#35571 - 03/08/2001 02:22 MP3 Ripper
LTJBukem
In order that I start ripping MP3's now in preparation which CD -> MP3 Ripper would you guys recommend ?
Must be free and run on Win 2000 and NT.
LTJ
LTJ
#35572 - 03/08/2001 02:26 Re: MP3 Ripper [Re: LTJBukem]
#35573 - 03/08/2001 02:27 Re: MP3 Ripper [Re: LTJBukem]
mtempsch
This is one of the few items I've actually spent money when it comes to software, so I'll immediately ignore the freeware requirement and
recommend AudioGrabber with the Lame encoder
See this url
#35574 - 03/08/2001 02:29 Re: MP3 Ripper [Re: mtempsch]
What do you guys think of Audio Catalyst? If any of you like it, what settings would he/she recommend?
Thanx :)
MK II BLUE/RED 12GB #923
#35575 - 03/08/2001 02:54 Re: MP3 Ripper [Re: Taym]
tigloo
Loc: Hamburg, Germany
I used to be using Audio Catalyst. Best settings are probably a matter of taste, I usually use variable bitrate and set it to a max bitrate of 192kbs.
However, I have been told numerous times that LAME would be much better in terms of sound quality than Xing's encoder, even though Xing is much faster.
I cannot hear a big difference with my simple ears, but I didn't really compare seriously yet.
Till
#35576 - 03/08/2001 03:03 Re: MP3 Ripper [Re: LTJBukem]
crazymelki
Loc: Switzerland
I use the comercial software Easy CD-DA Extractor from Poikosoft also with Lame 3.89 decoder!
CrazyMelki
crazymelki.com
#35577 - 03/08/2001 05:51 Re: MP3 Ripper [Re: Taym]
Happy Birthday Dignan
I just use Audiocatalyst. It doesn't require any thought, which is good for me
Try a few programs and see what you like. I like the speed and usability of AC, but the majority of people here are much more picky about the quality of their MP3's. For me, fast and easy AC is the way to go.
DiGNAN
Ob-La-Di, Ob-La-Da, etc.
#35578 - 03/08/2001 05:56 Re: MP3 Ripper [Re: Dignan]
Andrew
I like MusicMatch Jukebox. It's got quite a nice tag editor now as well. See www.musicmatch.com
Andy
26GB MKII Blue #090000727
#35579 - 03/08/2001 07:01 Re: MP3 Ripper [Re: LTJBukem]
Sheetzam
Loc: Annandale, VA
Personally I have been VERY happy with MusicMatch Jukebox. The encoder is good (I use 76%VBR), it keeps our quite extensive music collection in order, and searchable. Basically, it's almost everything you could want for dealing with your mp3's all in one program.
Now if only there was some nifty interface between it and the empeg...
#35580 - 03/08/2001 07:41 Re: MP3 Ripper [Re: tigloo]
smu
Loc: Germany (Ruhrgebiet)
Hi.
Take a look at http://www.incase.de/lame-xing-compare/ for a (now rather old) compare between Xing (AudioCatalyst) and lame encoding quality.
cu,
sven
proud MkII owner (12GB blue/green/smoked, #080000113)
#35581 - 03/08/2001 09:16 Re: MP3 Ripper [Re: LTJBukem]
jpski
Audiograbber & Lame have been what I was using. A LONG time back I purchased Audiograbber. I switched to Audiocatalyst when it was released. The Xing encoder really leaves some pretty bad artifacts in the MP3s. Also, the Lame encoder has nearly caught up with Xing speed-wise... without significant artifacts. The Audiocatalyst code development has stopped, so they will never add new features.... so forget about things like ID3v2 tags.
Audiograbber, however, is still being actively worked on. It is a rock solid application that I have used for years. I'd gladly pay much more than $20 (recently lowered from $25) for this app. The CD audio ripping engine has also come a long way since audiocatalyst. I NEVER get any errors ripping around 24x most of the time.
Buy audiograbber & download LAME!
-Jeremy
Mk2/40GB/Blue
Mk2/40GB/Blue
#35582 - 03/08/2001 09:26 Re: MP3 Ripper [Re: tigloo]
I have been told numerous times that LAME would be much better in terms of sound quality than Xing's encoder, even though Xing is much faster. I cannot hear a big difference with my simple ears, but I didn't really compare seriously yet.
Me too. I can't hear a difference between the Xing encoder at a high VBR rate and LAME at a similar rate. Nonetheless, I've been using LAME lately as everyone keeps slamming Xing. Bowing to peer pressure, I suppose.
