#70517 - 12/02/2002 19:17 B11 - Sony Stalk menu forward/back not working
BradS
Using the Sony Stalk with B07 when you hit the menu button and then the toggle forward and back levers it scrolls through the menus, playlists, ect.. But in B11, nothing. On the other hand in 07 holding the paddels did not seek through the track, but it does in b11... Hmmm...
#70518 - 12/02/2002 19:24 Re: B11 - Sony Stalk menu forward/back not working [Re: BradS]
Before I put this one on the internal bug list...
Are you running hijack? If so, is the problem still there without hijack? The only reason I'm suspicious is that Mark's been fiddling with the stalk codes in the latest hijacks.
#70519 - 12/02/2002 19:28 Re: B11 - Sony Stalk menu forward/back not working [Re: tfabris]
BradS
That was my first guess so I reaplied the B11 and the same thing. Just to make sure it was not my tuner I then went back to B07, and it worked.
#70520 - 12/02/2002 19:51 Re: B11 - Sony Stalk menu forward/back not working [Re: BradS]
#1779 now. Thanks.
