#41917 - 17/10/2001 13:33 D-O-A 2.0b3 Install
grgcombs
Loc: Dallas, TX
I should pretext this by saying I accepted any of the following issues when I downloaded the new beta. I wanted (and still want it) really really really bad. Lets hope the following is my fault some how.
I'm running Win2K, and I was installing the developer beta for the RioCar version. S/N 30102603. In the car I have a tuner and a Sony stalk.
1. I uninstalled the old empeg USB drivers.
2. I uninstalled emplode (1.0.3)
3. Installed the new emplode (2.0b3)
4. Installed the new developer kernel (2.0b3)
Installation all completed perfectly, no errors given at any point.
Immediately after the kernel install, the empeg reboots, flashy new startup guys!!! Then it puts up the static logo, gives me the initial loading stuff screen, then flashes to a screen with one horizontal line across the middle of the screen. It then immediately reboots and repeats.
Here's what I saw flashing by on the serial port ... If this is insufficient detail, I can give you more ...
Starting player
empeg-car 2.00-beta3 2001/10/17.
3bcda1f5 DHCP name = lo
3bcda1f5 DHCP index = 1
3bcda1f5 DHCP flags = 0x8
3bcda1f5 DHCP addr = 0.0.0.0
3bcda1f5 DHCP bcast = 0.0.0.0
3bcda1f5 DHCP mask = 0.0.0.0
3bcda1f5 DHCP name = eth0
3bcda1f5 DHCP index = 2
3bcda1f5 DHCP flags = 0x1043
3bcda1f5 DHCP addr = 192.168.0.6
3bcda1f5 DHCP bcast = 192.168.0.255
3bcda1f5 DHCP mask = 255.255.255.0
3bcda1f5 DHCP Adding interface eth0
Prolux 4 empeg car - 1.1090 Oct 17 2001
Vcb: 0x408ce000
E !! local_audio_player(275): memory violation at pc=0x020514bc, lr=0x020f6fc8 (
bad address=0x00000000, code 2)
componentpc : [<020514bc>] lr : [<020f6fc8>]
sp : be1ffcf0 ip : be1ffc98 fp : be1ffd08
.cpp 543: Invr10: 00000000 r9 : 022099c0 r8 : be1ffd34
alid tuner7 : 00000080 r6 : 022099c0 r5 : 00000000 r4 : 021ed4d0
informatr3 : 00000000 r2 : 00000000 r1 : 00000001 r0 : 021ed4dc
ion for FFlags: nzCvID 0x0. T IRQs on FIQs on Mode USER_32 Segment user
his is bad.
Control: C0EC517D Table: C0EC517D DAC: 00000015
@@ S0
Function entered at [<0205148c>] from [<02076358>]
r5 = 02224DB8 r4 = BE1FFD2C
Function entered at [<02076338>] from [<02075e10>]
r6 = 022099C0 r5 = 02224DB8 r4 = 02224CB8
Function entered at [<02075cdc>] from [<020ec52c>]
r10 = 020EC474 r8 = 0000300D r7 = 00000080 r6 = 0000000D
r5 = 022099C0 r4 = BE1FFD64
Function entered at [<020ec474>] from [<020f3808>]
r5 = 022099D8 r4 = BE1FFE40
Function entered at [<020f3740>] from [<0212e80c>]
r4 = 00000000
Function entered at [<0212cf80>] from [<020f3584>]
r8 = 0219712C r7 = 02197118 r6 = 020EC474 r5 = 00000003
r4 = 00000001
Function entered at [<020f34d4>] from [<0212e80c>]
r5 = 00000000 r4 = 00000000
Function entered at [<0219b3b0>] from [<020f5a28>]
Restored terminal settings
Abnormal player termination
Player received signal 11
Hope this helps!
Greg
RioCar (40Gig) Blue/Red/Green
'01 Audi A4 2.8 Quattro
#41918 - 17/10/2001 13:39 Re: D-O-A 2.0b3 Install [Re: grgcombs]
phaigh
I don't know if it did any checking, but perhaps the downloaded image was corrupt - it might be worthwhile checking it again.
Also, give consumer a go - I've d/l that and got it working, so perhaps the dev. image is broken.
Is yours a Mk2 or Mk2a?
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#41919 - 17/10/2001 14:07 Re: D-O-A 2.0b3 Install [Re: grgcombs]
schofiel
MAke sure you have downloaded the correct image for your player - ie. that you are not mistakenly downloading a Mk 1 image to a Mk 2 or vice versa. Each image is optimised for the available memory of the hardware in each player, so exceptions and seg faults as you see in your boot log dump may point to this.
#41920 - 17/10/2001 14:13 Re: D-O-A 2.0b3 Install [Re: grgcombs]
mac
Loc: Cambridge, UK
If you screw your eyes up and look hard enough at the log (ignoring junk that came from the kernel) you'll see:
E !! local_audio_component.cpp 543: Invalid tune information for ID 0x0. This is bad.
