#302046 - 11/09/2007 10:17 Can't upload or change config...
Major_Sarcasm
Loc: Isle of Wight, UK
Hi Guys
Bit of a bizzare one this (for me anyway, not had this problem before).
Went to upload a new album to the 'Peg yesterday evening so I could jive on the way to work. Popped the Empeg into my ML dock as usual and fired up Emplode. So far, so hoopy. Dragged & dropped the folder containing the files to my playlist structure in Emplode and also made a slight config change (the shutdown from standby timer). Hit 'Synch' and waited.
The player rebooted (which I thought was odd) and Emplode waited for it, then skipped through the rest of it's checklist, inlcuding the uploading tunes entry, lightning fast.
When the 'ta-da' had chimed, I checked my new playlist entry and it wasn't there. Neither was my config change. Most odd I thought.
Brief recent software history: Been running Version 2 final with the most recent Hijack. Upgraded to A11 for a short time (made the database fixes) and found it it unstable (crashed now and again), so reverted back to 2.00 final. I did the database fix again after downgrading and the machine is running normally apart from the above problem.
Any clue guys?
Steve
#302047 - 11/09/2007 11:32 Re: Can't upload or change config... [Re: Major_Sarcasm]
Any clue guys?
Sounds like what almost always happens here whenever I use Emplode to tweak my player's stuff. Which is why I procrastinate like mad about touching the damn thing.
#302048 - 11/09/2007 14:27 Re: Can't upload or change config... [Re: Major_Sarcasm]
You could try jEmplode - I very occasionally get oddness (usually seems connected to network loading) with emplode, but jEmplode seems to work every time - at least on v2 final. On 3alpha11 I usually need an emplode sync after jemplode just to make it all work.
#302049 - 11/09/2007 14:43 Re: Can't upload or change config... [Re: Major_Sarcasm]
Major, I think you may have run into this problem. I think you may need to FSCK the thing.
I had something similar happen when I tried one of the alphas and then reverted back to 2.0, just like you did. My player works perfectly fine now, and I do all my updates with Emplode 2.0 final.
One thing to check is make sure you're using emplode 2.00 final and not emplode 2.10.
#302050 - 11/09/2007 14:56 Re: Can't upload or change config... [Re: tfabris]
Major_Sarcasm
Thanks Tony, I'll Hyperterm into it tomorrow when I've finished my block of nights and report back. Thanks for your help.
Steve
#302051 - 11/09/2007 14:58 Re: Can't upload or change config... [Re: frog51]
Major_Sarcasm
Thanks Frog, but I've never got on with jEmplode I'm afraid and this is the 1st time I've ever really had a problem with Emplode. I'll try the FSCK tomorrow and see how I get on. Cheers for your input though.
Steve
#302052 - 12/09/2007 12:24 Re: Can't upload or change config... [Re: tfabris]
Major_Sarcasm
Well, no joy with that seemingly. Still have the same problem. Couple of issues I had whilst doing the procedure that you linked, Tony. When I typed the lines 'umount /dev/hda4' & 'umount /dev/hdc4' I got a bash error saying 'unmount no such file or directory'. Also, after typing 'fsck -fay /dev/hda4' and waiting a while, the player got to the 5th check and then even after 10 hours, I still couldn't type anything further in Hyperterminal. Had to reboot the player and shutdown/restart hyperterminal before continuing. Perhaps I should try the whole procedure again...
I logged the player booting and an attempt to upload some MP3s. I think the error is when I click synchronise, the player is rebooting rather than writing files or a new config. I can't even edit the config.ini file. Emplode states 'checking media' but the player is rebooting... log follows:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v477 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Jul 13 14:42:45 EDT 2007
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102438) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb84
Tuner: loopback=1, ID=-1
show_message("Hijack v477 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005980).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: HTS548040M9AT00, ATA DISK drive
hdb: IBM-DJSA-210, ATA DISK drive
hda: HTS548040M9AT00, 38154MB w/7877kB Cache, CHS=4864/255/63
hdb: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:86
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: GMT
/drive0/var/ttsclock: getopts: `Option
': not a valid identifier
Saved AC volume was 33
Volume=33
emptris v1.3 starting...
