#68221 - 07/02/2002 11:33 hijack 186 - initial functions
Dava
Loc: Bucks UK
HI Mark,
With 186 the initial.C and inital.H codes have stopped working.
I thought maybe that because we now have @DC and @AC you had changed it so I put:
[ir_translate]
;@DC initial=ffffff.L,ffffff.L,20DF0B
;@AC initial=000000.L,ffffff
80b44918=000000.L
And then I get an IR Translate Error popup at start.
Which is the correct method, @DC/@AC or initial.H/initial.C ?
Ta.
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#68222 - 07/02/2002 11:37 Re: hijack 186 - initial functions [Re: Dava]
Initial.C and Initial.H are the correct way.
But this whole "Initial" thing is very timing-sensitive, in that we are never really sure when the player is up and running, and if we sent the initial sequences too early, they get ignored.
Best suggestion I have is to place a bunch of null.L codes at the front of the initial sequences, to delay them a bit:
initial.C=null.L,null.L,null,L,button1,button2, ...
#68223 - 07/02/2002 12:29 Re: hijack 186 - initial functions [Re: mlord]
Dava
Loc: Bucks UK
Hmm.. Tried:
[ir_translate]
initial.C=null.L,null.L,null.L,null.L,null.L,null.L,20DF0B
initial.H=null.L,null.L,null.L,null.L,null.L,null.L,null.L,null.L,null.L,null.L,null.L,null.L,000000.L,ffffff
80b44918=000000.L
and still no joy....
#68224 - 07/02/2002 12:47 Re: hijack 186 - initial functions [Re: Dava]
Okay, I'll fix it.
#68225 - 07/02/2002 12:57 hijack 189: Initial functions revamped [Re: Dava]
Okay, Hijack v189 is out. This version features
  • all new implementation of "initial=" for startup button macros
  • requires "[output] notify=1" in config.ini for "initial=" to be triggered
  • all ir_translate flags now work with initial=, permitting multiple instances in config.ini with different flag combinations, as in:
    initial.CTA=xxxxxxx,xxxxxx
    initial.HT=xxxxxxx,yyyyyyy
    initial.CP=zzzzzz,zzzzzzz
  • ir_translate button flags are now case-insensitive
    Have fun.
  • Top
    #68226 - 07/02/2002 13:03 Re: hijack 189: Initial functions revamped [Re: mlord]
    Dava
    Loc: Bucks UK
    I like rubbing your lamp!
    You're the quickest genie on the planet!
    Cheers. Will try it now..
    #68227 - 08/02/2002 02:19 Re: hijack 189: Initial functions revamped [Re: mlord]
    Dava
    Loc: Bucks UK
    Works a treat.
    Cheers mister!
