#5362 - 12/12/1999 04:45 Grounding the AUX input?
Mark Miller
Loc: Southeastern Pennsylvania
I tried plugging in a portable MD player to the empeg aux input but the sound is suboptimal. It seems ok with another chassis grounded device, though. Would it be advisable to ground the AUX input leads when using a portable MD or tape player?
Thanks,
Mark
--> Get paid to surf the web! http://www.alladvantage.com/go.asp?refid=CCI498
#5363 - 13/12/1999 09:20 Re: Grounding the AUX input? [Re: Mark Miller]
Basically - yes. The inputs are designed to deal with a ground differential (eg, from another head unit) but not a totally floating one. Connecting the ground of the aux in to empeg chassis ground helps in this case.
#5364 - 14/12/1999 03:01 Re: Grounding the AUX input? [Re: altman]
Happy Birthday schofiel
Hugo, doesn't this imply that you should be including three sets of grounding leads with the sled, rather than two?
#5365 - 14/12/1999 15:17 Re: Grounding the AUX input? [Re: schofiel]
No - the aux input is designed for other head units to feed into. In this case, there is no need for any other grounding - the circuit works as intended. If you're feeding walkmans into the aux input, it will work but requires a good ground from somewhere.
#5366 - 15/12/1999 03:05 Re: Grounding the AUX input? [Re: altman]
So, as long as you have installed the grounding leads on the outputs (say, to the amps) then an input device with no earth reference is effectively referenced to the earth that way?
(obvious ignorance now showing)
#5367 - 15/12/1999 11:35 Re: Grounding the AUX input? [Re: schofiel]
No, all the grounds are separate :)
#5368 - 21/01/2000 01:56 Re: Grounding the AUX input? [Re: altman]
Mark Miller
I was reading this thread and I noticed I forgot to add my update. I soldered a thin wire to the outside (shield) of each of the AUX RCA connectors twisted them together and grounded them to the frame that holds the empeg sled. Sound quality is now terrific! I have a small Sharp MD unit that sometimes plug in and it sounds fine. I even tried a friend's Rio player via the empeg aux and it was ok, too.
Thanks for the tip Hugo!
=Mark