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
empacman running as pid 23
Vcb: 0x4086d000
Adding Swap: 16028k swap-space (priority -1)
disk.cpp : 876:Couldn't cleanly unmount drive 0 (c0041010)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
Restored terminal settings
Restart code received
Starting player
Timezone: GMT
Volume=33
empacman running as pid 52
Vcb: 0x4086d000
Steve
#302053 - 12/09/2007 12:58 Re: Can't upload or change config... [Re: Major_Sarcasm]
Major_Sarcasm
OK, tried again and Hyperterminal didn't lock up this time (what a piece of crap HT is, must find an alternative).
q
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# unmount /dev/hda4
bash: unmount: command not found
empeg:/empeg/bin# yn  unmount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
/dev/hda4: 9289/304448 files (28.9% non-contiguous), 23484275/38965657 blocks
empeg:/empeg/bin# fsck -fay /dev/hdc4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
/dev/hdc4: 112/76096 files (3.6% non-contiguous), 22219/9737280 blocks
empeg:/empeg/bin# swapoff /swapfile
empeg:/empeg/bin# sync
empeg:/empeg/bin#
Just tried uploading a tune and it's doing the same thing. Bah. Back to the drawing board. Should I try a reinstallation of Ver 2.0 final player software d'ya think?
Edit: This was the log for the boot immediately after the procedure above...
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0005a80).
Partition check:
Mounting proc
Starting player
Timezone: GMT
Volume=33
Vcb: 0x4086d000
Edited by Major_Sarcasm (12/09/2007 13:00)
Steve
#302054 - 12/09/2007 13:23 Re: Can't upload or change config... [Re: Major_Sarcasm]
Just to simplify things, and free up some RAM, try nuking emptris and pacman from the startup sequence.
#302055 - 12/09/2007 13:29 Re: Can't upload or change config... [Re: mlord]
Major_Sarcasm
I can't edit my config.ini. No configuration changes stick, either in config.ini or in the player config. Can I manually edit config.ini via hyperterminal?
Steve
#302056 - 12/09/2007 14:31 Re: Can't upload or change config... [Re: Major_Sarcasm]
Sure you can. Just because there's no MS-Windows GUI that works doesn't mean it cannot be done easily!
FTP to your player (it has Hijack installed, so it has FTP capability) and GET the config.ini file (copy it to your PC). Edit the file on your PC, and then FTP again to PUT the edited copy onto the player.
With a command-line FTP client, the commands look something like this:
ftp you.players.ip.addr
cd /empeg/var
get config.ini
quit
ftp your.players.ip.addr
cd /empeg/var
site rw
put config.ini
site ro
site reboot
quit
#302057 - 12/09/2007 15:10 Re: Can't upload or change config... [Re: Major_Sarcasm]
Admittedly, it was in the general text and not bold alongside those lines (I'm going to edit it so that it is) the FAQ did say: If you have only one hard disk, you may omit the lines that include /dev/hdc4.
However, you shouldn't have got those errors for hda4.
I think your problem all along may have been TTSClock, Emptris, and Pacman, some or all of which are running from the music partition (Drive0). Those programs are locking that partition and making it so it can't be read-write for the synchronization procedure. Remove them, do the necessary steps to FSCK, rebuild your databases, and you should be OK.
#302058 - 12/09/2007 15:14 Re: Can't upload or change config... [Re: mlord]
get config.ini
put config.ini
Reminder: If you are editing config.ini on your PC, you must not do it with Notepad. Notepad will insert Windows-Specific CR/LF pairs into the file whereas a linux file just expects an LF. You must use a Unix-Aware editor that will not mangle the linefeeds when re-saving, such as UltraEdit or EditPad Classic or some such.
#302059 - 12/09/2007 15:35 Re: Can't upload or change config... [Re: tfabris]
Major_Sarcasm
I do have two hard drives.
One question: Why would the programs that I have running (emptris, et al) be affecting the player now when I've had them installed/running for well over a year with no prior problems?
I've done the alpha and back to final before too, with these things in place.
