#360105 - 29/10/2013 07:02 Twin-slot shelving rails, mounting flat board to
So, in my study, I've got some twin-slot shelving rails (specifically B&Q's "flexi" system), with shelves on, as normal.
Now, I'd like to mount some stuff (power strips, etc.) in the same plane as the wall, so I'm thinking that I can mount some fibreboard vertically to the upright rails, spanning at least two rails, preferably so that it mounts into the existing slots in the rails.
But, I can't figure out whether this kind of bracket is available, how to search for it, or -- if it's not available -- how to mount something like that myself.
Ideas?
#360106 - 29/10/2013 07:06 Re: Twin-slot shelving rails, mounting flat board to [Re: Roger]
But, I can't figure out ... how to search for it
This BBS is brilliant! Immediately after posting that, I found something like what I want. Thanks, BBS!
Now to figure out if (a) this is compatible with the B&Q system or (b) if there's something similar for the B&Q system.
#360108 - 29/10/2013 11:05 Re: Twin-slot shelving rails, mounting flat board to [Re: Roger]
Originally Posted By: Spur Shelving
Slots are 31.75mm pitch. If you require 32mm pitch please contact us reference Spur Double-Lok32
So now you just need to measure the pitch on your existing units.
Edit:Though in this case I suspect it really doesn't matter: they should fit and work fine.
#360109 - 29/10/2013 11:37 Re: Twin-slot shelving rails, mounting flat board to [Re: mlord]
I've ordered some. Worst case, I can just file them down a bit.
#360141 - 01/11/2013 15:13 Re: Twin-slot shelving rails, mounting flat board to [Re: mlord]
They do. Sorted.
