#29644 - 18/04/2001 08:42 Display Server
Sheetzam
Loc: Annandale, VA
Any chance someone can post a FAQ about what Display Server actually does, where to find it, and how to install it? It's getting quite difficult to run that information down at this point.
#29645 - 18/04/2001 08:54 Re: Display Server [Re: Sheetzam]
fvgestel
Loc: Netherlands
Displayserver is a web-server for the empeg. It's primary goal was to show the empeg's display in a java-applet, hence it's name. Version 1.1 also has functions to download MP3's from your empeg and let it act as a pseudo shoutcast-server. It can be obtained from http://empeg.dyndns.org/empeg under displayserver1.1
There isn't a FAQ right now, only a technical description of how to install and run it. As 2.0 sees daylight, I will try to make some fancy HTML-page describing it's functions and various other stuff. I just downloaded HTML-KIT; boy, that's a great HTML-editor...
version 2.0 is a rewrite from 1.1 with some extra functionality :
- empeg acting as filetaxi
- customizible web-interface
- custimizible java-applet
- ability to install user CGI-scripts
- backup your empeg
- web-based text-editor for your empeg
- some stuff which isn't tested yet...
Frank van Gestel
Edited by fvgestel on 18/04/01 08:18 PM.
Frank van Gestel
#29646 - 18/04/2001 10:50 Re: Display Server [Re: fvgestel]
SE_Sport_Driver
sheetman - I was just doing a search for the last 20 minutes or so looking for the same info. I keep hearing things about it - but never any detailed info or where to even get it! :) A FAQ on this, or a link from the developer site would be great.
32GB (JUST UPGRADED!) Mk. II BLUE
Detroit, MI USA
www.PfeifferBeer.com
#29647 - 18/04/2001 10:53 Re: Display Server [Re: fvgestel]
Dearing
Loc: Florida
I know you get asked this often, but: Might there be USB-support?
_~= Dearing =~_
_~= Dearing =~_
#29648 - 18/04/2001 10:54 Re: Display Server [Re: SE_Sport_Driver]
SE_Sport_Driver
Frank, Again I'd like to say (and I've said it in several other posts) that you are amazing for having developed this and you HAVE to set up some way for us to pay you for registering this. It was one of the big reasons I bought my empeg.
Detroit, MI USA
#29649 - 18/04/2001 10:56 Re: Display Server [Re: SE_Sport_Driver]
SE_Sport_Driver
Cant get link to work....
Detroit, MI USA
#29650 - 18/04/2001 11:56 Re: Display Server [Re: SE_Sport_Driver]
Terminator
Loc: Dallas, TX
Try this one:
Sean
80000078
#29651 - 18/04/2001 12:17 Re: Display Server [Re: Terminator]
SE_Sport_Driver
I checked it out. Thanks! It looks like it may be just a bit beyond my scope of knowledge. I assume you install it via hyperterminal? I have the logo editor running, but I may wait until Frank gets his web page going ... But I didn't think I'd be able to add a HD, get the logo editor or connect thru ethernet and I did those.... so...
Detroit, MI USA
#29652 - 18/04/2001 12:34 Re: Display Server [Re: SE_Sport_Driver]
Terminator
Loc: Dallas, TX
This site has a ton of info on linux. It may answer some of your linux questions.
http://www.linux.com/howto/
80000078
#29653 - 18/04/2001 14:07 Re: Display Server [Re: SE_Sport_Driver]
Derek
Loc: NRW, Germany
I've got a good way for you to pay Frank back. Write some really cool piece of software that he will really want to use!
(list 6284, Mk1 S/N 00299 4GB blue [for sale]. Mk2 S/N 080000094 6GB blue)
#29654 - 18/04/2001 14:25 Re: Display Server [Re: Dearing]
fvgestel
Loc: Netherlands
That falls under the "not yet fully tested" category. I've got win32/empeg ip-usb proxy software running, but it can only handle one connection at a time. I'm trying to setup some protocol for multiple concurrent connections, but it has low priority.
Frank van Gestel
Frank van Gestel
#29655 - 19/04/2001 06:38 Re: Display Server [Re: fvgestel]
SE_Sport_Driver
I can't program, but I could help with the web site.... some sites I've done:
http://www.MotorCityImprov.com
http://www.10thGeneration.com
http://www.PfeifferBeer.com
Detroit, MI USA
#29656 - 19/04/2001 11:28 Re: Display Server [Re: SE_Sport_Driver]
SE_Sport_Driver
Could anyone re-rewrite the "readme.txt" file for dummies like me? tfrabis you rock at that kind of stuff.
(Sorry for all the newbie questions... I am checking out that Linux resourse...)
