#285467 - 14/08/2006 20:07 Unknown device on laptop
CrackersMcCheese
I've been given an HP notebook to use for a while at work. Its a Compaq nc6000 and is about 2-3 years old I guess (Pentium M 1.7, 512MB RAM, 40GB HDD) but its never been used. I was sure these models came with built-in wireless but can't seem to see anything in device manager except for one of those yellow question marks next to 'Network Controller'. The driver is missing and nothing I do will get it to obtain it.
Anyone know what this device might be? Could it be the wireless adapter?
#285468 - 14/08/2006 20:15 Re: Unknown device on laptop [Re: CrackersMcCheese]
speedy67
Loc: South-West-Germany
Does it have a "centrino" label somewhere? then it's probably the intel pro wireless device. Try downloading the drivers from the intel site...
cheers, Thomas new owner of the MK1 00123 MK2 12GB 090000815 (my first one) MK2a 040103735 (from 303) and ???
#285469 - 14/08/2006 20:15 Re: Unknown device on laptop [Re: CrackersMcCheese]
Waterman981
Loc: Salt Lake City, UT
My work has a couple of those floating around. In fact a fellow IT employee here has one, but she is out on vacation today. I will find out tomorrow if someone doesn't beat me to it.
-Michael
#040103696 on a shelf
#285470 - 14/08/2006 20:20 Re: Unknown device on laptop [Re: speedy67]
CrackersMcCheese
Yes it has an 'Intel Centrino' sticker on it... thanks for the suggestion about the Intel site. Will try now.
(I should add that I don't have the HP CDs so I'm pretty much stuck if that doesn't work)
#285471 - 14/08/2006 20:21 Re: Unknown device on laptop [Re: Waterman981]
CrackersMcCheese
Thanks Michael... any help would be appreciated!
#285472 - 14/08/2006 20:26 Re: Unknown device on laptop [Re: CrackersMcCheese]
Quite often, you can get the properties for the device. Right-click it in Device Manager, choose Properties and go to the 'Details' tab.
Under Device Instance Id, you'll see a string something like this:
PCI\VEN_11AB&DEV_4362&SUBSYS_81421043&REV_15\etc.
Go to http://pci-ids.ucw.cz/iii/ and look up the four digits after 'VEN_'. In this example, they're 11AB, which is 'Marvell Technology Group Ltd.' Clicking on that entry will take you to a page where you can look up the device ID (4362 in my example).
This'll display the model number, etc., of the device, e.g. '88E8053 PCI-E Gigabit Ethernet Controller'
From there you can drill down into the subsystem ID, but this is not normally necessary. Note that if you do, you need to word-swap the digits (i.e. in groups of 4) of the subsystem ID. In my case, 81421043 translates to 1043:8142, which is 'Marvell 88E8053 Gigabit Ethernet controller PCIe (Asus)'.
Which is actually what my example device is. You should be able to do the same to find yours.
#285473 - 14/08/2006 20:26 Re: Unknown device on laptop [Re: CrackersMcCheese]
speedy67
Are you familiar with linux? Then try booting a knoppix CD, the intel wireless cards are supported. Perhaps only to get the model of the card, just watch the hardware detection while booting the CD. It's worth a try...
#285474 - 14/08/2006 20:42 Re: Unknown device on laptop [Re: Roger]
CrackersMcCheese
Cheers Roger! Its an Intel Pro/Wireless 2200BG. Downloading the drivers (50MB!) now. Will post later if, sorry... WHEN it works Thanks again guys!
Thomas... sorry I'm no use with Linux. I keep meaning to try it sometime though. One day I'll have MythTV!
Edited by Phil. (14/08/2006 20:43)
#285475 - 14/08/2006 22:05 Re: Unknown device on laptop [Re: Roger]
Had to do exactly this today when I had to install a vanilla copy of XP on a new Dell box (it came with XP64 which Avid doesn't like). I got everything bar one device driver reinstalled which unhelpfully showed up as a 'PCI Device'. I used http://www.pcidatabase.com/ which worked really well.
I have to say when I saw a vendor ID of 0x8086 I knew it had to be intel. It's like a personalised licence plate for your car!
#285476 - 14/08/2006 23:50 Re: Unknown device on laptop [Re: CrackersMcCheese]
Pity. The 2200(A)BG works just fine "out-of-the-box" with most modern Linux distros.
#285477 - 15/08/2006 01:58 Re: Unknown device on laptop [Re: CrackersMcCheese]
Even though that is a big DL. You want it! The intel drivers and config software is so much better than the pucky most OEM's seem to ship.
#285478 - 15/08/2006 07:18 Re: Unknown device on laptop [Re: CrackersMcCheese]
furtive
You should be able to download all the drivers for it here
http://h18000.www1.hp.com/
Rio Karma - now on ebay...
#285479 - 15/08/2006 10:36 Re: Unknown device on laptop [Re: Roger]
Thanks for that tip, Roger! That's very useful, as I very often get devices on new OS installs that don't get their drivers installed, and I can't tell what they're supposed to be. I'll be using this in the future!
#285480 - 15/08/2006 16:11 Re: Unknown device on laptop [Re: Dignan]
CrackersMcCheese
Cheers guys! Wireless is all sorted!
