#302046 - 11/09/2007 10:17
Can't upload or change config...
Loc: Isle of Wight, UK
Hi Guys
Bit of a bizzare one this (for me anyway, not had this problem before).
Went to upload a new album to the 'Peg yesterday evening so I could jive on the way to work. Popped the Empeg into my ML dock as usual and fired up Emplode. So far, so hoopy. Dragged & dropped the folder containing the files to my playlist structure in Emplode and also made a slight config change (the shutdown from standby timer). Hit 'Synch' and waited.
The player rebooted (which I thought was odd) and Emplode waited for it, then skipped through the rest of it's checklist, inlcuding the uploading tunes entry, lightning fast.
When the 'ta-da' had chimed, I checked my new playlist entry and it wasn't there. Neither was my config change. Most odd I thought.
Brief recent software history: Been running Version 2 final with the most recent Hijack. Upgraded to A11 for a short time (made the database fixes) and found it it unstable (crashed now and again), so reverted back to 2.00 final. I did the database fix again after downgrading and the machine is running normally apart from the above problem.
Any clue guys?
Steve
#302047 - 11/09/2007 11:32
Re: Can't upload or change config...
[Re: Major_Sarcasm]
Quote: .. The player rebooted (which I thought was odd) and Emplode waited for it, then skipped through the rest of it's checklist, inlcuding the uploading tunes entry, lightning fast.
Any clue guys?
Sounds like what almost always happens here whenever I use Emplode to tweak my player's stuff. Which is why I procrastinate like mad about touching the damn thing.
#302048 - 11/09/2007 14:27
[Re: Major_Sarcasm]
You could try jEmplode - I very occasionally get oddness (usually seems connected to network loading) with emplode, but jEmplode seems to work every time - at least on v2 final. On 3alpha11 I usually need an emplode sync after jemplode just to make it all work.
#302049 - 11/09/2007 14:43
[Re: Major_Sarcasm]
Major, I think you may have run into this problem. I think you may need to FSCK the thing. I had something similar happen when I tried one of the alphas and then reverted back to 2.0, just like you did. My player works perfectly fine now, and I do all my updates with Emplode 2.0 final. One thing to check is make sure you're using emplode 2.00 final and not emplode 2.10.
#302050 - 11/09/2007 14:56
Thanks Tony, I'll Hyperterm into it tomorrow when I've finished my block of nights and report back. Thanks for your help.
Steve
#302051 - 11/09/2007 14:58
[Re: frog51]
Thanks Frog, but I've never got on with jEmplode I'm afraid and this is the 1st time I've ever really had a problem with Emplode. I'll try the FSCK tomorrow and see how I get on. Cheers for your input though.
Steve
#302052 - 12/09/2007 12:24
Well, no joy with that seemingly. Still have the same problem. Couple of issues I had whilst doing the procedure that you linked, Tony. When I typed the lines 'umount /dev/hda4' & 'umount /dev/hdc4' I got a bash error saying 'unmount no such file or directory'. Also, after typing 'fsck -fay /dev/hda4' and waiting a while, the player got to the 5th check and then even after 10 hours, I still couldn't type anything further in Hyperterminal. Had to reboot the player and shutdown/restart hyperterminal before continuing. Perhaps I should try the whole procedure again...
I logged the player booting and an attempt to upload some MP3s. I think the error is when I click synchronise, the player is rebooting rather than writing files or a new config. I can't even edit the config.ini file. Emplode states 'checking media' but the player is rebooting... log follows:
******************************** empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v477 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Jul 13 14:42:45 EDT 2007
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102438) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb84
Tuner: loopback=1, ID=-1
show_message("Hijack v477 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005980).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: HTS548040M9AT00, ATA DISK drive
hdb: IBM-DJSA-210, ATA DISK drive
hda: HTS548040M9AT00, 38154MB w/7877kB Cache, CHS=4864/255/63
hdb: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:86
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Remounting first music partition read-only Remounting second music partition read-only Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: GMT
/drive0/var/ttsclock: getopts: `Option ': not a valid identifier Saved AC volume was 33 Volume=33 emptris v1.3 starting... hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
empacman running as pid 23 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 Adding Swap: 16028k swap-space (priority -1)
disk.cpp : 876:Couldn't cleanly unmount drive 0 (c0041010) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
Restored terminal settings Remounting first music partition read-only Remounting second music partition read-only Restart code received Starting player Timezone: GMT
/drive0/var/ttsclock: getopts: `Option ': not a valid identifier Saved AC volume was 33 Volume=33 emptris v1.3 starting... empacman running as pid 52 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 ******************************
Steve
#302053 - 12/09/2007 12:58
[Re: Major_Sarcasm]
OK, tried again and Hyperterminal didn't lock up this time (what a piece of crap HT is, must find an alternative).
