#66870 - 04/02/2002 17:31 Hostname for RioCar on a lan?
Allistah
How do I know what the hostname is for my RioCar when I plug it into a network w/dhcp? Is this something that I can set in the config.ini file?
Thanks for any help anyone might have.
-Allistah
#66871 - 04/02/2002 17:51 Re: Hostname for RioCar on a lan? [Re: Allistah]
beaker
Loc: England
Try this thread. It may be what you're looking for
#66872 - 04/02/2002 18:06 Re: Hostname for RioCar on a lan? [Re: beaker]
Allistah
I guess theres no way to properly do this like a PC does eh? You gotta do all that hosts file stuff. It would be cool if the DHCP client looked at a setting in the config.ini file for a hostname=MyRioCar line and updated the DNS with it like a PC does. I'd like to be able to have my friends at work just goto a name instead of running some program first.
#66873 - 04/02/2002 18:29 Re: Hostname for RioCar on a lan? [Re: Allistah]
If your PC does this (And it's the true DynamicDNS implementation and not windows) 2.0 will try to register a name based off what you set in the config.ini or via emplode. Spaces are replaced with dashes (-). Not sure about other characters.
#66874 - 04/02/2002 18:33 Re: Hostname for RioCar on a lan? [Re: drakino]
Allistah
What is the option in the config.ini that I need to change? hostname= ? And what [heading] does this go under in config.ini file?
Thanks..
#66875 - 04/02/2002 18:55 Re: Hostname for RioCar on a lan? [Re: Allistah]
Allistah
So I guess this wont work on a Windows based network eh? Bummer. Why is that anyways? Could it be made to work?
#66876 - 04/02/2002 19:03 Re: Hostname for RioCar on a lan? [Re: Allistah]
Terminator
Loc: Dallas, TX
No, it won't. Some else mentioned that windows uses some wins server based system to do it. It could be made to work if someone at empeg decided to rewrite the dhcp server for the empeg. That doesnt seem likely though :-(
Sean
#66877 - 05/02/2002 03:17 Re: Hostname for RioCar on a lan? [Re: Allistah]
In honor of this question, I have created a new FAQ Entry. Enjoy!
#66878 - 05/02/2002 11:22 Re: Hostname for RioCar on a lan? [Re: tfabris]
BTW, the hyphen is a legitimate DNS character, but it's the only non-alphanumeric that is.
#66879 - 06/02/2002 16:02 Re: Hostname for RioCar on a lan? [Re: tfabris]
danthep
Loc: new zealand
Woo, just gave my mark2 a name and now i can ping it by name
All praise the ISC
