#78546 - 08/03/2002 04:45 anything new about creating boot animations?
Draghtnod
hi there!
i searched the FAQ and the board for infos to change the boot animation(at 2.0)... they are all a bit old.. huh?
is there something new known how to -create- an own animation and load it up to the flash?
Tino
#78547 - 08/03/2002 10:53 Re: anything new about creating boot animations? [Re: Draghtnod]
No one has (so far) created an editor for the factory boot up animations. Only the custom logo (which appears AFTER the factory boot up animations) has been editable so far. I've been meaning to update my logo editor to do this, but have not gotten around to it.
I will say this, though:
Anyone who wishes to create such an editor, I have reason to believe that the necessary information is in the publicly-available kernel source code. For instance, the flash memory locations of the stored frames are in the kernel source code if I recall correctly.
So. Who's up for it?
#78548 - 08/03/2002 11:47 Re: anything new about creating boot animations? [Re: tfabris]
If people get serious about this, I could make it simpler to locate the flash memory spot for it (as things move around..).
#78549 - 08/03/2002 12:00 Re: anything new about creating boot animations? [Re: mlord]
I thought the flash memory location was fixed for the animated logos.
#78550 - 08/03/2002 12:05 Re: anything new about creating boot animations? [Re: tfabris]
Nope. It's just a data structure inside the kernel. With a Hijack kernel, we can do whatever we please, so long as we leave a signature of some kind for uploader's to query.
#78551 - 08/03/2002 12:30 Re: anything new about creating boot animations? [Re: mlord]
Draghtnod
hum.. i would like to program an editor for this animations! but i can only simple C/C++ and good delphi (and some other stuff)..
so if i got an editor working with delphi, you couldnt implement it in your editor, right? -> not good!
hum.. i gonna try to change the animation in the kernel manually! is there already some point where i should start to search?
maybe we could export the animation out of the kernel and implement some functions wich can read various animations out of another part of the flash..? who knows?
#78552 - 08/03/2002 13:08 Re: anything new about creating boot animations? [Re: tfabris]
justinlarsen
Loc: Petaluma, CA
tony comeon.. build version 2 of your logo edititor with everything you want.. you know you want to
---- Justin Larsen
#78553 - 08/03/2002 15:56 Re: anything new about creating boot animations? [Re: tfabris]
Draghtnod
#ifdef NO_ANIMATION
/* The Rio logo for the splash screen */
#include "rio_logo.h"
/* The empeg logo for the splash screen: includes tux */
#include "empeg_logo.h"
#else
/* Animations for both empeg and rio players. */
#include "empeg_ani.h"
#include "rio_ani.h"
the rio_ani.h/empeg_ani.h includes an animation.. i just dont know what animation this is.. i hope its the boot animation.. right?
#78554 - 08/03/2002 16:12 Re: anything new about creating boot animations? [Re: Draghtnod]
Don't see why there's an ifdef, they're both in there...
#78555 - 08/03/2002 16:19 Re: anything new about creating boot animations? [Re: tfabris]
Draghtnod
yeah! there both in there.. the ifdef is only an unused feature! if the NO_ANIMATION is set, an picture is displayed instead of an animation at boot!
well.. i got the code of the animations and i got the code wich decompresses the other code... or something i think i just can do it!
gimme some time *calculating*
#78556 - 08/03/2002 17:22 Re: anything new about creating boot animations? [Re: Draghtnod]
Draghtnod
after 3 hours headbreaking calculations and tries,.... I GOT IT!!!
im reconstruating the first frame of the empeg animation now.. then ill see if im right
#78557 - 08/03/2002 20:54 Re: anything new about creating boot animations? [Re: tfabris]
mschrag
Loc: Richmond, VA
I'm game ... Is the animation basically a concanated series of stills in the usual format (2048b)?
#78558 - 08/03/2002 21:02 Re: anything new about creating boot animations? [Re: mschrag]
Close. Yes, just a bunch of catenated images, but if I recall correctly, they're packed 4 pixels per byte, 1024bytes per frame.
#78559 - 08/03/2002 21:07 Re: anything new about creating boot animations? [Re: mlord]
And oh yeah, at the beginning is a table of frame offsets (int's) from the beginning of the animation (offsets from start of the offset table). Final offset in table is zero, as an end marker.
#78560 - 09/03/2002 05:02 Re: anything new about creating boot animations? [Re: mlord]
Draghtnod
youre right.. why didnt you say that earlyer? *g*
whatever.. im onby progging a player for this animations..
#78561 - 09/03/2002 07:24 Re: anything new about creating boot animations? [Re: Draghtnod]
Draghtnod
look at this:
http://server2040.virtualave.net/draghtnod/empeg.jpg
the offsetthing at the begining is a liddl confusing.. but it shouldnt be a problem..
is anyone else working on this???
