#70987 - 13/02/2002 14:07 Hijack v199, problem....
Memil
Loc: Sweden
Hi!
The "Remember Car/DC Visual" (or something like that ), isnt that for the empeg to remember/restoring the visuals in the car?
Well if it is so, it wont work for me?
Anyone have any suggestion?
(mlord, keep up the good work! You should see my "geek pals" faces when I demo the webinterface )
/Fredrik
Mk2a - 10gb(soon 50gb), 2.00b11 - Hijack v199
#70988 - 13/02/2002 14:10 Re: Hijack v199, problem.... [Re: Memil]
There will be a problem with Hijack's "Restore DC/Car Visuals" feature in Beta11, when moving the player between home and car. It won't work all the time. This is due to a bug in the Beta11 player, and is not Hijack's fault.
#70989 - 13/02/2002 14:27 Re: Hijack v199, problem.... [Re: tfabris]
Memil
Loc: Sweden
Ok!
Dont know if it makes any difference but I had the same problem with beta7?
I dont need to move it between home and car either, just need to turn off the car...
/Fredrik
#70990 - 13/02/2002 14:32 Re: Hijack v199, problem.... [Re: Memil]
If you had the problem in beta7, here is the resolution:
Select your desired text screen mode FROM THE MAIN MENU, not by cycling.
Select your desired visual screen mode FROM THE MAIN MENU, not by cycling.
After that, it should work OK.
#70991 - 13/02/2002 14:38 Re: Hijack v199, problem.... [Re: tfabris]
Memil
Loc: Sweden
Thanks!
Will try that tomorrow on my way to work!
/Fredrik
#70992 - 13/02/2002 15:26 Re: Hijack v199, problem.... [Re: tfabris]
Fastrack
Loc: Toronto, Ontario Canada
Well I was waiting for this to get asked again I saw this a post on this subject about a week ago. But it disappeared after not reading for a couple of days!
Anyway.. I went back to using version 175 of HiJack and the Restore Visuals/INfo Mode WORKS perfectly in 2.0 beta 11!!!!.
So Mark must have changed something
Ben Rio Car 10GB + 60GB Toshiba ([green]Green[/green]) - Serial # 30102833
#70993 - 15/02/2002 02:55 Re: Hijack v199, problem.... [Re: Fastrack]
Memil
Loc: Sweden
Probably, because it didnt work on when I choosed in the menues either...
I'll just have to wait until mlord lookes at the sources again...
/Fredrik - Mk2a 10gb, Blue
#70994 - 15/02/2002 09:20 Re: Hijack v199, problem.... [Re: Fastrack]
ClownBurner
Loc: Irvine, CA USA
Oddly enough, mine works fine in the car in b11, but always defaults to info:transient when at home. I guess I need a "Restore AC Visuals" option...
_____________ James Mancini
#70995 - 15/02/2002 11:58 Re: Hijack v199, problem.... [Re: ClownBurner]
Use initial= in IR Translate to do whatever you want at startup. This includes popping into your desired display mode.
#70996 - 19/02/2002 12:16 Re: Hijack v199, problem.... [Re: hybrid8]
ClownBurner
Loc: Irvine, CA USA
Great idea.. but I can't get it to work... I've tried this:
[ir_translate]
;@AC initial=null.L,null.L,null.L,null.L,null.L,null.L,null.L,Info
and this:
[ir_translate]
initial.H=null.L,null.L,null.L,null.L,null.L,null.L,null.L,Info
..But neither seems to have an effect. Any ideas?
#70997 - 21/02/2002 11:06 Re: Hijack v199, problem.... [Re: ClownBurner]
Nuke all the "nulls" (not needed in latest versions), and stick one null at the END. Maybe, maybe not..
#70998 - 21/02/2002 11:07 Re: Hijack v199, problem.... [Re: mlord]
Actually, maybe keep one null at the beginning.. the player seems to toss the first button press after it restarts..
#70999 - 21/02/2002 22:58 Re: Hijack v199, problem.... [Re: mlord]
ClownBurner
Loc: Irvine, CA USA
That, combined with a v202 upgrade, seems to have nailed it.. Thanks!
