nice post-2.0 request for the default player software, but The Guys are trying to concentrate on only doing bugfixes at the moment. I thought that it might have more of a chance of showing up in Hijack before it showed up in the default player software.
#82847 - 23/03/2002 13:02 Re: Hijack feature request: Dim the in-home display? [Re: tfabris]
Yeah, sounds good.
Busy here now. But I accept patches..
#82848 - 24/03/2002 08:20 Re: Hijack feature request: Dim the in-home display? [Re: mlord]
genixia
ok.
#82849 - 24/03/2002 09:06 Re: Hijack feature request: Dim the in-home display? [Re: genixia]
>ok
I was hoping you might say that!
#82850 - 24/03/2002 09:29 Re: Hijack feature request: Dim the in-home display? [Re: tfabris]
genixia
Ok, so is this to be a set & forget value (ie config.ini) or dynamic (ie use some valuable flash)?
My guess is that config.ini is the place for this, and unless I hear convincing arguments to the contrary, that is the way I'm going to code it...
#82851 - 24/03/2002 09:33 Re: Hijack feature request: Dim the in-home display? [Re: genixia]
sounds good.
See the comments inside hijack.c, just below the declaration of buttonled_menu_label
Display levels range from 000 to 239.
EDIT: note that Hugo suggests never using the brightest values (0 to 15), as they "overdrive" the display. This leaves us with a useable range from 16 .. 239, or 224 useable values.
Edited by mlord (24/03/2002 09:36)
#82852 - 24/03/2002 09:33 Re: Hijack feature request: Dim the in-home display? [Re: genixia]
If you're going to do it in config (which is fine by me) are you planning on adding support for two states? Or just a single every-case setting?
I vote for two states if you hadn't already thought about that. Then of course comes the request for an easy way to toggle them via Hijack (maybe another fake button name would be nice - of course so would allowing it to work with the illumination line on the sled even when running AC mode)
#82853 - 24/03/2002 09:38 Re: Hijack feature request: Dim the in-home display? [Re: hybrid8]
If we want separate dim/bright states, then there's no need for fake buttons or anything.. just the two settings in config.ini. Hijack can internally sense the dimmer wire (headlight sense) input.
#82854 - 24/03/2002 09:45 Re: Hijack feature request: Dim the in-home display? [Re: mlord]
Sweet. That works for me. I was just thinking about other people that might not be using (or might not want to use) the illumination line (which would require the sled). This is going to make my docking station even more like an actual alarm clock. Woohoo.
#82855 - 24/03/2002 09:46 Re: Hijack feature request: Dim the in-home display? [Re: tfabris]
Can you ask your friend if the setting is actually closer to 70 or 80? I think we'd hate to think at a later time... "Hmmm.. Guess it should have been closer to 70.... Ooops"
#82856 - 24/03/2002 10:00 Re: Hijack feature request: Dim the in-home display? [Re: mlord]
Mmm.. actually, I suppose somebody should test to see if the player software actually already dims the display in AC/Home mode when the headlight sense (dimmer) wire is activated..
If so, then we probably just need the one setting: max brightness, or maybe a brightness offset or something.
#82857 - 24/03/2002 10:23 Re: Hijack feature request: Dim the in-home display? [Re: mlord]
genixia
Yep, I'm just compiling with some additional debug printks to look at this.
If I can hijack at the display ioctl and just override the level it would be simple.
#82858 - 24/03/2002 10:48 Re: Hijack feature request: Dim the in-home display? [Re: mlord]
Heh. That would be a good idea. No sense in re-inventing the wheel.
#82859 - 24/03/2002 10:49 Re: Hijack feature request: Dim the in-home display? [Re: hybrid8]
I'll send him here to add his input now, thanks.
#82860 - 24/03/2002 11:20 Re: Hijack feature request: Dim the in-home display? [Re: genixia]
Or just force the headlight-sense line active, in empeg_power.c
#82861 - 24/03/2002 13:22 Re: Hijack feature request: Dim the in-home display? [Re: mlord]
I tested the illumination sense while the player is in AC mode and it has no effect on the display unfortunately. Hopefully this can be included as part of the hack...
Testing method: Player powered through dock connections. Dummy plug inserted into AC jack to force AC mode. Illumination sense connected to +12 source and no effect (works as expected when I remove the dummy plug).
#82862 - 24/03/2002 13:34 Re: Hijack feature request: Dim the in-home display? [Re: hybrid8]
genixia
I didn't think it would use the DC mode dimmer settings in AC mode. Oh well.
#82863 - 24/03/2002 14:17 Re: Hijack feature request: Dim the in-home display? [Re: hybrid8]
Can you ground it and try again? (instead of +12V)
I think it's active low, not sure though.
#82864 - 24/03/2002 22:35 Re: Hijack feature request: Dim the in-home display? [Re: mlord]
It's definitely active high. I tested in DC mode and it works fine. The simplest test of all is just to stick the dummy plug in and put the empeg in the car as normal (there's a cut-out in the sled which prevents the dummy plug from interfering with docking). And it doesn't work.
#82865 - 25/03/2002 13:31 Re: Hijack feature request: Dim the in-home display? [Re: tfabris]
CommOri
I would tend to go with a setting near 70%. 80% may be a bit hot.
