#57539 - 10/01/2002 14:16 How fast should it upload?
f_devocht
Loc: Belgium
Probably a very stupid question, but being a newbie I hope I'm forgiven ...
Exactly how long should it take to upload my files to the empeg? I started the synchronisation request about 2 hours ago and it's not even halfway through it. I'm uploading 250Mb only! At this rate it'll take forever to get a few Gigs on it ...
Oh, I'm using the USB, couldn't get the ethernet to work.
ta,
Frank
#57540 - 10/01/2002 16:27 Re: How fast should it upload? [Re: f_devocht]
tarkie
USB does take a while, not the fastest interconnect in the world.
Ethernet is a lot lot faster, and you should concentrate on getting that working.
The player by default tries to obtain a dynamic ethernet address from the network via DHCP. I've turned that off by setting manual override on the Player Configuration settings, and specifying an IP address on my network. Resynced the player, and then Emplode picks it up.
Remember that the player is only 10mb ethernet, so if your lan is 100mb you wont see the player.
Good luck
M2a/Smoke/60gb/Tuner!! Thanks Joe M2a/Blue10gb Thanks Ian!
#57541 - 10/01/2002 18:11 Re: How fast should it upload? [Re: tarkie]
I'm not sure what your measure of "a lot lot faster" is, but Ethernet is only marginally faster than USB on the Empeg. I can't remember the exact numbers but I think Ethernet ends up being maybe 10-15% faster. Definitely worth switching to Ethernet, but it's not like it doubles your speed or anything.
#57542 - 10/01/2002 22:19 Re: How fast should it upload? [Re: f_devocht]
You should expect at least 200-250kb/sec from USB - about 15 minutes for 250MB. You should get around 750kb/sec over ethernet, about 5 minutes for a 250MB upload.
YMMV, though, especially with USB. Depends a lot on controller type, etc. It's possible that 2.0 has other issues with USB, I've not done performance tests on it.
#57543 - 10/01/2002 22:44 Re: How fast should it upload? [Re: altman]
kojak71
Using ethernet seems to be more stable. With USB I get loads of errors on uploading tracks with a quite a few tracks not making it to the player. Then again I'm using 2b7. Although the faq says uploads should be done in small chunks, I've had no problems with a 10Gb upload using ethernet
#57544 - 11/01/2002 01:49 Re: How fast should it upload? [Re: kojak71]
f_devocht
Loc: Belgium
I also posted this to the bugs forum cause this has turned into a big problem. After 3hrs, the upload ended with an error during stage 5 and when I try to reconnect I get:
The download process failed during stage 1:
Player error 0xffffffec
#57545 - 11/01/2002 03:10 Re: How fast should it upload? [Re: f_devocht]
I would highly recommend putting in the work to get Ethernet working. There are some machines that USB simply doesn't work reliably on. My home machine is one such machine, there has never been a version of emplode where big uploads have been realiable. In contrast Ethernet works fine.
#57546 - 11/01/2002 05:11 Re: How fast should it upload? [Re: altman]
Laura
Loc: Greenhills, Ohio
I did my first uploading yesterday of around 1Gb. It took 9 1/2 hours using USB which to me seemed like a pretty long time. I am using version 1.02 that came with the player. Would upgrading emplode speed it up? Or should I try ethernet next time?
Laura
MKI #017/90
whatever
#57547 - 11/01/2002 05:24 Re: How fast should it upload? [Re: Laura]
9 1/2 hrs for ONE gig???
Definitely use ethernet next time! Personally when I got my first Mk2a, I'd already read on this board that USB was considerably slower than ethernet was (that's why I never bothered with it) but I didn't know the difference was THAT big.
I don't know how much time it took me to upload one gig, but the times Hugo mentions seem about right.
#57548 - 11/01/2002 05:43 Re: How fast should it upload? [Re: Laura]
Upgrading will not speed USB up, get your Ethernet setup working...
#57549 - 11/01/2002 07:17 Re: How fast should it upload? [Re: andy]
Ezekiel
Loc: NH USA
Remember to check the ethernet cable and the ports at either end. I suffered many mystery errors on account of a bad CAT5 cable. Replaced cable and it's been smooth sailing ever since.
-Zeke
WWFSMD?
#57550 - 11/01/2002 07:57 Re: How fast should it upload? [Re: Laura]
it took about that long to do 10 gig when I first did mine.
I haven't really cared too much about the speed you're probably only going to do the huge uploads right when you get the player after that I would think it would just be one album when you get a new one
#57551 - 11/01/2002 08:10 Re: How fast should it upload? [Re: kojak71]
I found USB to be a lot more stable than ethernet. I keep getting the 0x80072746 error while using ethernet, and haven't managed to complete a synch yet. That makes USB to be, approximately, infinately faster for me
#57552 - 11/01/2002 10:21 Re: How fast should it upload? [Re: Laura]
It shouldn't have taken that long, Laura, even for USB (ethernet is only a tiny bit faster than USB). Sure you weren't using the serial port?
Did you get any error messages?
If you really were using USB, perhaps there's something wrong with the USB setup on your PC. Maybe a motherboard BIOS upgrade is needed, or a device driver for the USB controller needs to be installed?
