#59136 - 15/01/2002 10:04 Re-organising Visuals menu
tms13
Loc: Lochcarron and Edinburgh
I know I've mentioned in the past how it's sometimes hard to find a particular visual.
How about making the Visual menu a level deeper, and having 3 sub-menus:
Categorised
The current selection of Abstract, Spectral Plot, Informative, ...
Favourites
The ones chosen in config.ini for the current music source
Alphabetically
All visuals, sorted by name (for easy access with remote or knob)
with Favourites not appearing if the user hasn't set any.
As an example to clarify the above: with this new structure, we'd use Menu -> Visual -> Categorised -> Soundplot -> Tux Much to get our beloved penguin, rather than the current Menu -> Visual -> Soundplot -> Tux Much.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#59137 - 15/01/2002 10:19 Re: Re-organising Visuals menu [Re: tms13]
Nosferatu
Loc: France, Champagne
I agree with that wish.
Yes, when You want to select a visual , the classified Theme isnt very intuitive.
And also, i'd like to have my FAvorites in the Menu ....
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#59138 - 15/01/2002 18:19 Re: Re-organising Visuals menu [Re: Nosferatu]
I'd settle for just being able to scroll backwards through the visuals. It is frustrating to hit the "visual" button 60 times looking for TimeShade128, only to go past it, and have to press the button 60 more times to get to it again.
#59139 - 15/01/2002 19:19 Re: Re-organising Visuals menu [Re: tanstaafl.]
number6
Being able to backwards through the visuals is one major advantage of having the Sony Stalk Interface.
[But not the only one].
Its also on Mark Lords hit list of new features to add to the HIjack kernel real-soon-nowTM
[what it looks like Mark will end up doing is:
1. creating Fake Stalk commands to go Previous visual for those of use who have Tuners [whether or not we have a Stalk attached].
2. For those of us without Tuners, his kernel will pretend there is one there so that we can use #1 to go previous visual.
[Stalk commands come in from the Tuner Interface so you cannot fake a Stalk controler without faking a Tuner if one is not there].
If you ask Mark nicely I'm sure he can push it up the priority ladder a little.
#59140 - 16/01/2002 04:35 Re: Re-organising Visuals menu [Re: tms13]
prolux
Loc: Manchester, UK
I plan to reorganise the visuals menu in the near future in a similar way to how you have described.
A new layer will be added as you have suggested above the current 'Types' menu, this will include the following items:
Types, Favourites, All Visuals, Select Mode
It will work pretty much as you have described, but Favourites will also include functionality for turning on and off the favourites list.
I would like to add a Lists submenu which would be similar to the Favourites menu, but would allow the management of multiple lists as well as list selection - Sadly this would require quite a bit of work due to the read-only issues and so will probably not get implemented until....
The Select Mode submenu I will leave to your imaginations - It is the implementation of a much requested feature.
#59141 - 16/01/2002 06:37 Re: Re-organising Visuals menu [Re: prolux]
tms13
Thanks for the info, Toby. Your plan sounds really good.
Toby Speight
#59142 - 16/01/2002 12:41 Re: Re-organising Visuals menu [Re: prolux]
By any chance would one of the modes be a "scrolling" mode where you could scroll forwards/backwards through the visuals using the rotary knob?
