#285157 - 05/08/2006 01:53 Sigh.. One More Time
avatarTX
Loc: Dallas Texas USA
its been a few years since this happened to me last time but my player is on the fritz again. Something failed during a sync. Here is a boot log..
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v355 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Sat Jan 17 08:49:36 EST 2004
empeg-car player (hardware revision 7, serial number 80000506)
Command line: mem=12m
Memory: 10960k/12M available (976k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hdb: TOSHIBA MK3017GAP, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:fa
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
change_root: old root has d_count Trying to unmount old root ...
empeg-preinit starting...
no /etc/preinit.d
empeg-preinit complete
empeg init 0.8
Mounting proc
Starting player
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
If I remember correctly, the system pauses here and then I get a screen full of the following meseges before it stops and locks up at the "Building Music Databases" messege.
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 536320
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 1584896
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 536336
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1378968022, count = 1
Remounting filesystem read-only
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1049598623, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3587859799, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3746542519, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2324098151, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3156579785, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3259374302, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3076771428, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1444106692, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3061143961, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2465988487, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 75562868, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3957023990, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 619864585, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1100831618, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 492120582, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2779541917, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 125487147, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 351565038, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 238260640, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 279308760, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3869135572, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3346116401, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1064822859, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3728119687, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1639482798, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3042814818, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4233031597, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4183690202, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3078601839, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3690847854, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2563492389, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1157990582, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2745284141, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1025401609, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2339073800, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3325476899, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1335623240, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4170219998, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 604570739, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4053224064, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 609528984, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1461005887, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2586530566, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2108970447, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1264076136, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1950238578, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3667703301, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4208335225, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1635327410, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2185416059, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1635543418, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 667199156, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2008740226, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1810286253, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2538383181, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4177517526, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4180568365, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1427211816, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3398025780, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 917440477, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 700560994, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3911591617, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3838395593, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1375150516, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 519104084, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2868257193, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3285810408, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1194998933, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1765137158, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1834255825, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1188697700, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1953661715, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3945497316, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2102805712, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 483089735, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3655364268, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1298296514, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3684099110, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1082245153, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3328758555, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3154077009, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1914778200, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2958899770, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3796992230, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 160441473, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2449534542, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1276086797, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3397421653, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 674369179, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4138061379, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 649135069, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1279028067, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 678921823, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1756205524, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 185405736, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1788570916, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3534674744, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1476566370, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1285162031, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 231392237, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3075295799, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 665287191, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1089172210, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 347165015, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 687410535, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3501942116, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 107303660, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2834322369, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 647041162, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1196537677, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2367638283, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3935045293, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 440648086, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4282469019, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4185166587, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1697252608, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1644817372, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1264655858, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 384184765, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1973491987, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3358270892, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3022981491, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 883493059, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1822715258, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 925476221, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1079461986, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1230629842, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2191305908, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3433225336, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2546576359, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3005403588, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2162168100, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3592722212, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 535874010, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 89589549, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 800975942, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 923826783, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2240902978, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 501566510, count = 1
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 4821573
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1558900372, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1444262663, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1526561256, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2650132691, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1895219550, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2512604308, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 461546474, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3012232678, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 672411049, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1419927513, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2875756850, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1142229558, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2930806953, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 163958888, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3414736238, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1444042394, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2230421671, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2300175769, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3592357114, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3580073004, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2781632646, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1644708157, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 513251392, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1709074340, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2353956246, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3844274042, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2655459985, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 435595732, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 206383414, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1433428630, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2784213741, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2487880161, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1766841816, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4209678181, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4009506264, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 308717235, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3593104091, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1196454098, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 479223889, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 393079698, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 571240997, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 83132435, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3388059605, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3916396062, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 238447645, count = 1
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 8681147
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1150505550, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4266789264, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1194045489, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3995446420, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2394854524, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3047498811, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3776633621, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 693834233, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2880227362, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1054549766, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3205333991, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1859544879, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3597773540, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 721279898, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2384791253, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3292087712, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2961885346, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 611443076, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3531983442, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 652442470, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1671511762, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 338638965, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4236505524, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 609635612, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1546954384, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1952610921, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3377721740, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 695476638, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 594234956, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2577639017, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 594918941, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2707904780, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2465988458, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 75561844, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1792895192, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 502417990, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 816708481, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2303928514, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 632058267, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 159498283, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 150353006, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1497473193, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 699935925, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2085328614, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1479634211, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3371119687, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1677683295, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1887663065, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1226983444, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3871913517, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3901926981, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 642152160, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2807729912, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1514125121, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 553005512, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2436016868, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4238152224, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1404436745, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3172208362, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1401934093, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 364453188, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 852756374, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 580342912, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3852870437, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 359155090, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2147634300, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3685052131, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2467107392, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1225168915, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2662642220, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 11827496, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2518583872, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1424770347, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1493772348, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2764183345, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3704009345, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1835541945, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2546428967, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2661181108, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1226846346, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3364365936, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4193751482, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2440163071, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2585754380, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1985838189, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1714681560, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2013193876, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3883475249, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2993084876, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3942954307, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3792103900, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 684771261, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 40009092, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 289777626, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2647389965, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1743616326, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1990696602, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3657006205, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2537370331, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3114274933, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1386087680, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 65116692, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 441991306, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2306939975, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1238023989, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 226184473, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 350153511, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1316917025, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1090728932, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 823550486, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1481153587, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2496128052, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3684082372, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3566251804, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3712200379, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 494033948, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 953250755, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3551578882, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3794651820, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 644603576, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2408731108, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4214226601, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2118580442, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1267902672, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3352316227, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 262191912, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1233259129, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2356209794, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2688930377, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2271044324, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1339663885, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 946600266, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4288675734, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2019956963, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4086990716, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4029104774, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1131511112, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3399529909, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2589344905, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 901191173, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3947355821, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2522972078, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 684479387, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3740061334, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 150778176, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2751877248, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 566978566, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3416467915, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2031873580, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3126889375, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3067643950, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1366037687, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3389622339, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 67240389, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2316540688, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 66151940, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1794018450, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2542543894, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3679927449, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1898387110, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3456509440, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 979773586, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3029245248, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1776840193, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 711454001, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1795453456, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3117931694, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2288552530, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1327668222, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3546645536, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1137117761, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 958518419, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 659501848, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 327319924, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 358818838, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4004976773, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2850523638, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 982076837, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3295464073, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1052216353, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1474608446, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 13618430, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1699562096, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1144062789, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2739818553, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1483995531, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 637750996, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3117748166, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1662294836, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2279120405, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2077901576, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1850606508, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 460845038, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2428567557, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2686610872, count = 1
Remounting fi
Edited by avatarTX (05/08/2006 03:16)
Carl Aydelotte Dallas Texas USA empeg MKII 080000506 40gb-green
#285158 - 05/08/2006 02:56 Re: Sigh.. One More Time [Re: avatarTX]
avatarTX
I found this in the FAQ and am running it now..