******************************** q Restored terminal settings Remounting first music partition read-only Remounting second music partition read-only Player exited normally: 0 Switching to shell-player loop Starting bash. empeg:/empeg/bin# ro empeg:/empeg/bin# unmount /dev/hda4 bash: unmount: command not found empeg:/empeg/bin# yn unmount /dev/hdc4 bash: unmount: command not found empeg:/empeg/bin# swapon /swapfile Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay / Parallelizing fsck version 1.19 (13-Jul-2000) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information /dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks empeg:/empeg/bin# fsck -fay /dev/hda4 Parallelizing fsck version 1.19 (13-Jul-2000) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information /dev/hda4: 9289/304448 files (28.9% non-contiguous), 23484275/38965657 blocks empeg:/empeg/bin# fsck -fay /dev/hdc4 Parallelizing fsck version 1.19 (13-Jul-2000) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information /dev/hdc4: 112/76096 files (3.6% non-contiguous), 22219/9737280 blocks empeg:/empeg/bin# swapoff /swapfile empeg:/empeg/bin# sync empeg:/empeg/bin# ****************************************
Just tried uploading a tune and it's doing the same thing. Bah. Back to the drawing board. Should I try a reinstallation of Ver 2.0 final player software d'ya think?
Edit: This was the log for the boot immediately after the procedure above...
empeg state support initialised 0089/88c1 (save to d0005a80).
Partition check:
empacman running as pid 23 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 ***********************************
Edited by Major_Sarcasm (12/09/2007 13:00)
Steve
#302054 - 12/09/2007 13:23
[Re: Major_Sarcasm]
Just to simplify things, and free up some RAM, try nuking emptris and pacman from the startup sequence.
#302055 - 12/09/2007 13:29
I can't edit my config.ini. No configuration changes stick, either in config.ini or in the player config. Can I manually edit config.ini via hyperterminal?
Steve
#302056 - 12/09/2007 14:31
[Re: Major_Sarcasm]
Quote: I can't edit my config.ini.
Sure you can. Just because there's no MS-Windows GUI that works doesn't mean it cannot be done easily!
FTP to your player (it has Hijack installed, so it has FTP capability) and GET the config.ini file (copy it to your PC). Edit the file on your PC, and then FTP again to PUT the edited copy onto the player.
With a command-line FTP client, the commands look something like this:
ftp you.players.ip.addr cd /empeg/var get config.ini quit
ftp your.players.ip.addr cd /empeg/var site rw put config.ini site ro site reboot quit
#302057 - 12/09/2007 15:10
[Re: Major_Sarcasm]
Quote: When I typed the lines 'umount /dev/hda4' & 'umount /dev/hdc4' I got a bash error saying 'unmount no such file or directory'.
Admittedly, it was in the general text and not bold alongside those lines (I'm going to edit it so that it is) the FAQ did say: If you have only one hard disk, you may omit the lines that include /dev/hdc4.
However, you shouldn't have got those errors for hda4.
I think your problem all along may have been TTSClock, Emptris, and Pacman, some or all of which are running from the music partition (Drive0). Those programs are locking that partition and making it so it can't be read-write for the synchronization procedure. Remove them, do the necessary steps to FSCK, rebuild your databases, and you should be OK.
#302058 - 12/09/2007 15:14
Quote: get config.ini ... put config.ini
Reminder: If you are editing config.ini on your PC, you must not do it with Notepad. Notepad will insert Windows-Specific CR/LF pairs into the file whereas a linux file just expects an LF. You must use a Unix-Aware editor that will not mangle the linefeeds when re-saving, such as UltraEdit or EditPad Classic or some such.
#302059 - 12/09/2007 15:35
Quote: Admittedly, it was in the general text and not bold alongside those lines (I'm going to edit it so that it is) the FAQ did say: If you have only one hard disk, you may omit the lines that include /dev/hdc4.
