#49194 - 05/12/2001 21:27 Playlist Duration increas when mod props
Emplode bug (v2.0b3)
Every time you modify the properties of a playlist, the duration for that playlist increases by the actual duration of the list.
For example: Edit properties to change the Artist field on a 10 minute playlist and the duration will now read 20 minutes. Edit it again and it will now read 30 minutes. Etc.
All my playlists now all read 2x the correct duration after editing.
This phenomenon does not happen when editing track properties.
I searched and couldn't find any other reports of this bug (searched for "duration")
#49195 - 05/12/2001 23:52 Re: Playlist Duration increas when mod props [Re: hybrid8]
I was unable to reproduce this on 2.0b6 (a version you have not yet seen), so I think they may have fixed that one in the process of fixing other bugs in Emplode. Good catch, though.
#49196 - 06/12/2001 04:17 Re: Playlist Duration increas when mod props [Re: tfabris]
No. We fixed that one specifically, post b3.
#49197 - 06/12/2001 08:35 Re: Playlist Duration increas when mod props [Re: Roger]
More quirks coming up - another thread. Let's see if you've changed these...
#49198 - 06/12/2001 08:45 Re: Playlist Duration increas when mod props [Re: Roger]
Another question relating to this... Since my lists now all have the incorrect times (some are now 3 or 4x their proper length because of additional editing), will the fields for these be recalculated and repopulated when I'm running the new software?
#49199 - 07/12/2001 09:49 Re: Playlist Duration increas when mod props [Re: hybrid8]
Yes.
