#42234 - 17/10/2001 22:43 long pause after initial start
Liufeng
Loc: Alaska
Sorry if this has already been posted... there are about 100 new messages in bug reports so I haven't read them all.
I'm running MK2 with 2.0b3... There is a long pause with a blank screen (no LED either) between the animated TUX and the startup. Has anyone else noticed this. I thought at first I had a bad upgrade.. but the player works fine as far as I can tell it just takes a while. Note: I don't have any additional HDs.. and no other modifications.
It isn't too troublesome.. just suprising and perhaps a fixable bug.
Tom
Reg #2845: Mark 1 #00173, Mark 2 #119
Reg #2845: Mark 1 #00173, Mark 2 #119, Mark 2a
#42235 - 17/10/2001 23:20 Re: long pause after initial start [Re: Liufeng]
Define "Long". And how about the serial output from the boot process?
One possibility is that (if I recall correctly), they changed the code so that it searches for a second hard disk a little longer. But if it doesn't find one, it sets some kind of a flag so that it boots quicker NEXT time and doesn't bother to search for a second hard disk. I forget the trigger for re-enabling the flag, maybe it was on the next synch?
#42236 - 18/10/2001 00:31 Re: long pause after initial start [Re: Liufeng]
n6mod
Loc: Berkeley, CA
I haven't seen anything like this, but if I had to guess...
It sounds like you have a blank boot logo, so when it's supposed to be showing the logo, the display is totally blank.
Just a guess, mind you...
-Zandr
Mk.I #0150 10GB
RioCar #010101243 10GB (96GB here I come...)
-Zandr
Mk.IIa #010101243 currently getting a 500GB SSD. More spares in the shed.
#42237 - 18/10/2001 01:27 Re: long pause after initial start [Re: n6mod]
Liufeng
Loc: Alaska
Ok you got it. I used Tfabris logoedit to delete custom logos and now it works like I expect. Silly, really.
Thanks for the help.
Tom
#42238 - 18/10/2001 04:16 Re: long pause after initial start [Re: tfabris]
if it doesn't find one, it sets some kind of a flag so that it boots quicker NEXT time.
It's supposed to do an exhaustive check every time when at home -- you're unlikely to add a disk and then put it in the car, right? Then it should save this value to flash, allowing the car boot to go quicker on a single disk.
However, I don't think that Hugo's actually implemented it yet.
