#46424 - 14/11/2001 05:21 Emplode progress bar
Is Emplode supposed to have an overall progress bar while syncing ? It has a bar for the current tune and a bar below that is never updated. Is this bottom bar supposed to be the overal progress bar, if so it doesn't work.
#46425 - 14/11/2001 06:48 Re: Emplode progress bar [Re: andy]
Correct. It doesn't work. It might eventually. Until then, I think I'll remove it.
#46426 - 14/11/2001 06:56 Re: Emplode progress bar [Re: Roger]
Could you not easily make it sort of work instead ?
I guess the ultimate aim would be to make it match the progress of the volume of data transfered, which I'm guessing is reasonably tricky. Would it not be at least easy to make it show the progress of the number of tunes transfered ?
#46427 - 14/11/2001 07:00 Re: Emplode progress bar [Re: andy]
Actually, I've got an earlier copy of emplode here, in which it does work. I can fix it, probably. However, it still won't be completely accurate. The fix for that can wait until after v2.0-final is released.
#46428 - 14/11/2001 07:09 Re: Emplode progress bar [Re: Roger]
Partly working would definitely be much better than nothing at all (I am part way through a 1Gb sync and I have no idea how far I have got).
#46429 - 14/11/2001 07:19 Re: Emplode progress bar [Re: Roger]
FITNR.