ro
umount /dev/hda4
umount /dev/hdc4
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
The first hard drive (hda4) performed as expected.. but the second drive (hdc4) is making some strange noises. I am also getting these messeges, I dont remember if the first drive did this or not?
ide0: reset timed-out, status=0x80
hdb: status timeout: status=0x80
hdb: drive not ready for command
end_request: I/O error, dev 03:44 (hdb), sector 6353269
hda: status timeout: status=0x80
hda: drive not ready for command
ide0: reset: success
Error reading block 3176634 (Attempt to read block from filesystem resulted in s
hort read) while reading indirect blocks of inode 1433. Ignore error? yes
Inode 1433, i_blocks is 7850, should be 7338. Fix? yes
hdb: irq timeout: status=0xff
hda: lost interrupt
hdb: irq timeout: status=0x80
I am going to let it continue until I get a prompt .. the second drive is bigger so I expect this to take some time. I am keeping my fingers crossed too. Someone please tell me I am on the right track?
Edited by avatarTX (05/08/2006 03:18)
#285159 - 05/08/2006 03:14 Re: Sigh.. One More Time [Re: avatarTX]
avatarTX
Well it moved on..
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Unattached inode 3756
Connect to /lost+found? yes
Inode 3756 ref count is 2, should be 1. Fix? yes
Pass 5: Checking group summary information
But now I seem to be stuck at this new problem. Some sort of memory violation, and it appears to be stuck in a never ending loop..
ontrol: D03A117D Table: D03A117D DAC: 00000015
init(1): memory violation at pc=0x00000000, lr=0x02007140 (bad address=0x0000000
0, code 2)
pc : [<00000000>] lr : [<02007140>]
sp : 00000000 ip : bffffd88 fp : 00000000
r10: bffffe98 r9 : 00000000 r8 : 0203d938
r7 : bffffdac r6 : 00000000 r5 : 00000009 r4 : 00000000
r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 00000009
Flags: nzcv IRQs on FIQs on Mode USER_32 Segment user
Control: D03A117D Table: D03A117D DAC: 00000015
0, code 2)
and its doing that over and over and over. I dont know if I shoud stop it, or even how to stop it if I wanted to. Cntrl-C maybe?
Edited by avatarTX (05/08/2006 03:19)
#285160 - 05/08/2006 04:02 Re: Sigh.. One More Time [Re: avatarTX]
avatarTX
Well I give up. Nothing I have tried has worked so far. I had to power off the unit to stop the memory violation loop it was in and cannot get the system to boot normally yet. I have searched the FAQs for help and have not been able to find what I need.
I had this same problem a few years ago and managed to fix it then but I dont remember how I did it. My databases are corrupt and I need to rebuild them, I think.. and cannot figure out how.
Anyone have any ideas?
#285161 - 05/08/2006 05:10 Re: Sigh.. One More Time [Re: avatarTX]
The fact that the second hard disk made funny noises points (i think) to some kind of physical failure. Either the disk is bad, or you have one of the usual cable-or-IDE-header problems.
All the FSCKs and database rebuilds in the world won't help you if you're having hardware trouble.
#285162 - 05/08/2006 11:03 Re: Sigh.. One More Time [Re: tfabris]
avatarTX
Well now.. go figure. In an effort to find out whats going on I opened up my player to see if I could tell what is actually happening. As soon as I take the cover off I fire it up and it comes up like a champ. I think my player is either haunted or just needed its screws loosened once.
Emplodes sees it and everything. I cant tell you what a relief that is!
#285163 - 05/08/2006 12:14 Re: Sigh.. One More Time [Re: avatarTX]
maczrool
Loc: Louisiana, USA
Those are classic signs of a bad cable or IDE header problem.
Stu
#285164 - 05/08/2006 14:54 Re: Sigh.. One More Time [Re: maczrool]
More specifically, even if it seems to have magically fixed itself for now, the problem is going to come back. You need to locate and repair whatever is causing the intermittent fault.