Steve
#302060 - 12/09/2007 15:41 Re: Can't upload or change config... [Re: Major_Sarcasm]
Major_Sarcasm
OK, config.ini looked like this:
[synchronise]
seq_num=271
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
1=InfoTex OTT
count=1
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
15=Flancedoor
14=InfoTex Twist
13=InfoTex OTT
12=LogDiff 128
11=SpectroLog 128
10=Spectroflip 128
9=Spectrometer 128
8=Anna Vu
7=Oscilloscope LR
6=Oscilloscope
5=Sound Samosa
4=Rorschach
3=SoundFlag
2=Shapescape
1=Scope
count=15
[VisualFavourites_FM]
1=InfoTex OTT
count=1
[Options]
Name=Digit
[User Info]
Email=*******
Phone=*******
Name=******
[Network]
Gateway=192.168.1.100
Netmask=255.255.255.0
IPAddress=192.168.1.104
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=5000
[display]
squash_visuals=1
play_count=1
visual_names=1
caching=0
[kenwood]
disabled=0
[menu]
quit=1
sort_playlist=1
[shuffle]
deduplicate=0
[hush]
hushpercent=80
[volumecap]
enabled=0
[ramp]
disabled=0
[controls]
stalk_side=none
[tuner]
region=europe
[aux]
source=
title=
artist=
[startup]
ReserveCache=0
[hijack]
buttonled_dim=5
buttonled_off=5
disable_bassboost_FM=1
;@AC ;@EXEC /drive0/var/ttsclock
;@AC ;@EXEC /drive0/var/emptris
;@AC ;@EXEC /drive0/var/empacman
[ir_translate]
One.L=Clock
Four.L=HijackMenu
And now looks like this:
[synchronise]
seq_num=271
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
1=InfoTex OTT
count=1
count=0
15=Flancedoor
14=InfoTex Twist
13=InfoTex OTT
12=LogDiff 128
11=SpectroLog 128
10=Spectroflip 128
9=Spectrometer 128
8=Anna Vu
7=Oscilloscope LR
6=Oscilloscope
5=Sound Samosa
4=Rorschach
3=SoundFlag
2=Shapescape
1=Scope
count=15
1=InfoTex OTT
count=1
[Options]
Name=Digit
[User Info]
Email=********
Phone=*********
Name=*******
[Network]
DHCP=0
[sense]
muteaction=0
mute=-1
[power]
off_timeout=5000
[display]
squash_visuals=1
play_count=1
visual_names=1
caching=0
[kenwood]
disabled=0
[menu]
quit=1
sort_playlist=1
[shuffle]
deduplicate=0
[hush]
hushpercent=80
[volumecap]
enabled=0
[ramp]
disabled=0
[controls]
stalk_side=none
[tuner]
region=europe
[aux]
source=
title=
artist=
[startup]
ReserveCache=0
[hijack]
buttonled_dim=5
buttonled_off=5
[ir_translate]
One.L=Clock
Four.L=HijackMenu
I'll try the FSCK again now.
Steve
#302061 - 12/09/2007 15:55 Re: Can't upload or change config... [Re: Major_Sarcasm]
Major_Sarcasm
OK, I think I've been a grade-A cock.
I remember whilst I had A11 installed I thought that my reserve cache settings might me causing visual stuttering on track changes, so I reduced it to zero (see above). Of course this has had a knock-on effect to the memory available for the player. I didn't re-do the FSCK, I just tried uploading some choons and all seems well.
I'll re-edit the config.ini to inlclude the lines I had before, but I'll set a reserve cache again too.
All should be tickety-boo after that.
I extend my heart-felt gratitude, as always, for the excellent help I receive on this board.
Just out of interest, why do I keep getting the error message about 'unmount'? Any clues? Obviously the file doesn't exist on my player, just wondering why.
Steve
#302062 - 12/09/2007 15:55 Re: Can't upload or change config... [Re: Major_Sarcasm]
Cool. So you simply nuked the three EXEC lines:
@@ -79,9 +79,6 @@
buttonled_dim=5
buttonled_off=5
-;@AC ;@EXEC /drive0/var/ttsclock
-;@AC ;@EXEC /drive0/var/emptris
-;@AC ;@EXEC /drive0/var/empacman
[ir_translate]
One.L=Clock
Four.L=HijackMenu
Good luck!
