Page 2 of 2 < 1 2
#74478 - 14/03/2002 17:38 Re: No Hard Disc Found Contact Support [Re: dclesse]
Nic
Loc: Marlow, UK
I have a very similar problem to 94cobra and skamp's on a 30GB Rio - same boot error, occurs mostly during car use, maybe for half an hour it might not boot and then *woo* it works again. It DOES occur during AC use, but far less frequently. It has also been getting worse and worse. It feels like a dying HDD...but I'm so trying not to accept this
I've replaced the IDE cable with a new one from support and I've double checked it's tightly fitted.
After a great deal of "why won't it break when I WANT it to?!" frustration I have gotten a serial log from the little beast.
Here it is: It doesn't *feel* like it gives much away, but here goes:
If there is anyone present who wants to upgrade the flash, let them speak
now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the
kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v225 (root@tbird.localnet)
(gcc version 2.95.3 20010315 (release)) #2 Sat Mar 2 09:22:29 EST 2002
empeg-car player (hardware revision 9, serial number 30103054)
Command line: mem=16m
Memory: 14968k/16M available (1008k code, 20k reserved, 384k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11
1999 )
Starting kswapd v 1.5
Signature is 20706d65 'emp '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC
00:02:d7:26:0b:ee
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
There. Any comments? Email support and cry for mercy?
#74479 - 14/03/2002 20:06 Re: No Hard Disc Found Contact Support [Re: Nic]
Drives not found.
Triple check the connections.. make sure everything is aligned.
Can you hear the drives spin up?
Email support.
Page 2 of 2 < 1 2