I suspect this is a red herring but the traceback looks like something to do with the playlist code. I'll investigate further tomorrow.
Has anyone done much with empty playlists?
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
#41921 - 17/10/2001 15:05 Re: D-O-A 2.0b3 Install [Re: mac]
I have an empty one, hang on, I'll check it.
Nope, behaves fine on mine. Empty playlists say "none" on the player screen and don't let you try to play them. Selecting an empty playlist in Emplode and hitting Play results in "end of playlist" on the player but no crashes.
#41922 - 17/10/2001 15:47 Re: D-O-A 2.0b3 Install [Re: schofiel]
grgcombs
Loc: Dallas, TX
Unless someone changed the terminology on me, my RioCar has a mk2 kernel on it.
#41923 - 17/10/2001 16:02 Re: D-O-A 2.0b3 Install [Re: mac]
grgcombs
Loc: Dallas, TX
Also note that reinstalling the 1.03 developer kernel brings it back to life.
Also, if I forgot to mention this elsewhere, it didn't help installing the client version of 2.0b3.
g
#41924 - 17/10/2001 16:53 Re: D-O-A 2.0b3 Install [Re: grgcombs]
bonzi
I have the same symptoms. The player restarts after two or three seconds (after only displaying a horizontal line for a fraction of second). Attached is serial log.
Reverting to 1.03 worked.
*snif*
Dragi "Bonzi" Raos
Zagreb, Croatia
40916-serial_log.zip (75 downloads)
#41925 - 17/10/2001 17:01 Re: D-O-A 2.0b3 Install [Re: bonzi]
Has anyone who's been having these crashes done a re-download of the .upgrade file with GetRight to make sure it's OK?
#41926 - 17/10/2001 17:06 Re: D-O-A 2.0b3 Install [Re: tfabris]
bonzi
Hm, the length is correct, so it is not ftp ASCII transfer EOL fix error (and the protocol is not ftp, anyway )...
I don't have GetRight. Do you have the URL handy?
(http://www.getright.com, obviously... )
Dragi "Bonzi" Raos
Zagreb, Croatia
Edited by bonzi on 18/10/01 01:08 AM.
#41927 - 17/10/2001 18:02 Re: D-O-A 2.0b3 Install [Re: bonzi]
jwickis
Loc: India
actually I found it here myself.
I usually use Gozilla is GetRight better does anyone know? Anyone,anyone?
#695-Mk2/8 colors-12Gig w/Tuner- awaits v2.x & Voice Recog.
#41928 - 17/10/2001 18:04 Re: D-O-A 2.0b3 Install [Re: tfabris]
bonzi
Downloaded GetRight, downloaded development image using GetRight, no difference.
Dragi "Bonzi" Raos
Zagreb, Croatia
#41929 - 17/10/2001 18:50 Re: D-O-A 2.0b3 Install [Re: grgcombs]
grgcombs
Loc: Dallas, TX
One last note and I'll leave you guys alone. It doesn't make any difference if I take it out to the car and plug it in where there is a tuner.
g
#41930 - 17/10/2001 20:01 Re: D-O-A 2.0b3 Install [Re: grgcombs]
ctadlock
I had the same problems as mentioned above, here is how I fixed mine:
The blank line is a visual, everything else worked once I switched to the menu.
No sound came out because the volume on the player was all the way down.
Everything seems to work fine for me.
Specs:
W2k
Mark 2
Ethernet
developer mark2 upgrade
#41931 - 17/10/2001 20:58 Re: D-O-A 2.0b3 Install [Re: ctadlock]
grgcombs
Loc: Dallas, TX
I can't get to the menu to change anything. I realize it's a visual, but the machine is in a semi-endless loop. No amount of anything will bring up a menu before it reboots again.
g
#41932 - 18/10/2001 02:55 Re: D-O-A 2.0b3 Install [Re: grgcombs]
BryanR
Loc: Berkshire, UK
I'm having this problem too. I have been able to see a menu, by repeatedly pressing the menu button whilst it's booting, but it still reboots automatically anyway.
Well, I like the animation, anyway. Back to 1.03, I guess...
Bryan.
Mark 2 #080000515
Was 12GB Blue, now 42GB Green!
Bryan.
#41933 - 18/10/2001 04:35 Re: D-O-A 2.0b3 Install [Re: bonzi]
It should be very hard to get a corrupted .upgrade file as it is internally length and CRC checked.
#41934 - 18/10/2001 06:32 Re: D-O-A 2.0b3 Install [Re: BryanR]
grgcombs
Loc: Dallas, TX
So that makes three of us right? BryanR, bonzi, and myself. What do we have in common?
1. I've got two drives, one 10 gig, and one self-installed IBM 30 gig.
2. I 've got my IP address hard set, not on DHCP.
3. I've got just over 3000 titles which span both drives, barely.
4. I previously edited that config file for PalmEmpeg to show more output on the serial, but that should have been wiped during the reinstall.