#78562 - 09/03/2002 09:54 Re: anything new about creating boot animations? [Re: Draghtnod]
Just in case it didn't occur to you, it looks like you've got an order wrong somewhere. I think you need to flip the first and second halves of the bytes to get it in the right order, IIRC.
#78563 - 09/03/2002 10:00 Re: anything new about creating boot animations? [Re: wfaulk]
smu
Loc: Germany (Ruhrgebiet)
Hi.
It look more like a byteorder (big endian versus little endian) problem to me. But the effect is pretty much the same. Look at this:
Packed 4 pixels/Byte:
AABB CCDD
Decode on empeg:
00AA 00BB 00CC 00DD
Decode on PC (without reversing byteorder)
00CC 00DD 00AA 00BB
If you reverse the byte order on the PC, or swap the nibbles (hi/low 4 bit) in the packed byte, you will get the correct result.
cu,
sven
#78564 - 09/03/2002 10:05 Re: anything new about creating boot animations? [Re: smu]
You're probably right. It's been months since I wrote my code to extract that data and I'm too lazy to bother looking at it.
#78565 - 09/03/2002 10:20 Re: anything new about creating boot animations? [Re: wfaulk]
Draghtnod
hum.. the real problem is: what do i have to do with the begining of the code? there are a lot of equals and so on.. but i dont really see the connection to the single frame!
for example i know that 0x54 means the last frame.. but why?
#78566 - 09/03/2002 12:03 Re: anything new about creating boot animations? [Re: Draghtnod]
Ummm ... what?
Your initial problem is that the pixels are being drawn in the wrong order. That's why your jpeg looks like it's being viewed through a lenticular screen. You need to either swap pairs of bytes or swap nybbles within bytes (probably the former) in order to get it to print out properly.
Beyond that, I don't understand what you're asking.
#78567 - 09/03/2002 12:28 Re: anything new about creating boot animations? [Re: wfaulk]
Draghtnod
ups sorry for my bad english
the problem with the wrong order is corrected.. it paints a perfect picture now!
my last problem:
the first enterys in the animationcode are the pointers to the several frames (they are needed to prevent doubled frames)! i dont know how i have to use them! hum.. i have an idea! well.. i think this night will be full of calculations too *dreaming of flying pixels and offsets*
Edited by Draghtnod (09/03/2002 12:29)
#78568 - 09/03/2002 12:34 Re: anything new about creating boot animations? [Re: Draghtnod]
Look in the game_finale() routine of Hijack (hijack.c), and/or at the empeg_display.c driver, both of which decode and "play" the animations.
#78569 - 09/03/2002 19:44 Re: anything new about creating boot animations? [Re: Draghtnod]
peterk
Loc: California (Ex NZ)
My comment is a little more "low tech " then byte ordering.
On the boot animation for my Rio IIa (personality changed to empeg), tux is on the RIGHT of the empeg logo. How come yours is on the left?
PeterK
#78570 - 10/03/2002 03:10 Re: anything new about creating boot animations? [Re: peterk]
Draghtnod
i know.. was a little fault by my side!
great news:
i do now know what the code at the begining means! (and now tux is on the right side) i need only a liidle time to complete the player! creating animations is no problem! i also think you can crate the animation as long as you want until the flash is full! and if the next hijack deletes all 2 animations, you can crate a very cool long one
the player is complete this evening if nothing terrible happens..
#78571 - 10/03/2002 03:32 Re: anything new about creating boot animations? [Re: Draghtnod]
Draghtnod
#78572 - 10/03/2002 07:49 Re: anything new about creating boot animations? [Re: Draghtnod]
justinlarsen
Loc: Petaluma, CA
looks good.. now if i could just figure it out.. anyone planning on writing a program to do the animations and it will also flash it to the player?
---- Justin Larsen
#78573 - 10/03/2002 08:59 Re: anything new about creating boot animations? [Re: justinlarsen]
Draghtnod
u need to modify the kernel before you can flash it up! i cant and i wont do that.. i can do the program wich writes the animation!
i dont know how that flashing thing works..
#78574 - 10/03/2002 13:51 Re: anything new about creating boot animations? [Re: Draghtnod]
justinlarsen
Loc: Petaluma, CA
maybe you can work with tony and/or mark they know all about flashing, try writing to the program to just do that animations and/or ask them to see if they would help to to do the flashing part there both pretty good about helping maybe it will modivate tony, tony also mentioned he had something that would make it real easy but he didt have the time to implant it ect.
---- Justin Larsen
#78575 - 11/03/2002 07:14 Re: anything new about creating boot animations? [Re: justinlarsen]
Draghtnod
okay..
Tony? Mark? what do i have to do to flash an animation up to the flash? i will do the program to read, modify and write the animation... isnt it possible to simple export the animation to a seperat memory area?
my empeg_ani.h/rio_ani.h player will be up in some hours..
