#67369 - 05/02/2002 17:14 R3Mix Preset in Audiograbber
jarredduq
Loc: California, USA
For people who user audiograbber to rip their CD's to MP3 I just found out about an undocumented feature. You can use the r3mix preset with the lame encoder. Here's how to do it:
Edit this line in audiograbber.ini:
MP3QualityMode=xxxxxx
Set it to
MP3QualityMode=R3MIX
#67370 - 05/02/2002 17:18 Re: R3Mix Preset in Audiograbber [Re: jarredduq]
Laura
Loc: Greenhills, Ohio
What is the r3mix preset used for and how do I get into the audiograbber.ini file to change it?
Laura
MKI #017/90
whatever
#67371 - 05/02/2002 17:22 Re: R3Mix Preset in Audiograbber [Re: Laura]
jarredduq
It would take me to long to explain it, just goto http://www.r3mix.net to learn about the r3mix preset.
To edit the file simply go into windows explorer and goto the audiograbber directory(probably in your C Drive) and you should see the file. Right click on the file and left click edit, change the setting as described above and click file, save. You should be good to go.
#67372 - 05/02/2002 18:24 Re: R3Mix Preset in Audiograbber [Re: jarredduq]
Quick question, with Lame 3.91, what should I be using? --r3mix or --alt-preset standard? I keep seeing mixed info on this...
#67373 - 05/02/2002 18:35 Re: R3Mix Preset in Audiograbber [Re: drakino]
svferris
Loc: San Diego, CA, USA
My understanding (based on usenet posts) is that the --alt-preset standard replaced the --r3mix setting, rendering the latter obsolete.
#67374 - 05/02/2002 19:00 Re: R3Mix Preset in Audiograbber [Re: drakino]
Find the full equivalents of each preset to find out exactly what they're doing. r3mix.net shows the complete command line params and I'm sure the other stuff is available on dibrom's site (can't remember where or what the url is).
The tip above for the r3mix setting and AudioGrabber is for when you're using the DLL with AG's built-in controls. If you use a command-line encoder from AG's command line prefs page, then you can specify whatever options you want (obviously).
Ok, 24 is on. Time to go.
#67375 - 05/02/2002 22:28 Re: R3Mix Preset in Audiograbber [Re: hybrid8]
svferris
That's why you get a TiVo...
#67376 - 06/02/2002 09:31 Re: R3Mix Preset in Audiograbber [Re: jarredduq]
SE_Sport_Driver
One thing I noticed is that he recommends JointStereo for LAMe.... is this still true? I thought everyone here said NO joint stereo?
#67377 - 06/02/2002 09:54 Re: R3Mix Preset in Audiograbber [Re: svferris]
f_devocht
Loc: Belgium
Can you use the --alt-preset setting with audiograbber?
Frank
#67378 - 06/02/2002 10:56 Re: R3Mix Preset in Audiograbber [Re: f_devocht]
svferris
I'm not sure on that. I use EAC, which allows you to specify your own command line options.
#67379 - 06/02/2002 20:03 Re: R3Mix Preset in Audiograbber [Re: f_devocht]
Laura
I tried putting that setting in the ini file and saved it and opened it again to find it had changed to normal. I'm not sure what it was supposed to do.
Laura
MKI #017/90
whatever
#67380 - 06/02/2002 20:11 Re: R3Mix Preset in Audiograbber [Re: Laura]
It's a way to override the simpler settings normally allowed for the dll LAME implementation.
Don't use r3mix without going to www.r3mix.net to read about it. It's an easy read. Just make sure you understand why he chose to configure the preset the way he did.
You can also download LAME.exe and use that with Audiograbber as an EXTERNAL encoder. That way you can easily specify any command line options right in AG. Very easy to do.
#67381 - 06/02/2002 22:38 Re: R3Mix Preset in Audiograbber [Re: hybrid8]
Laura
I do use Lame in AudioGrabber, the newest 3.91 version of it.