5. I've got an actual RioCar player (Mk2a?)
6. I have a tuner in the car.
7. I have a sony stalk in the car.
8. I was previously using 1.03 (most people were I guess)
g
#41935 - 18/10/2001 06:33 Re: D-O-A 2.0b3 Install [Re: altman]
bonzi
That's what I thought. And besides, it being corrupted so subtly that kernel and root FS are OK, and player almost runs, is extremely unlikely. But one clutches the proverbial straw... .
Dragi "Bonzi" Raos
Zagreb, Croatia
#41936 - 18/10/2001 06:41 Re: D-O-A 2.0b3 Install [Re: grgcombs]
bonzi
2, 4 & 8 (single drive, full but not too full (140MB free), timecodes output, original empeg MkII, tuner and stalk not yet installed, migrated from 1.03).
Dragi "Bonzi" Raos
Zagreb, Croatia
#41937 - 18/10/2001 06:44 Re: D-O-A 2.0b3 Install [Re: grgcombs]
BryanR
Loc: Berkshire, UK
Quite a few similarities here! I have:
1. Two drives - one 12 gig and one self-installed IBM 30 gig.
2. IP address hard-set.
3. I've got over 4500 titles, spanning both disks.
4. I had it spitting out more info on the serial line, for something I was messing about with myself.
5. I've got a Empeg Mk2
6. I have a tuner.
7. (nope)
8. I was previously running 1.03 (developer).
Before upgrading, I had kernal hacks for VolAdj, IRHack and KnobAppend, and Picker running in my init script. Of course, these should have all gone now. I've also got quite a few things in and under /drive0/var, not that that should make any difference, either.
Bryan.
Mark 2 #080000515
Bryan.
#41938 - 18/10/2001 06:47 Re: D-O-A 2.0b3 Install [Re: grgcombs]
The config file lives on the music partition and is not rewritten by an upgrade.
#41939 - 18/10/2001 07:08 Re: D-O-A 2.0b3 Install [Re: peter]
BryanR
Loc: Berkshire, UK
Just as a quick test, I removed the following from my config.ini file:
[output]
timecodes=1
notify=1
And now it works correctly!
Right, I'm happy now...
Bryan.
Mark 2 #080000515
Bryan.
#41940 - 18/10/2001 07:11 Re: D-O-A 2.0b3 Install [Re: BryanR]
grgcombs
Loc: Dallas, TX
I was just about to try that! So I guess the additional serial output is broken?
g
#41941 - 18/10/2001 07:26 Re: D-O-A 2.0b3 Install [Re: grgcombs]
edwin
Loc: Druten, The Netherlands
WEEEHOOO!
I only removed the notify=1 and left in [output] and timecodes=1 and it also works!!! But no output on serial now anymore.... IIRC, I have read about dropping 'notify' support in future releases, so I guess this is what it was then.
After changing the config.ini I got another error concerning the empty playlist. I went into the menu and selected a playlist and it works! Well that resolves bug #1119 then.
I'm out driving now
ญญ______________
Edwin de Vaan
[white]ญญ______________[/white]
Edwin de Vaan aka FLaSHmAStER
#41942 - 18/10/2001 07:35 Re: D-O-A 2.0b3 Install [Re: grgcombs]
Yes. Mr Robson, Mr Combs: good catch.
#41943 - 18/10/2001 08:30 Re: D-O-A 2.0b3 Install [Re: edwin]
No, it was a bug -- I guess none of us (and no-one on the alpha list) had serial notify enabled. Or else they managed never to power up into an empty playlist.
FITNR.
#41944 - 18/10/2001 08:58 Re: D-O-A 2.0b3 Install [Re: peter]
bonzi
So, it is combination of 'notify' and booting to the empy list? I would like to keep notify, but what the heck, I will remove it now and see what happens...
Dragi "Bonzi" Raos
Zagreb, Croatia
Update: Aaargh, I managed to fire upgrade to 2.0b3 without doing the editing the whole excercise was about! Too excited.... Sigh, back to 1.03, edit config.ini, try 2.0b3 again...
Edited by bonzi on 18/10/01 05:03 PM.
#41945 - 18/10/2001 12:16 Re: D-O-A 2.0b3 Install [Re: bonzi]
bonzi
Forgot to update: It works! Removing timecodes from serial eliminated reboot problem. However, don't close this bug as yet: I want my timecodes (from time to time, anyway).
Dragi "Bonzi" Raos
Zagreb, Croatia
#41946 - 13/11/2001 22:57 Re: D-O-A 2.0b3 Install [Re: bonzi]
groo
So I have a Mk.1 player (serial 00366), and I downloaded the correct image for the player. I have exactly the same symptoms as described above, and my config.ini (/empeg/var/config.ini) does not contain an output section, let alone those two keys. :-(
I was previously running 1.02, and am now running 1.03. Attached are a partial log of the boot messages as well as my config.ini.
45102-config_ini.txt (399 downloads)
