#59826 - 16/01/2002 15:11 Got my player back from repair...
BAKup
Loc: Houston, TX
The display works fine now
It's not seeing the HD now
I've already shot off an e-mail to david, but here's the log from the serial port.
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #214 Sat Jun 23 16:38:57 BST 2001
empeg-car player (hardware revision 9, serial number 40104087)
Command line: mem=16m temp=28
Memory: 15064k/16M available (960k code, 20k reserved, 332k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004700).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:f
7
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...•Ô•…¹¹½Ñ½Á•¹É½½Ñ‘•Ù¥•ÁÍéÁÕ)5ߪK¹•±Á…¹¥éY
MéU¹…‰±•Ñ½µ½Õ¹ÑÉ½½Ñ™Í½¹ÁÍéÁÕ)5
--Ben
78GB MkIIa, Dead tuner.
#59827 - 17/01/2002 12:16 Re: Got my player back from repair... [Re: BAKup]
BAKup
Loc: Houston, TX
Well, heard back from David over from support(You da man!), got the go ahead to look at the cable. It's bad , but I've got it working at least He's going to have one sent to me when they get more in.
--Ben