#35583 - 03/08/2001 09:30 Re: MP3 Ripper [Re: Sheetzam]
Terminator
Loc: Dallas, TX
I think using musicmatch breaks ff/rw on the empeg though. :-(
Sean
#35584 - 03/08/2001 09:50 Re: MP3 Ripper [Re: LTJBukem]
Terminator
Loc: Dallas, TX
I use audiograbber and lame, but if it must be free, then I think your best option would be EAC and lame. EAC takes some configuring to get things set up right, but there are some excellent step by step directions for this. EAC uses secure ripping, so its great for scratched cds. There are a bunch of lame command lines around, so if you need one, let me know. If you decide to use lame, try to use the command line exe rather than the dll, because the dll hasn't changed much since 3.87.
Sean
#35585 - 03/08/2001 09:53 Re: MP3 Ripper [Re: LTJBukem]
edwin
Loc: Druten, The Netherlands
With a Plexwriter comes Plextools, at least here in Europe. It will rip your CD's to WAV excellently, as to be expected of Plextor. Then again, you could add the LAME dll to it and end up with MP3's! WMA is supported also.
I actually use Feurio! Professional since it also has nice database functionality for organizing your audio CDs. Of course, with some help of the LAME dll out come the MP3s.
Edwin de Vaan
mk2 rev.7 # 080000263 (queue 1232) 6+20Gb blue/red
[white]­­______________[/white]
Edwin de Vaan aka FLaSHmAStER
#35586 - 03/08/2001 10:29 Re: MP3 Ripper [Re: Terminator]
No, using Variable Bit Rate encoding is what breaks FF/RW. It's not Musicmatch's fault, it's the empeg's fault. This bug will be fixed on the empeg with the next software release.
Variable Bit Rate encoding is a good thing, don't let the FF/RW bug scare you away from VBR.
#35587 - 03/08/2001 10:36 Re: MP3 Ripper [Re: tfabris]
Terminator
Loc: Dallas, TX
You are right, I got things mixed up. Most of my lame encoded vbr files work fine. Heres a quote from the release notes.
"It appears that Audio Catalyst will produce files with incorrect VBR
headers if Real Player 7 is also installed. It is not possible to fast
forward or rewind such files, the time display will not update and the
player will not remember where it was in the track if powered
off. Apparently the latest version of MP3 Tag Studio can repair these files
although we have not tested it."
Sean
#35588 - 03/08/2001 10:46 Re: MP3 Ripper [Re: Terminator]
Oh, I see. You were referring to a different issue where the files are actually corrupted. Sorry, I forgot about that one.
Even if the files are correctly encoded and fixed, the empeg currently has trouble doing FF/RW in VBR files. This will be taken care of with version 2.0 software.
#35589 - 03/08/2001 11:17 Re: MP3 Ripper [Re: LTJBukem]
trevorp
Loc: Ft Lauderdale, FL
I have to put my vote in for EAC + Lame. I've been using them for about a year now. I _CAN_ hear a difference between Lame and Xing... Or at least I think I can Maybe that's why it's called psycho-acoustics?
-Trevor
Mk 2, Green 12GB 080000349
-Trevor
Mk 2, Green 12GB, Tuner, 2.0b11, 080000349
#35590 - 03/08/2001 11:21 Re: MP3 Ripper [Re: Terminator]
Geoff
Loc: Northern Ireland
I'd be interested in some of those lame command lines. I just switched to using the dll last week instead of the exe for the simple reason that whatever way I had the exe configured, it was taking about 30-35 minutes to encode a ripped .wav file compared with the dll ripping and encoding at between 0.5x - 0.7x (about 5 minutes for a 3.5min track)
(I'm using EAC 0.9 prebeta 11 and lame 3.89 MMX, encoding to 192k VBR)
Geoff
Got one of the first Mark 2 empegs...
