#310792 - 31/05/2008 19:55 emplode problem
K.A.W
I get a erro message saying that emplode has a problem and need to be closed when I connect.This happend when i was uploading tracks.Its running 2.0 13 beta.What need to be done to solve this ?
#310814 - 01/06/2008 14:01 Re: emplode problem [Re: K.A.W]
chrispitude
Loc: Saylorsburg, PA
So you're saying the emplode application itself crashed? Have you tried jEmplode instead?
http://www.jempeg.org/
- Chris
1995 BMW M3 - 250GB RioCar
#310815 - 01/06/2008 14:09 Re: emplode problem [Re: K.A.W]
Upgrade to v2.01 and emplode-2.00 for starters.
If the problem then persists, manually delete/rebuild the database files using instructions from the Empeg FAQ (link at top of this page).
#310816 - 01/06/2008 14:21 Re: emplode problem [Re: mlord]
K.A.W
With jemplode i get:
There isn't a file with FID 2 on this device.
Unable to synchronize with the current device. Failed to synchronize with device. FSCK found an serious problem (check logs for explanation.
