#49227 - 06/12/2001 08:38 Exiting Properties Tab always marks change
Exiting the Properties page of a Playlist by pressing OK, always marks the list as "changed" even when no modification was made to the information.
This isn't a huge deal because no data is changed, but it forced un-necessary sync operations.
I've also been making some macros to cut/copy/paste between different areas in emplode and need to enter a property page and exit without making changes. Having that item marked as changed makes the display confusing when trying to compare to other legitimately-changed entries.
#49228 - 06/12/2001 14:23 Re: Exiting Properties Tab always marks change [Re: hybrid8]
muzza
I pointed this out back in pre-release betas. They just have to check the dirty property of each item in the dialog. They'll get to it one day I guess.
#49229 - 07/12/2001 09:52 Re: Exiting Properties Tab always marks change [Re: hybrid8]
Don't press OK, then. That's what the Cancel button is for .
