#36847 - 20/08/2001 16:42 how did you bend the tabs to open mkii
silvercas
just trying to be as delicate as possible
#36848 - 20/08/2001 16:55 Re: how did you bend the tabs to open mkii [Re: silvercas]
morrisdl
Loc: Rochester, NY USA
very carefully!
just make sure to get them back down or it might get stuck in the sled - speaking from personal experience.
-Doug
Mk2-12G Blue (Now A/R Green)
#36849 - 20/08/2001 17:06 Re: how did you bend the tabs to open mkii [Re: morrisdl]
silvercas
hmm did you use pliers? also where both referring to the tabs on the actually case not the top right? I can do this... ROB WHAT IS THE TRICK?
#36850 - 20/08/2001 17:25 Re: how did you bend the tabs to open mkii [Re: silvercas]
Greetings!
Actually, you should not need to bend the tabs to open the top. It should slide. It might be a little tough, or you would have to bend the tabs very slightly, but it should not be a significant amount.
Paul G.
SN# 090000587 (96GB Smoke)
#36851 - 20/08/2001 17:25 Re: how did you bend the tabs to open mkii [Re: pgrzelak]
silvercas
bend them with plyers... i dont want to mess this up.
#36852 - 20/08/2001 18:05 Re: how did you bend the tabs to open mkii [Re: silvercas]
mardibloke
Loc: Penarth, UK
Screwdriver did the trick for me, bend a very small ammount at a time and keep testing the lid. Make sure you have the handle in the correct position to release the lid too !
Rod, UK Mk2 64gig Red S/No.341 2xDell RioReceiver
Rod, UK
#36853 - 20/08/2001 18:18 Re: how did you bend the tabs to open mkii [Re: mardibloke]
silvercas
yup the handle was pull outward so that those tabs were down.. ok ill lightly press down with a screwdriver tommorow when I try again
#36854 - 21/08/2001 02:05 Re: how did you bend the tabs to open mkii [Re: silvercas]
The best way to do this is not to bend the tabs at all. If you fold the handle out, you should be able to insert a screwdriver into the gap just behind the tabs. With a small amount of leverage, you should be able to coax the lid past the tabs.
Remember to take the fascia off first.
#36855 - 21/08/2001 03:11 Re: how did you bend the tabs to open mkii [Re: silvercas]
David
Loc: Cambridge
I see a lot of players that come back for repair with mangled cases. On one player, the tabs had been bent to get the unit open a few times and were so weak they were about to fall off.
David
// I'm probably not speaking on behalf of empeg/SONICblue here...
#36856 - 21/08/2001 03:26 Re: how did you bend the tabs to open mkii [Re: David]
silvercas
tell us the correct way to open it please... the parts inside are user serviceable. :)
#36857 - 21/08/2001 03:47 Re: how did you bend the tabs to open mkii [Re: silvercas]
Refer to Rogers post further down the thread.
This does invalidate the warranty, though.
#36858 - 21/08/2001 04:45 Re: how did you bend the tabs to open mkii [Re: rob]
silvercas
ok will try that method.. even though im A+ certified to repair computers?
#36859 - 21/08/2001 05:39 Re: how did you bend the tabs to open mkii [Re: silvercas]
It doesn't have much in common with a PC.
#36860 - 21/08/2001 05:50 Re: how did you bend the tabs to open mkii [Re: rob]
silvercas
not to argue but I disagree.. It has a mobo a cpu memory, hd and runs linux.. its a computer to me. the only difference is the display a VFD (i think thats what its called )
#36861 - 21/08/2001 06:51 Re: how did you bend the tabs to open mkii [Re: silvercas]
It might be a computer, but it's not a PC.
#36862 - 21/08/2001 06:54 Re: how did you bend the tabs to open mkii [Re: Roger]
silvercas
hmmmm..ok its not a personal computer but it is a computer and is very servicable. also A+ doesnt entail just PC's
#36863 - 21/08/2001 06:56 Re: how did you bend the tabs to open mkii [Re: silvercas]
mardibloke
Loc: Penarth, UK
Its doesn't pay to argue with the management
Rod, UK
#36864 - 21/08/2001 07:43 Re: how did you bend the tabs to open mkii [Re: silvercas]
You'll still void your warranty.
#36865 - 21/08/2001 07:44 Re: how did you bend the tabs to open mkii [Re: Roger]
silvercas
ah thats ok.. i took some business classes and they gotta prove I damaged it. :)
#36866 - 21/08/2001 07:58 Re: how did you bend the tabs to open mkii [Re: silvercas]
mardibloke
Loc: Penarth, UK
Erm no, you have to prove you have not had the lid off. As soon as you take the lid off your on your own. You then are at the mercy of Empeg goodwill. For many people Empeg have stretched this goodwill a very long way. I hope it continues
Rod, UK
#36867 - 21/08/2001 08:01 Re: how did you bend the tabs to open mkii [Re: mardibloke]
silvercas
me to! :)
#36868 - 21/08/2001 09:08 Re: how did you bend the tabs to open mkii [Re: silvercas]
PC's are easy to work inside. Everyone knows how they go together, and they are designed so that common mistakes do not - usually - cause serious damage. This is not the case with the car player. The metalwork is easy to assemble and dissassemble when you've done it twenty times, but the first few times it's easy to bend things, snap things, and cause damage which you may not even notice at first. There are connectors without locating lugs which will cause serious damage should you offset them upon reconnection.
That's why removing the lid invalidates your warranty. If you choose to do so - hopefully having read some of the excellent advice that has been posted to this BBS - then it's your call, and it's at your risk.
#36869 - 21/08/2001 12:31 Re: how did you bend the tabs to open mkii [Re: silvercas]
beaker
Loc: England
Thought I'd make a (very short!!) video to show how I do it. There may be a better method but this works without bending anything too much. I did do a longer video showing the complete removal of the lid but it was unnecessarily long for all the people using modems so I didn't put this up.
You'll find the video here.
Marcus (beaker)
32 gig (various colours)
#36870 - 21/08/2001 12:39 Re: how did you bend the tabs to open mkii [Re: beaker]
Perfect! That's the best way to open the player.
Note that opening is a little easier and reassembly is a lot easier with the Rio version of the product - we made some slight changes to the metalwork.
#36871 - 21/08/2001 13:20 Re: how did you bend the tabs to open mkii [Re: beaker]
Cool. I am linking that puppy in the FAQ. Any chance that the URL will stay good for a long time?
#36872 - 21/08/2001 13:25 Re: how did you bend the tabs to open mkii [Re: tfabris]
beaker
Loc: England
Certainly for the forseable future. If anyone wants to mirror it (just in case it does become unavailable for some reason) please feel free to do so. If this community website comes off it could be put into the file repository (if there's going to be one that is).
Marcus (beaker)
#36873 - 21/08/2001 14:04 Re: how did you bend the tabs to open mkii [Re: beaker]
beaker
Loc: England
I've added another short video showing how to get the tabs back over again on reassembly. Same link.
Marcus (beaker)