Laura
MKI #017/90
whatever
#67382 - 06/02/2002 22:52 Re: R3Mix Preset in Audiograbber [Re: Laura]
Terminator
Loc: Dallas, TX
If you are already running it as an external encoder, changing the how audiograbber uses the dll won't change anything. The dll integrates into audiograbber, while the lame exe file is a seperate standalone program that could be run by itself if you wanted to. All you have to do to get the command line version to use r3mix settings is to add --r3mix to the arguments under mp3settings.
Sean
#67383 - 07/02/2002 05:44 Re: R3Mix Preset in Audiograbber [Re: Terminator]
Laura
I believe I understand. I have been running it as an internal encoder. I checked external and saw where you put in the command lines. I"ll have to go back to the R3mix site and read up on what should be in the command line. Thanks.
I just wish my job work load would ease up a bit so I could find more time to play around with all this stuff.
Laura
MKI #017/90
whatever
#67384 - 07/02/2002 08:38 Re: R3Mix Preset in Audiograbber [Re: SE_Sport_Driver]
nester
Loc: Louisville, KY, USA
Joint Stereo with Lame is OK, and the recommended setting. The major problems with Joint Stereo were when using Xing as the encoder. The stereo seperation was all foobar'ed and it made for interesting listening with headphones.
Lame, Fraunhofe, and Blade don't seem to do this.. Long live lame.
(i liked being called stranger better than newbie.)
Edited by nester (07/02/2002 08:39)
#67385 - 07/02/2002 08:49 Re: R3Mix Preset in Audiograbber [Re: nester]
SE_Sport_Driver
I guess I'm not as computer savy as I thought...
I WAS using MediaJukebox with LAME but convinced myself to get Audiograbber (with a little persuation from a fellow BBS member) with the seperate LAME encoder. But I can't seem to find a place to start... The site referenced in this thread seems to be out of date because of LAME releasing 3.91?
I was running MediaJukebox at "High" quality, VBR LAME, Joint Stereo. File sizes were slightly smaller than 192kps CBR with MusicMatch. I would like file sizes the same as I had with MediaJukebox and am clueless with the command line stuff... oh well.
I havn't had much luck at the AudioGrabber site for LAME specific info and the LAME site is pretty general too... Oh well, I guess I'll use MediaJukebox for the meantime.
#67386 - 07/02/2002 09:30 Re: R3Mix Preset in Audiograbber [Re: SE_Sport_Driver]
Just download Audiograbber (from audiograbber) and the lame DLL file (linked from all lame and most mp3 sites) - and install audiograbber. Pop the Lame DLL in the audiograbber directory and it will appear automagically as an option. When Lame is selected as the encoder of choice, the GUI presents you with parameters relevant to LAME.
Yup - it really is that easy.
You can either go with the options from the menu or use the slider bar for lower to higher quality.
#67387 - 07/02/2002 14:51 Re: R3Mix Preset in Audiograbber [Re: nester]
I've got plenty of joint stereo tracks made in Xing, and they sound fine on headphones. Perhaps the foobar'ed problem you describe was due to this problem?
#67388 - 07/02/2002 19:03 Re: R3Mix Preset in Audiograbber [Re: SE_Sport_Driver]
I'll hook you up with some good settings to start with. You can tweak beyond that after you make some preview tracks.
Check your PM in a bit.
#67389 - 08/02/2002 08:41 Re: R3Mix Preset in Audiograbber [Re: hybrid8]
SE_Sport_Driver
Bruno, I got the PM thanks!
But get this:!!!!
I was testing the "--alt-preset standard" setting... The program ripped along at a decent rate... dumping all the WAV's to the folder. The I saw the program (AudioGrabber) create the folder for the mp3's. When it was done, a little window popped up, one after another, for each track. Each window was up for only 1/2 second. Each time, it did, the WAV disappreared. I was shocked it was working this fast and knew it wasn't encoding this fast. When it was done, I looked in the folder it created for the album and it was empty.... this thing ripped to WAV, created a folder, then erased all the WAV's! wff?!
