#66626 - 04/02/2002 12:10 Removing wires from sled connector to save space
jules
Loc: Indiana USA
Hi,
I have a problem with very limited space in my car installation and do not plan to use the serial, tuner, mute, or microphone. If I remove the wires for these from the sled connector, will I encounter any problems? Also, what functionality do I loose if I connect both the permanent power (yellow) and ignition sense (orange) to switched power? (I assume I'll be rebooting a lot but that doesn't bother me). Will really appreciate any info. Thanks.
I had posted this msg in the technical forum cause I didn't realized there was a dedicated installation forum.
#66627 - 04/02/2002 12:24 Re: Removing wires from sled connector to save space [Re: jules]
That's OK. I'll lock this thread here now and point people to the ongoing discussion in the Technical forum here:
http://empeg.comms.net/php/showflat.php?Cat=&Board=empeg_tech&Number=64857