Detroit, MI USA
#29657 - 19/04/2001 12:04 Re: Display Server [Re: SE_Sport_Driver]
fvgestel
Loc: Netherlands
- unzip the install.sh.gz file ( you can use winzip )
I guess this doesn't need any explanation
- copy the install.sh file to the empeg ( use binary mode when using ftp )
connect empeg through the serial cable to your pc
start hyperterminal (start->programs->accessories->communications)
create a new connection and name it "empeg"
when windows comes with a dialog which asks to connect, click cancel
in the menubar choose File->properties
A new window will open with two tabs : "connect to" & "settings"
in the "connect to" tab, choose the serial port to use "COM1/COM2",
then click on configure
set the following values :
Bits per second : 115200
Data bits: 8
Parity: None
Stop bits: 1
Flow control: None
Close the properties window by clicking OK
Close the tabbed window by clicking OK
Now click on the phone icon; a connection will be made
reboot your empeg; boot messages should appear in hyperterminal
after bootup is complete, press "q" a couple of times to get a shell prompt
a shell prompt looks like this:
type the following ( [ENTER] is pressing the ENTER-key) :
# rw[ENTER]
# cd /tmp[ENTER]
In hyperterminal, in the menubar, select "transfer->send file..."
Select the unzipped install.sh file and Zmodem as the transfer protocol
click send to send the file to the empeg
- make the install.sh file executable ( chmod +x install.sh )
type the following in hyperterm :
# chmod +x install.sh[ENTER]
- run the install.sh file on the empeg ( ./install.sh )
# ./install.sh[ENTER]
- answer the questions asked
Just pressing ENTER at the questions will take the default settings
- cd to the install-dir
type:
# cd /usr/local/displayserver[ENTER]
- start display server : ./displayserver
Not really neccesary;if you've setup for automatic startup, you could just pull the plug and reboot your empeg and everything should work fine.
To start immediately :
# ./displayserver[ENTER]
- open your web-browser
No comment
- give URL : http://[ip-address of your empeg]
Assuming you have connected it through ethernet also
- userid : ttt password: ttt
This gets asked the first time you open the web-page
- off you go
Did it regularly, still going off once in a while
Frank van Gestel
Frank van Gestel
#29658 - 19/04/2001 13:08 Re: Display Server [Re: fvgestel]
cd /tmp[ENTER]
Actually, I highly recommend putting install.sh in drive0/var because then it's persistent and you can simply re-run install.sh after a player upgrade.
Unless /tmp is persistent, too, in which case I'll shut up. I don't know much about Linux.
#29659 - 19/04/2001 14:30 Re: Display Server [Re: tfabris]
fvgestel
Loc: Netherlands
You're right, /tmp isn't persistent during upgrades.
Just like selecting install-location I tell people that everything is back to default when applying upgrades. Well, should be, I heard there were some cases where the second drive wasn't mounted correctly at boot time (my fault). AFAIK these issues were solved using an upgrade and multiple reboots.
Can anyone verify that the current version(1.1) hasn't got any bad side-effects?
I don't get any mails about bugs lately, so it should probably be OK
Anyway, I also had it installed in /usr/local/displayserver, where /usr/local is located on /drive0, so an upgrade would only require another init.
Frank van Gestel
Frank van Gestel
#29660 - 20/04/2001 05:00 Re: Display Server [Re: fvgestel]
SE_Sport_Driver
So, if I get this right...
cd /drive0/var INSTEAD OF cd /temp ?
Also, do I need to have the developer image installed instead of the consumer image?
Finally, (sorry guys!) when applying upgrades, do I need to take any special precautions now that I have 2 drives? I wouldn't think so, but just want to check.
Detroit, MI USA
#29661 - 20/04/2001 07:06 Re: Display Server [Re: SE_Sport_Driver]
SE_Sport_Driver
so the only file I need is install_sh.gz? What are "kernal.patch" and "Zimage.gz" for?
I am not able to get the shell prompt, so I am guessing that I need the developer image....
Detroit, MI USA
#29662 - 20/04/2001 09:04 Re: Display Server [Re: SE_Sport_Driver]
SE_Sport_Driver
Just a little heads up to everyone trying this like me... after I unzipped the install_sh.gz file, somehow the extracted file became named "Install.sh" <-- with a capitol letter I. I could transfer the file, but when trying the chmod and ./install commands, it said that there was no file named Install.sh or install.sh. So, I renamed the file on my PC (all lower case) and re-send it. I don't know how to erase the one with the capitol I on the empeg, but I figure it is not taking up too much room.. (intalled it in the tmp dir)...
This thing is just sweet! Now I am going to do a search to figure out how to get the streeming going. (Winamp just says Authorization Required - but doesn't ask for a password...)
