Was running Developer 2beta7 + v162hijack
While doing a fairly small empload to my unit, it died with a synchronization error
Since then it hasn't booted - I've tried reinstalling Developer 2beta7, beta3 & consumer v1.03
All these say that they have installed correctly, but no joy
I even tried car2-builder-20011022.upgrade, but this made no change, although it said it finished successfully.
When I logged in though, all of the music files where still there
When it boots, I get
Starting player
player(7): memory violation at pc=0x0212d43c, lr=0x0212d3ec (bad address=0x0b1a1f99, code 2)
Does anyone have a clue what is happening? (full boot messages attached)
cheers,
Craig
Hmmm, for some reason the attachment doesn't seem to have loaded completely - anyway the relevant bits are:
......blah blah
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
pc : [<0212d43c>] lr : [<0212d3ec>]
sp : bffffd58 ip : bffffd78 fp : bffffd74
r10: 0219e4cc r9 : 02186684 r8 : bffffe60
r7 : 0b1a1f95 r6 : 0219d940 r5 : 021a1f91 r4 : 09000004
r3 : 00000000 r2 : 09000004 r1 : 021a1f91 r0 : 0219d940
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F7517D Table: C0F7517D DAC: 00000015
Function entered at [<0212d41c>] from [<0212d3ec>]
r7 = 00000008 r6 = 021A19A8 r5 = 021A1F91 r4 = 0219D940
Function entered at [<0212d344>] from [<02114544>]
r5 = 021A1998 r4 = 00000001
Function entered at [<021144c0>] from [<020e8bf0>]
r10 = 021A1F99 r9 = 02186684 r8 = BFFFFE60 r7 = 00000008
r6 = 021A19A8 r5 = 021A1998 r4 = 00000001
Function entered at [<020e7a04>] from [<020bd308>]
r10 = 02053B88 r9 = 00000000 r8 = 02162008 r7 = 0219E6A8
r6 = 00000008 r5 = 0000001B r4 = 0219E6BC
Function entered at [<020bd1b4>] from [<020c2380>]
r10 = 02053B88 r9 = 00000000 r8 = 02162008 r7 = 00000000
r6 = 020000C0 r5 = BFFFFF64 r4 = 0219E48C
Function entered at [<020c2368>] from [<0215ef54>]
Function entered at [<0215ef30>] from [<020000d4>]
r4 = 00000001
Function entered at [<020000c0>] from [<02118c78>]
Function entered at [<02118bb4>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
player(8): memory violation at pc=0x0212d43c, lr=0x0212d3ec (bad address=0x0b1a1f99, code 2)
.......ad nauseam
66531-ciaempeg.TXT (172 downloads)
Edited by craigalsop (07/02/2002 16:33)