#57553 - 11/01/2002 11:29 Re: How fast should it upload? [Re: f_devocht]
Fastrack
Loc: Toronto, Ontario Canada
Hi Frank,
I can backup what everyone else is saying! Using USB I get speeds of about 300KB/s (max).... Using ethernet I see about 900KB/s most of the time!.
If your trying to connect the empeg to your network card directly you'll need a cross-over cable.
I hope this helps
Ben Rio Car 10GB + 60GB Toshiba ([green]Green[/green]) - Serial # 30102833
#57554 - 11/01/2002 11:47 Re: How fast should it upload? [Re: Fastrack]
There should not be that big of a difference between USB and Ethernet. If you're seeing speed differences that big, there's something wrong with the USB on your PC. Like I told Laura, probably driver or BIOS related.
#57555 - 11/01/2002 12:09 Re: How fast should it upload? [Re: tfabris]
mafisto
Loc: St. Paul, MN, USA
I'm confused about this. Above, Hugo mentions 250 vs. 750 USB to Ethernet, but there are two references (including yours, Tony) stating that this ratio is not right. Is this a version thing?
your fiend, mafisto
#57556 - 11/01/2002 13:28 Re: How fast should it upload? [Re: mafisto]
Hmm.
I didn't think ethernet was that much faster. But you guys are all saying 3x the USB speed is normal for ethernet.
Okay, I stand corrected. It just didn't sound right to me.
#57557 - 11/01/2002 13:34 Re: How fast should it upload? [Re: tfabris]
SE_Sport_Driver
I remember some talk a while about about 1.1 having faster Ethernet upload speeds... am I imagining this? I thought it was faster at communication with the empeg, but once the actual files were being transfered, I thought it made little difference... hmm
#57558 - 11/01/2002 21:56 Re: How fast should it upload? [Re: tfabris]
Laura
I have to admit it was the first time that I have used the USB port on my computer. And I'm sure that I wasn't using serial, I do enough of those connections on my job and know how slow it is. I didn't see any error messages the times that I checked it. I need to upgrade the bios anyway to install a large drive. So I'll see how it goes after that.
Laura
MKI #017/90
whatever
#57559 - 12/01/2002 04:20 Re: How fast should it upload? [Re: SE_Sport_Driver]
From memory...
In v1.0, USB speed is about 300Kb/s. Ethernet speed is about 450Kb/s.
Peter put a lot of effort into the protocol in v2.0 (it was called v1.1 back then). Bulk ethernet transfers to the player should now get about 700Kb/s. USB is unchanged.
Download from the player is unaffected by the extra work.
#57560 - 12/01/2002 17:49 Re: How fast should it upload? [Re: Roger]
sendero
I wonder if it'd be possible to include support for USB 2.0 so that the transfer speeds could greatly increase. hmm..
Rio Car 30gb
2000 Boxster S, <img src="/ubbthreads/images/graemlins/cool.gif" alt="" />
#57561 - 12/01/2002 18:25 Re: How fast should it upload? [Re: sendero]
The answer to that would be a very straightforward, no. The hardware in the empeg that provides the USB support was conceived long before USB 2.0 existed. Even if it did support USB the ISA bus in the empeg wouldn't be able to take advantage of USB 2.0 speeds.
#57562 - 12/01/2002 21:47 Re: How fast should it upload? [Re: Roger]
jheathco
Loc: Mission Viejo, California
I get close to 1MB/sec with ethernet, about 350 with USB. I use USB when just uploading a few songs because its easier (for me) and use ethernet when doing larger uploads.
John Heathco - 30gig MKIIa w/ tuner module
#57563 - 14/01/2002 23:21 Re: How fast should it upload? [Re: jheathco]
Trekkie
You noted that you couldn't get ethernet to work.
In my experience, ethernet didn't work out of the box. So I tried USB with on set of MP3s.
Then I decided to figure out why Ethernet didn't work. It did get the IP from my DHCP server fine, and it was listed. Log said time out first try.
AFter using USB, it started working magically.
Try your ethrenet again if you haven't. Maybe that same gremlin was in yours as in my new one.
#57564 - 17/01/2002 19:45 Re: How fast should it upload? [Re: tonyc]
Laura
I haven't tried getting it on ethernet yet but I have discovered that if I upload 1 CD at a time it goes very quick over USB. For now I am happy enough with that. I took the day off of work yesterday just so I could install my new 60Gb drive in my desktop computer just for MP3's (even told my boss that but then I've earned some PTO). Spent the day ripping and uploading once I got it installed.
Laura
MKI #017/90
whatever
#57565 - 17/01/2002 20:23 Re: How fast should it upload? [Re: Laura]
I know this will be hard to do... but a month from now you will be very grateful that you took a lot of extra time to get all your tag information just exactly perfectly right and complete before you loaded the songs into the player.
Trust me, there are a lot of people on the bbs (including myself) who wish they had spent more time tagging and less time ripping CDs!
#57566 - 17/01/2002 20:48 Re: How fast should it upload? [Re: tanstaafl.]
Laura
Maybe I better read the FAQ's on tagging before I upload any more. Thanks for letting me know that.
Laura
MKI #017/90
whatever