#302063 - 12/09/2007 15:58 Re: Can't upload or change config... [Re: mlord]
@@ -79,9 +79,6 @@
buttonled_dim=5
buttonled_off=5
[ir_translate]
One.L=Clock
Four.L=HijackMenu
Good luck!
One possible tip for people with a similar problem (extra programs running
off of the music partition and therefore preventing sync from working),
might be to prefix those lines with ";@AC ;@HOME ", instead of just ";@AC ".
That way you can enable/disable them on the fly (almost)
using the HOME/WORK location selector on the Hijack menu.
#302064 - 12/09/2007 16:06 Re: Can't upload or change config... [Re: Major_Sarcasm]
Major_Sarcasm
All is now indeed tickety-boo. So, it was the reserve cache settings all along. D'oh.
Steve
#302065 - 12/09/2007 16:10 Re: Can't upload or change config... [Re: Major_Sarcasm]
??? You didn't change any ReserveCache setting.
EDIT: oh, I see we posted simultaneously earlier on.
But I still think..
It was the extra programs that were running, preventing the music
partition from being remounted R/W for the sync.
Edited by mlord (12/09/2007 16:11)
#302066 - 12/09/2007 16:13 Re: Can't upload or change config... [Re: Major_Sarcasm]
Because the correct spelling is umount, not unmount
#302067 - 12/09/2007 16:27 Re: Can't upload or change config... [Re: mlord]
Major_Sarcasm
It was the extra programs that were running, preventing the music partition from being remounted R/W for the sync.
Although, I've put my config.ini back to the way it was, but specified a reserve cache of 15 and now it all works again.
As for the umount/unmount... I'm a berk.
Steve
#302068 - 12/09/2007 18:26 Re: Can't upload or change config... [Re: mlord]
Odd. Earlier in the thread, he said umount (i.e., indicating he'd done it correctly), I checked that first.
I'll clarify that in the FAQ.
#302069 - 12/09/2007 19:02 Re: Can't upload or change config... [Re: tfabris]
Major_Sarcasm
No, I definitely cocked it up.
Steve
#302070 - 12/09/2007 21:33 Re: Can't upload or change config... [Re: Major_Sarcasm]
Heh. You typed it correctly when asking the question about why the command didn't work (it was the first thing I looked for, I even quoted it back in one of my messages), you just didn't type it correctly when actually executing the commands. I missed that bit.
(And looking even closer, I see that you told us the error message said unmount. I missed that bit, too. I only looked closely at the bit where you initially said what commands you had typed.)
Well, I've updated the FAQ entry anyway, so hopefully folks in the future won't make the same mistake. You aren't the only person to have done that.
#302071 - 13/09/2007 00:39 Re: Can't upload or change config... [Re: tfabris]
I believe the first one to do that was the bloke who left out the n in the first place when naming the original command!
#302072 - 13/09/2007 06:48 Re: Can't upload or change config... [Re: mlord]
I always thought truncated Unix command names was silly, right upto the point that I first had to admin a machine on the other side of the Atlantic via a 9600 modem link
#302073 - 13/09/2007 11:09 Re: Can't upload or change config... [Re: andy]
julf
And you haven't tried it on a 110 baud teletype...
#302074 - 13/09/2007 13:11 Re: Can't upload or change config... [Re: julf]
Or even RFC 1149.
#302075 - 13/09/2007 17:03 Re: Can't upload or change config... [Re: JBjorgen]
Or even RFC 1149.
Now that brings back a memory of one of the high points of the 2005 empeg meet in Amersfoort.
Rob V. was talking about an adventure that he and Patrick had had, involving a pair of walkie-talkies relayed through a model aircraft, enabling them to talk without being in line-of-sight, Rob on one side of a hill, Patrick on the other. Patrick said something about using it to transmit data, whereupon Rob started saying "one one oh one oh oh one one oh oh..." to which Patrick replied, "Rob, you've just invented IP over Voice."
That story got applause from the attendees.