Geoff
Mk1 Blue - was 4GB, now 16GB
Mk2 Red - was 12GB, now 60GB
#35591 - 03/08/2001 11:29 Re: MP3 Ripper [Re: Geoff]
synergy
From abcde (linux using cdparanoia and lame) I use the following command arguments:
-m a -q 2 -h -v -V 2 -b 96 -k --add-id3v2
There is a bit of redundancy in the arguments, but it works very well for me. Basically, I'm setting it to (in order)
Automatically decide stereo format (joint or separate)
quality 2 (1-10 scale, 1 being absolute best)
High quality switch (Vbr automatically turns this on I think)
vbr mode
VBR quality of compression (1-10 scale, 1 being bigger files, 10 being crappy sound)
Minimum bitrate of 96kbs
kill the high-pass filter
force writing id3v2 tags (lame will write v1 tags by default only)
#35592 - 03/08/2001 11:45 Re: MP3 Ripper [Re: synergy]
trevorp
I used to use -mj -h -q2 -V1 -b96 -B320, but have recently switched to --r3mix -b96 --add-id3v2. From www.r3mix.net: "--r3mix -b112" is synonym for "-V1 -mj -h --athtype 3 --lowpass 19.5 -b112"
I changed to -b96, just to stick with my previous minimum bitrate.
I highly recommend this site for a good read on MP3 encoding.
-Trevor
-Trevor
#35593 - 03/08/2001 12:22 Re: MP3 Ripper [Re: Geoff]
smu
Hi.
My lame commandline option is configured as follows within EAC:
-v -h %h-V 0 -q 2%h%l-V 4 -q 5%l -ms -b 128 -B %r %c-p%c %s %d
All that % stuff is for using the switches EAC provides to configure the encoder. With my current settings, the above commandline equals to:
-v -h -V 0 -q 2 -ms -b 128 -B 320
cu,
sven
#35594 - 03/08/2001 12:30 Re: MP3 Ripper [Re: LTJBukem]
SuperQ
Loc: Berlin, DE
Damn, I guess that rules out my first choice.. ripit.pl :)
12gig red mk2 -- 080000125
80gig red mk2 -- 080000125
#35595 - 03/08/2001 16:48 Re: MP3 Ripper [Re: synergy]
Geoff
Just out of interest, how long does lame take to encode files using your settings? (and what spec is the machine?)
I just find it hard to believe that on my 300MHz P2 (with 384MB RAM!) lame is still estimating 40 minutes to encode a 6 minute .wav - admittedly it's running Win98SE, but even that can't be the problem!!
I know about the reported problems with Audiocatalyst, but it ripped and encoded a CD faster than the playing time. EAC & lame (at the minute) is taking about 5 hours to do one disc... it's getting to be an overnight job to rip a couple of CDs!!
I must be doing something very wrong!
Geoff
Geoff
#35596 - 03/08/2001 17:15 Re: MP3 Ripper [Re: LTJBukem]
I recommend Easy cd-da
I tried audio catalyst but it was hard to get to work because it requires aspi plus easy cd-da gives free updates
32Gig MK2 In 2001 VW Golf TDI
#35597 - 03/08/2001 17:43 Re: MP3 Ripper [Re: Geoff]
synergy
I'm ripping at approximately 5x realtime (Pioneer DVD drive). Encoding is being done at about 1.75x realtime on my main (at the house) fileserver.
Now, Specs... that machine is a Dual P3 550, .5G ram, with significant drive IO.
I'm ripping with abcde (a better CD encoder), which pulls the tracks as fast as cdparanoia can get them (as perfectly as possible), and then fires off encoders in the background to process the files. So, a full CD takes around 20-25 minutes to encode, thanks to the 2 processors.
I can't see lame taking that long to encode a file on a 300mhz... It's certainly not going to do it realtime at VBR, but I don't get it taking that long... I'll run a test on my backup server and see what it does...
#35598 - 03/08/2001 18:04 Re: MP3 Ripper [Re: Geoff]
synergy
Ok... Did a quick test on my backup server (P2 300, 128M ram)
Ripped an ~5 minute track, fed it to lame with -m a -q 2 -h -v -V 2 -b 96 -k as the options...
Encoding at .6599x realtime... so, about 8 minutes.
This is with the most recent version of lame, on a Debian linux box.
Gotta say something is up with your setup...
#35599 - 03/08/2001 18:50 Re: MP3 Ripper [Re: synergy]
andygjones
i can do direct CD to mp3 rips at 8-9x. am using audiograbber and lame set to 192 High Quality. set on normal quality i get about 13x
Machine is 1.2GHz Athlon, 512mb, Teac 32x SCSI CD-Rom
RioCar 40GB RGB - can never decide
#35600 - 03/08/2001 18:59 Re: MP3 Ripper [Re: andygjones]
rockstar
almost my exact setup, i have a 1.3 with more ram, and i am using audio catalyst as it came packaged. i get 9x-10x usually(cd in good shape)