Detroit, MI USA
#29663 - 20/04/2001 12:48 Re: Display Server [Re: SE_Sport_Driver]
Dearing
Loc: Florida
rm = delete file
mv = rename OR move a file. (path is optional if file is in local dir)
_~= Dearing =~_
_~= Dearing =~_
#29664 - 20/04/2001 13:00 Re: Display Server [Re: Dearing]
SE_Sport_Driver
Thanks! The old MSDOS days are coming back to me... :)
Detroit, MI USA
#29665 - 23/04/2001 18:38 Re: Display Server [Re: SE_Sport_Driver]
Smoker_Man
Loc: Calgary, CANADA
well, init the displayserver with the ./displayserver -noauth and you can get away with streaming with no authorization, myself, I have edited the config.ini file so that it inits with the -noauth setting. (I cant remember where the config.ini is sorry, Frank or Tony do - ownership of the issue sucessfuly delegated!)
Hope that helps
Smoker_Man
#080000449 MkII - 36Gb Blue
2x160Gb MkII Lighted Buttons 080000449
#29666 - 07/05/2001 02:14 Revenge of the stupid [Re: Smoker_Man]
thinfourth2
okay i got my network running achievment
i got displayserver running another achievment
i got winamp streaming off empeg
i got the IR kernal hack running yet another achievment
what i want to do now is to get the window with display sever to stay on top and any ideas how to get the internet over a simple home netwrk so that girlfriend can play with chat rooms while i do something usefull like read this forum and ask stupid questions using two computers
#29667 - 07/05/2001 05:56 Re: Revenge of the stupid [Re: thinfourth2]
Ezekiel
Loc: NH USA
To get it to stay on top, you can use something like windowblinds (www.stardock.net). Some of the skins support this (such as Win2k_Extended). I don't know if there's a shareware version still available.
Home networking, two basic choices: two ethernet cards in one machine & some software like Wingate (also a firewall software like Blackice Defender) where one NIC is your internal network and one is to your internet connection (assuming DSL or Cable), or alternately a piece of hardware that acts as a hub/switch and firewall. There are a lot of these. A good place to start is to practicallynetworked.com. Either way is not too difficult, but requires some footwork to determine what you need. I don' t think you'll have a hard time, since you've come this far. If you have a dial-up some of these hardware solutions will still work, as they have modems or allow for external modems.
-Zeke
WWFSMD?
#29668 - 07/05/2001 08:52 Re: Revenge of the stupid [Re: Ezekiel]
Don't forget to tell him that recent versions of Windows come with "Internet Connection Sharing" software built-in. It's a pain, though, especially if you've already got your LAN addresses pre-assigned because ICS renumbers everything. Or at least that's the way I recall it working.
#29669 - 07/05/2001 09:52 Re: Revenge of the stupid [Re: tfabris]
thinfourth2
i read the web site discovered ICS software thing ran it and result network stopped working and empeg disappeared off network. No fun what so ever so everything is back where i was before i might not have internet sharing but at least i got the empeg back on the LAN
Thank god microsoft never wrote the software for empeg
#29670 - 07/05/2001 09:58 Re: Revenge of the stupid [Re: thinfourth2]
Yeah, your experiences with ICS are pretty much universal. Since it renumbers everything and completely changes your networking scheme, it tends to screw up existing networks.
It's actually possible to get the Empeg and your old network working properly and co-existing peacefully with ICS, but it takes a bit of know-how and Blood/Sweat/Tears to get it done.
I think that in your case, for simplicity's sake, you're better off getting a hardware router that does the internet connection sharing. Lots of companies make these... Linksys, 3Com, etc. They can either share a phone connection, a DSL connection, or an ISDN connection. Sometimes you can get them with a firewall built-in.
#29671 - 07/05/2001 11:06 Re: Revenge of the stupid [Re: tfabris]
Ezekiel
Loc: NH USA
I'm inclined to agree. I've just gotten the SMC 7004WBR. About $280 for a 3 port Switch, Wireless (Wifi/802.11b), Print server (LPR), & WAN Firewall/NAT. Simple Switch/NAT devices (4 port) can be had for about $150. I had a dual homed machine, but this setup frees up some resources & doesn't bother the Mrs' connection when Descent III crashes my system.
-Zeke
WWFSMD?
#29672 - 07/05/2001 12:29 return of the stupid [Re: Ezekiel]
thinfourth2
looks like i'll have to do a bit of saving and home work as just now i have an modem V90 but i might upgrade to ADSL at some point and also i spent a load of cash on this strange little computer thing that fits into my car and plays music
#29673 - 07/05/2001 13:06 Re: return of the stupid [Re: thinfourth2]
SE_Sport_Driver
Back to Displayserver... Is there any way to get it to stream the root playlist?
Detroit, MI USA