I do have two hard drives.
One question: Why would the programs that I have running (emptris, et al) be affecting the player now when I've had them installed/running for well over a year with no prior problems?
I've done the alpha and back to final before too, with these things in place.
Steve
#302060 - 12/09/2007 15:41
[Re: Major_Sarcasm]
OK, config.ini looked like this:
[synchronise] seq_num=271 [wendy] flag_amount=0 [custom] wendy= [searches] amount=0 [VisualFavourites_AM] 1=InfoTex OTT count=1 [VisualFavourites_AUX] count=0 [VisualFavourites_DSP] 15=Flancedoor 14=InfoTex Twist 13=InfoTex OTT 12=LogDiff 128 11=SpectroLog 128 10=Spectroflip 128 9=Spectrometer 128 8=Anna Vu 7=Oscilloscope LR 6=Oscilloscope 5=Sound Samosa 4=Rorschach 3=SoundFlag 2=Shapescape 1=Scope count=15 [VisualFavourites_FM] 1=InfoTex OTT count=1 [Options] Name=Digit [User Info] Email=******* Phone=******* Name=****** [Network] Gateway=192.168.1.100 Netmask=255.255.255.0 IPAddress=192.168.1.104 DHCP=0 [sense] muteaction=0 mute=-1 [power] off_timeout=5000 [display] squash_visuals=1 play_count=1 visual_names=1 caching=0 [kenwood] disabled=0 [menu] quit=1 sort_playlist=1 [shuffle] deduplicate=0 [hush] hushpercent=80 [volumecap] enabled=0 [ramp] disabled=0 [controls] stalk_side=none [tuner] region=europe [aux] source= title= artist= [startup] ReserveCache=0 [hijack] buttonled_dim=5 buttonled_off=5 disable_bassboost_FM=1 ;@AC ;@EXEC /drive0/var/ttsclock ;@AC ;@EXEC /drive0/var/emptris ;@AC ;@EXEC /drive0/var/empacman [ir_translate] One.L=Clock Four.L=HijackMenu
And now looks like this:
[synchronise] seq_num=271 [wendy] flag_amount=0 [custom] wendy= [searches] amount=0 [VisualFavourites_AM] 1=InfoTex OTT count=1 [VisualFavourites_AUX] count=0 [VisualFavourites_DSP] 15=Flancedoor 14=InfoTex Twist 13=InfoTex OTT 12=LogDiff 128 11=SpectroLog 128 10=Spectroflip 128 9=Spectrometer 128 8=Anna Vu 7=Oscilloscope LR 6=Oscilloscope 5=Sound Samosa 4=Rorschach 3=SoundFlag 2=Shapescape 1=Scope count=15 [VisualFavourites_FM] 1=InfoTex OTT count=1 [Options] Name=Digit [User Info] Email=******** Phone=********* Name=******* [Network] Gateway=192.168.1.100 Netmask=255.255.255.0 IPAddress=192.168.1.104 DHCP=0 [sense] muteaction=0 mute=-1 [power] off_timeout=5000 [display] squash_visuals=1 play_count=1 visual_names=1 caching=0 [kenwood] disabled=0 [menu] quit=1 sort_playlist=1 [shuffle] deduplicate=0 [hush] hushpercent=80 [volumecap] enabled=0 [ramp] disabled=0 [controls] stalk_side=none [tuner] region=europe [aux] source= title= artist= [startup] ReserveCache=0 [hijack] buttonled_dim=5 buttonled_off=5 disable_bassboost_FM=1 [ir_translate] One.L=Clock Four.L=HijackMenu
I'll try the FSCK again now.
Steve
#302061 - 12/09/2007 15:55
[Re: Major_Sarcasm]
OK, I think I've been a grade-A cock.
I remember whilst I had A11 installed I thought that my reserve cache settings might me causing visual stuttering on track changes, so I reduced it to zero (see above). Of course this has had a knock-on effect to the memory available for the player. I didn't re-do the FSCK, I just tried uploading some choons and all seems well.
I'll re-edit the config.ini to inlclude the lines I had before, but I'll set a reserve cache again too.
All should be tickety-boo after that.
I extend my heart-felt gratitude, as always, for the excellent help I receive on this board.
