#329785 - 04/02/2010 02:50 USB cooling fan?
Is there such a thing as a small (~3"--5") fan that runs off a USB port? I need a small low-volume, low-speed fan to stir the air around my external dock to keep my 1 TB backup drive temperatures in check. Plugging the fan into a USB port would be simplest, but if necessary I can run it off 110v.
Recommendations?
#329786 - 04/02/2010 03:42 Re: USB cooling fan? [Re: tanstaafl.]
Sure. There's a ton of them that come in USB laptop cooling pads. You could pull one out.
If I wasn't lazy, I'd google one for ya.
#329789 - 04/02/2010 08:20 Re: USB cooling fan? [Re: tanstaafl.]
There are also USB disk drive enclosures which come with a built-in cooling fan. Those vertical dock thingys are cute, though.
#329793 - 04/02/2010 11:24 Re: USB cooling fan? [Re: tfabris]
Aren't those docks only intended to be used temporarily? I don't think you're supposed to leave the drive in there for extended periods, which lessens the need for cooling.
I've been meaning to get one of those docks. At last count I have 12 hard disks lying around.
#329798 - 04/02/2010 12:21 Re: USB cooling fan? [Re: tanstaafl.]
Deal Extreme SKU #7153 (sold out).
And many similar items.
This variable-speed model looks particularly good.
Edited by mlord (04/02/2010 12:31)
#329799 - 04/02/2010 12:27 Re: USB cooling fan? [Re: mlord]
Mmmm... good idea that (fan for vertical drive dock). I think I'll rummage through the fan pile here, and see if any of them can run from 5VDC. Add a small small inline resistor (to drop the fan speed/noise), and a block of wood (to adjust the height), and it ought to work well.
#329804 - 04/02/2010 13:58 Re: USB cooling fan? [Re: Dignan]
It is used only intermittently -- for a few hours every ten days or so when I do a full system backup. It heats up quite rapidly, in half an hour I receive notification that it is approaching the temperature limits (Acive@ Hard Disk monitor program.) The dock is parked in a corner of my computer hutch in stagnant air, even a little bit of air circulation will keep it cool.
#329805 - 04/02/2010 14:15 Re: USB cooling fan? [Re: tanstaafl.]
matthew_k
You shouldn't need to rip anything apart, I used one of these successfully when I needed to run a computer in a cabinet:
Thermaltake Mobile Fan II External USB Cooling Fan
As far as I know the one I installed is still going strong.
#329807 - 04/02/2010 14:24 Re: USB cooling fan? [Re: matthew_k]
Very cool (no pun intended) product! I had no idea such a thing existed.
Though technically, isn't the little dongle all you really need? It looks to have a standard fan connector. Of course, it's nice that the fan its self has that nice little wire enclosure...
#329816 - 04/02/2010 16:24 Re: USB cooling fan? [Re: tanstaafl.]
A quick GIS for 'usb fan' got loads of cute fans for personal use.