#67390 - 08/02/2002 08:49 Re: R3Mix Preset in Audiograbber [Re: SE_Sport_Driver]
Terminator
Loc: Dallas, TX
What else is in your command line? It sounds like either you didnt tell ag where to find the lame file, or your command line was wrong. Mine looks like this:
%s %d --r3mix
Yours should be somthing along the lines of:
%s %d --alt-preset standard
Sean
#67391 - 08/02/2002 08:51 Re: R3Mix Preset in Audiograbber [Re: Terminator]
SE_Sport_Driver
I just did "--alt-preset standard".... I thought that took care of everything.. what does %s %d do?
EDIT: Just click the "info" box and found out... I feel stupid now... hehe I guess I took the instructions of putting "--alt-preset standard" in the arguments too literal!
Edited by SE_Sport_Driver (08/02/2002 08:54)
#67392 - 08/02/2002 08:52 Re: R3Mix Preset in Audiograbber [Re: SE_Sport_Driver]
Terminator
Loc: Dallas, TX
Tells the encoder where to look for the ripped wavs. Try it!
#67393 - 08/02/2002 10:54 Re: R3Mix Preset in Audiograbber [Re: SE_Sport_Driver]
Basically you told AG to call LAME with the argument "--alt-preset" but without the IN or OUT file. AG happily does that. And then also deletes the WAV as you also asked it to do. Hehe. It's a case of it doing exactly what you told it to do. And not what you wanted it to do.
When I pasted you my command line, I *did* have the in/out variables in there - guess you missed them.
#67394 - 08/02/2002 10:58 Re: R3Mix Preset in Audiograbber [Re: hybrid8]
SE_Sport_Driver
Nope, you DID have them in there, and I did use them for YOUR preset, but for the --alt-preset, I didn't put them in. I never thought it was "broken" or acting up, I knew I was just telling it the wrong thing...:)
I'm just glad I didn't rip a ton of CD's and THEN find out.
#67395 - 08/02/2002 12:10 Re: R3Mix Preset in Audiograbber [Re: SE_Sport_Driver]
svferris
Heh, I did the exact same thing. Had to do a little research on usenet before I figured out what I did wrong.
#67396 - 08/02/2002 20:11 Re: R3Mix Preset in Audiograbber [Re: Terminator]
Laura
Ok, I played around with this tonight. I set Lame to be used as an external encoder, turned off normalization and used the --alt-preset standard. I then played the original CD and then the MP3 but I have to admit this is all through WinAmp because my players are still in England at the moment, and I thought the song sounded kind of distorted in the MP3 file. I was using Metallica's song One for my example. So what did I do wrong here?
Laura
MKI #017/90
whatever
#67397 - 08/02/2002 20:38 Re: R3Mix Preset in Audiograbber [Re: Laura]
Do it again exactly like you did the first time, EXCEPT, do not delete the WAV file. When you're done encoding, do a 3-way comparison between CD, WAV and MP3. Basically you want to figure out where the problems are being introduced. If your WAV is lousy, then your problem is at the ripping stage, not encode. If your WAV is fine, try the r3mix setting. Or try the following (which is mostly r3mix):
"--nspsytune --vbr-mtrh -V0 -mj -h -b112 --lowpass 19.5 --athtype 3 --ns-sfb21 2 -Z -X0 %s %d"
Don't include the quotes when you paste it into AG. Obviously you have to pick "user defined" in the list box above where you paste the argument.
#67398 - 08/02/2002 21:36 Re: R3Mix Preset in Audiograbber [Re: hybrid8]
Laura
Thanks, I'll give that a try and see. I've always just deleted the .wav files without listening to them. I do have just a cheap generic CD-ROM drive so maybe that is the problem.
Laura
MKI #017/90
whatever
