#290888 - 28/11/2006 20:49 Ethernet troubles...
I do have access to a PC, but it's not that convenient right now. So I haven't tried Emplode (in a long time) nor have I done anything with the serial cable recently.
Running Hijack 413 as I haven't actually connected the player to a computer in ages. The last time was just to use Empeg Menu X in June.
The empeg is connected directly to my router right now and I'm trying to access it from my Powerbook over wifi.
Here's what I can do:
Connect HTTP to see the file structure
Connect HTTP and use the playlist navigation that's part of Hijack
Control the player and download stream files
Download tracks by using Save As in browser
See the player with Jemplode
Here's what I can't do:
Connect via FTP
Connect with Jemplode (it just says "Loading..." pretty much forever - have left it some 20 minutes)
Download more than a few tracks before the player locks out all remote connections (won't refresh over HTTP, etc.)
After the freezing, eventually the player will start responding through the web interface again. This last time it took about 5-10 minutes. During the freeze it's completely unreachable via a browser.
Can anyone suggest any troubleshooting steps that I can use remotely? When I have some time I will connect up through emplode on a PC and also spy any messages over the serial port.
#290889 - 29/11/2006 01:08 Re: Ethernet troubles... [Re: hybrid8]
Connect via FTP
Hijack doesn't support the RFC-compliant "passive" FTP mode that most s/w now defaults to. If your client can do "active" or "PORT" FTP, then tell it to use that mode. The mozilla/firefox family cannot do that, so they just won't work.
Filesystem being checked?
Ugh.
Sounds like bad sectors or bad connection with the hard disk.
Connect using HTTP, and GET /proc/kmsg and post it here.
#290890 - 29/11/2006 03:22 Re: Ethernet troubles... [Re: mlord]
Thanks for the suggestions. I still haven't been able to connect via FTP, even after disabling passive mode. Unfortunately the FTP client I'm using right now doesn't offer any other controls for that (only a single check box for passive mode).
Here's the kmsg:
<4>Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue Aug 17 18:05:30 EDT 2004
<4>Processor: Intel StrongARM-1100 revision 11
<4>Checking for extra DRAM:
<4>c1000000: wrote ffffffff, read e91ba9f0
<4>NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.
<4>empeg-car player (hardware revision 9, serial number 30102542) 16MB DRAM
<4>Command line: mem=16m
<4>Calibrating delay loop... 207.67 BogoMIPS
<4>Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
<4>Dentry hash table entries: 2048 (order 2, 16k)
<4>Buffer cache hash table entries: 16384 (order 4, 64k)
<4>Page cache hash table entries: 4096 (order 2, 16k)
<4>POSIX conformance testing by UNIFIX
<6>Linux NET4.0 for Linux 2.2
<6>Based upon Swansea University Computer Society NET3.039
<6>NET4: Linux TCP/IP 1.0 for NET4.0
<6>IP Protocols: ICMP, UDP, TCP
<4>TCP: Hash tables configured (ehash 16384 bhash 16384)
<6>IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)
<4>Starting kswapd v 1.5
<6>SA1100 serial driver version 4.27 with no serial options enabled
<6>ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART
<6>ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART
<6>ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART
<4>Signature is 67706d65 'empg'
<4>Found custom animation at offset 0x9c378
<4>Tuner: loopback=0, ID=-1
<4>Scheduling custom logo.
<4>empeg display initialised.
<4>empeg dsp audio initialised
<4>empeg dsp mixer initialised
<4>empeg dsp initialised
<4>empeg audio-in initialised, CS4231A revision a0
<4>empeg remote control/panel button initialised.
<4>empeg usb initialised, PDIUSBD12 id 1012
<4>empeg state support initialised 0089/88c1 (save to d0005080).
<4>empeg RDS driver initialised
<4>empeg power-pic driver initialised (first boot)
<4>RAM disk driver initialized: 16 RAM disks of 4096K size
<4>empeg single channel IDE
<4>Probing primary interface...
<4>hdb: FUJITSU MHL2300AT, ATA DISK drive
<4>hda: ST9100823A, ATA DISK drive
<4>ide0 at 0x000-0x007,0x038 on irq 6
<6>hda: ST9100823A, 95396MB w/8192kB Cache, CHS=12161/255/63
<6>hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
<4>empeg-flash driver initialized
<4>smc chip id/revision 0x3349
<4>smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
<4>
<4>SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:ee
<6>Partition check:
<6> hda: hda1 < hda5 hda6 > hda2 hda3 hda4
<6> hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4
<5>RAMDISK: ext2 filesystem found at block 0
<5>RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
<4>EXT2-fs warning: checktime reached, running e2fsck is recommended
<4>VFS: Mounted root (ext2 filesystem).
<4>VFS: Mounted root (ext2 filesystem) readonly.
<4>change_root: old root has d_count=1
<5>Trying to unmount old root ... okay
<4>Freeing unused kernel memory: 4k init
<4>Timezone: EST5EDT
<4>Hijack: intercepting config.ini
<4>
<4>hijack: removed menu entry: "Hard Disk Detection"
<4>hijack: removed menu entry: "Serial Port Assignment"
<4>khttpd: listening on port 80
<4>kftpd: listening on port 21
<4>khttpd: open(/favicon.ico) failed, rc=-2
#290891 - 29/11/2006 03:26 Re: Ethernet troubles... [Re: hybrid8]
Sure does look healthy that far. Dump it again after running into troubles (or perhaps you just did that?).
