#46294 - 13/11/2001 12:10 bought a tuner - now what?
jlira
i plugged my tuner into the unit and tried to find a menu option to choose it as an input - no dice.
help please :)
thanks
joe
30102792, 10 GB, Blue
#46295 - 13/11/2001 12:12 Re: bought a tuner - now what? [Re: jlira]
tms13
Loc: Lochcarron and Edinburgh
The tuner should just appear in the Source menu - if not, then I think you have a problem (which might be diagnosable if you can log into your empeg in the car).
You don't say what version of the player software you have - I assume at least 1.0.3, since that's what comes with the tuner.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#46296 - 13/11/2001 12:14 Re: bought a tuner - now what? [Re: jlira]
robricc
If you havn't flashed the Rio Car yet, It has version 1.02 of the car player software on it. You must have at least 1.03 to use the tuner. A CD should have come with the tuner.
#46297 - 13/11/2001 12:31 Re: bought a tuner - now what? [Re: robricc]
jlira
yeap i am running the latest 2b3 of everything (car image and emplode)
#46298 - 13/11/2001 12:36 Re: bought a tuner - now what? [Re: jlira]
robricc
Your serial number in your sig suggests that you have a Rio unit and not an Empeg. With my Empeg, a few of the wires came loose of their crimp in the docking cage. It is my understanding that this issue has been fixed with the Rio units, but you never know.
Otherwise, If you are using the extension cable that came with the tuner, I remember seeing that some of those shipped wired improperly.
Good Luck.
#46299 - 13/11/2001 14:35 Re: bought a tuner - now what? [Re: jlira]
David
Loc: Cambridge
Rio units shouldn't have any player-side tuner problems.
Check that the LED on the tuner comes on when powering up the player (it should come on towards the end of the boot sequence, once the player initialises it).
If you're using the extension cable that came with the tuner, try without it.
Check that your sled is wired firmly and the wiring order is correct (see the FAQ).
Downgrade to 1.03.
I've only had one dead tuner module so far, so wiring and software are the likely culprits.
email carsupport@riohome.com if you still have problems.
#46300 - 13/11/2001 14:38 Re: bought a tuner - now what? [Re: jlira]
Are you sure the software you installed was for a Mark2? I think that accidentally installing a Mk1 version of the software onto a Mk2 might make the tuner unavailable. Just a guess.
#46301 - 13/11/2001 15:03 Re: bought a tuner - now what? [Re: tfabris]
jlira
pretty sure it's MK2, i have been using it every day with no other problems, and i thought if i put MK1 on a riocar, it wouldn't even boot
i'll try some of the diagnostic stuff. maybe the extension cable wiring is mixed up. i guess i will find out tonight :)
joe
