Page 2 of 2 < 1 2
#70813 - 16/02/2002 13:39 Re: Cutting lame encoding time in half with --vbr- [Re: SE_Sport_Driver]
ajayrockrock
Loc: Riverside, CA
the "recommended settings" in EAC uses the --alt-preset standard setting instead of --r3mix.
later,
ajay
#70814 - 16/02/2002 16:05 Re: Cutting lame encoding time in half with --vbr- [Re: ajayrockrock]
Cas_O
Loc: 's-Hertogenbosch; the Netherla...
I thought that the r3mix settings had become obsolete last month, replaced by --alt-preset, supported since Lame 3.91
#70815 - 16/02/2002 20:15 Re: Cutting lame encoding time in half with --vbr- [Re: SE_Sport_Driver]
traintrax
I thought it was --alt-preset standard %s %d..
#70816 - 16/02/2002 23:44 Re: Cutting lame encoding time in half with --vbr- [Re: Cas_O]
ajayrockrock
Loc: Riverside, CA
in lame 3.91, the "alt-preset" stuff got a lot of improvements and is now considered to be the best in terms of quality and size.
while --r3mix is just a shortcut for several different switches, --alt-preset actually changes the way the internals work.
Read the Changelog for LAME and you'll find a lot of useful info about --alt-preset
later,
ajay
later,
ajay
#70817 - 17/02/2002 00:34 Re: Cutting lame encoding time in half with --vbr- [Re: traintrax]
frekin
I ran through the EAC configuration wizard, to see how it's choices would compare with my manual setting of Lame parsing with command line options --alt-preset standard -b32. When I looked at the compression settings after picking the r3mix recommended settings in the wizard, I saw that it uses these "Additional command line options:"
%l--alt-preset 128%l%h--alt-preset standard%h %s %d
and it has selected "User Defined Encoder", with the path to my lame.exe.
Can someone point me to an FAQ that explains what the %l...%l, %h...%h, %s, and %d do?
#70818 - 17/02/2002 09:14 Re: Cutting lame encoding time in half with --vbr- [Re: ajayrockrock]
Dylan
Loc: Virginia, USA
Thanks, I wasn't aware of --alt-preset. I'll give it a shot.
-Dylan
Page 2 of 2 < 1 2