Just out of interest, why do I keep getting the error message about 'unmount'? Any clues? Obviously the file doesn't exist on my player, just wondering why.
Steve
#302062 - 12/09/2007 15:55
[Re: Major_Sarcasm]
Quote: OK, config.ini looked like this: ...
Cool. So you simply nuked the three EXEC lines:
@@ -79,9 +79,6 @@ buttonled_dim=5 buttonled_off=5 disable_bassboost_FM=1 -;@AC ;@EXEC /drive0/var/ttsclock -;@AC ;@EXEC /drive0/var/emptris -;@AC ;@EXEC /drive0/var/empacman [ir_translate] One.L=Clock Four.L=HijackMenu
Good luck!
#302063 - 12/09/2007 15:58
Good luck!
One possible tip for people with a similar problem (extra programs running off of the music partition and therefore preventing sync from working), might be to prefix those lines with ";@AC ;@HOME ", instead of just ";@AC ".
That way you can enable/disable them on the fly (almost) using the HOME/WORK location selector on the Hijack menu.
#302064 - 12/09/2007 16:06
[Re: Major_Sarcasm]
Quote: All should be tickety-boo after that.
All is now indeed tickety-boo. So, it was the reserve cache settings all along. D'oh.
Steve
#302065 - 12/09/2007 16:10
[Re: Major_Sarcasm]
??? You didn't change any ReserveCache setting. EDIT: oh, I see we posted simultaneously earlier on. But I still think..
It was the extra programs that were running, preventing the music partition from being remounted R/W for the sync.
Edited by mlord (12/09/2007 16:11)
#302066 - 12/09/2007 16:13
[Re: Major_Sarcasm]
Because the correct spelling is umount, not unmount
#302067 - 12/09/2007 16:27
Quote: It was the extra programs that were running, preventing the music partition from being remounted R/W for the sync.
Although, I've put my config.ini back to the way it was, but specified a reserve cache of 15 and now it all works again.
As for the umount/unmount... I'm a berk.
Steve
#302068 - 12/09/2007 18:26
Quote: Just out of interest, why do I keep getting the error message about 'unmount'? Any clues? Obviously the file doesn't exist on my player, just wondering why.
Odd. Earlier in the thread, he said umount (i.e., indicating he'd done it correctly), I checked that first.
I'll clarify that in the FAQ.
#302069 - 12/09/2007 19:02
Quote: empeg:/empeg/bin# ro empeg:/empeg/bin# unmount /dev/hda4 bash: unmount: command not found empeg:/empeg/bin# yn unmount /dev/hdc4 bash: unmount: command not found empeg:/empeg/bin# swapon /swapfile
No, I definitely cocked it up.
Steve
#302070 - 12/09/2007 21:33
[Re: Major_Sarcasm]
Heh. You typed it correctly when asking the question about why the command didn't work (it was the first thing I looked for, I even quoted it back in one of my messages), you just didn't type it correctly when actually executing the commands. I missed that bit.  (And looking even closer, I see that you told us the error message said unmount. I missed that bit, too. I only looked closely at the bit where you initially said what commands you had typed.) Well, I've updated the FAQ entry anyway, so hopefully folks in the future won't make the same mistake. You aren't the only person to have done that.
#302071 - 13/09/2007 00:39
Quote: You aren't the only person to have done that.
I believe the first one to do that was the bloke who left out the n in the first place when naming the original command!
#302072 - 13/09/2007 06:48
I always thought truncated Unix command names was silly, right upto the point that I first had to admin a machine on the other side of the Atlantic via a 9600 modem link
#302074 - 13/09/2007 13:11
[Re: julf]
#302075 - 13/09/2007 17:03
[Re: JBjorgen]
Quote: Or even RFC 1149.
Now that brings back a memory of one of the high points of the 2005 empeg meet in Amersfoort.
Rob V. was talking about an adventure that he and Patrick had had, involving a pair of walkie-talkies relayed through a model aircraft, enabling them to talk without being in line-of-sight, Rob on one side of a hill, Patrick on the other. Patrick said something about using it to transmit data, whereupon Rob started saying "one one oh one oh oh one one oh oh..." to which Patrick replied, "Rob, you've just invented IP over Voice."
That story got applause from the attendees.
