#282463 - 06/06/2006 01:11 Sigbus Error?
newguy1
Loc: Massachusetts,USA
Just got this Sigbus error today.Had to pull the player from sled to reboot.I have occasionally gotten the Segfault error and had to pull player to reboot also.All the errors occurred when starting car and player freezes at the static logo screen.
Back in March I tried v3 alpha 11 for a few days but then went back to v2.0 final.I've always used Hijack,not sure what version I had on before I upgraded but probably one that didn't show the error.After I reverted back to 2.0 I put on hijack v448 which I guess is why I now see the errors.Although the player never locked up before I tried alpha11
Anyway,do I need to be concerned?I hate pulling the player that way as it pops the speakers.
MIKE 80Gb RIO
#282464 - 06/06/2006 01:53 Re: Sigbus Error? [Re: newguy1]
You're right: It's only recent hijacks that show the error. The error isn't caused by hijack, it's just reporting them now.
I agree that locked up player software sucks because of that speaker-pop. Sometimes, even when the player software is locked up, you can still make the Hijack menu appear and select the "reboot machine" option to get the player to reboot nicely without needing to pull it and make the pop happen.
So. Back to the problem at hand: sigbus and segfault errors. These can be caused by:
- Running alpha software. Your best bet is to stick with 2.0 final or 2.0 beta 13.
- A specific bad MP3 file that screws up the decoder.
- Disk drive, IDE header, or disk cable trouble.
- RAM trouble.
- Other hardware trouble.
I'm guessing that the fact you're specifically getting a "sigbus" error indicates a certain kind of hardware trouble that others might be able to diagnose. But first give us a full boot log and a RAM test log. Instructions on how to do this are in the FAQ, search for Hyperterminal.
#282465 - 06/06/2006 23:49 Re: Sigbus Error? [Re: tfabris]
newguy1
Ok thanks Tony,It will take me a couple days but i'll get the info posted.
MIKE 80Gb RIO
#282466 - 08/06/2006 01:44 Re: Sigbus Error? [Re: newguy1]
newguy1
Well I took the player out of the car(it worked fine on my 45 minute drive home today)and connected it to AC power and the serial cable.Now I get the No hardrive found error and can hear the hardrive starting/stopping starting/stopping over and over.
Anyway here are the logs
282788-Boot.txt (226 downloads)
MIKE 80Gb RIO
#282467 - 08/06/2006 01:44 Re: Sigbus Error? [Re: newguy1]
newguy1
Ram log.
282789-RAM.txt (188 downloads)
MIKE 80Gb RIO
#282468 - 08/06/2006 02:32 Re: Sigbus Error? [Re: newguy1]
Yup, as you can see pretty clearly in the log, you've got one of the usual problems.
#282469 - 08/06/2006 09:28 Re: Sigbus Error? [Re: tfabris]
newguy1
I guess it possible,but support has already replaced the drive,the cable,and repaired the header.I don't remember exactly but maybe it was 2 years ago.I'll try it back in the car later today and see what happens.
MIKE 80Gb RIO
#282470 - 08/06/2006 11:08 Re: Sigbus Error? [Re: newguy1]
If it is okay in the car, you might want to check to see if your AC power supply / wall wart is dying. Maybe it is not supplying enough power to keep the drives spinning...
Another thought, if you have one of Mark's docks, is to try it in there - that uses the DC power channel.
Edit: Note - this assume that it was working in the car. It was in one of your posts, but not in the first post. You might also just want to check to see if the hard drive cable worked loose from the connector due to use or vibration.
#282471 - 08/06/2006 23:39 Re: Sigbus Error? [Re: pgrzelak]
newguy1
It seems to work in the car fine.I've only had the sigbus/segfault errors about 5 times.
I have the original home power supply that came with the player.When I plugged it in last night it wouldn't boot but tonite it did. here is the new boot log and new ram test.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v448 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Mar 16 19:43:10 EST 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004780).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED
ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED
ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED
ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED
ide_data_test: wrote 0x0000 read 0xbbc4 -- FAILED
ide_data_test: wrote 0xffff read 0xbbc4 -- FAILED
ide_data_test: wrote 0xaaaa read 0xbbc4 -- FAILED
ide_data_test: wrote 0x5555 read 0xbbc4 -- FAILED
hda: FUJITSU MHR2030AT, ATA DISK drive
ide_data_test: wrote 0x0000 read 0x045a -- FAILED
ide_data_test: wrote 0xffff read 0x045a -- FAILED
ide_data_test: wrote 0xaaaa read 0x045a -- FAILED
ide_data_test: wrote 0x5555 read 0x045a -- FAILED
hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2
e
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Compìàlayer
redirected to /proc/ttyH
Timezone: Atlantic/South_Georgia
khttpd: listening on port 80
kftpd: listening on port 21
And the new ram test.
0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id FUJITSU MHR2030AT
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 00
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
MIKE 80Gb RIO
#282472 - 09/06/2006 10:38 Re: Sigbus Error? [Re: newguy1]
So sometimes the hard drive works (second log), and sometimes not (first log).
Time to check out the cable and connections.
#282473 - 10/06/2006 14:31 Re: Sigbus Error? [Re: mlord]
newguy1
I unplugged and reconnected the cables but still got the IDE failure tests in the log.
By coincidence I upgraded to hijack 461 from 448 and the IDE failures are gone.I downgraded back to 448 to see if failure notice was still there and it was.Then upgraded back to 461 and they were gone.
Does that mean my drive is good or maybe on its way out?
version 448 log
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0005c80).
e
Partition check:
Mounting proc
Starting player
Using non-standard cache size 124 (adjustment 10)
Vcb: 0x407cd000
serial_notify_thread.cpp: 116:@@ N145
serial_notify_thread.cpp: 117:@@ F0x4cb0
serial_notify_thread.cpp: 118:@@ TDaughter
serial_notify_thread.cpp: 119:@@ APearl Jam
serial_notify_thread.cpp: 120:@@ GAlternative
serial_notify_thread.cpp: 180:@@ #4cb0 0:01:17
serial_notify_thread.cpp: 170:@@ S0
version 461 log
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v461 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Jun 8 15:00:28 EDT 2006
c1000000: wrote ffffffff, read e28cc001
empeg state support initialised 0089/88c1 (save to d0005d80).
e
Partition check:
Mounting proc
Starting player
hijack: removed menu entry: "Serial Port Assignment"
Vcb: 0x407cd000
MIKE 80Gb RIO
#282474 - 10/06/2006 14:40 Re: Sigbus Error? [Re: newguy1]
No, the messages are still there, they just lack the "FAILED" text that I nuked from recent Hijack versions (see the changelog, if you like).
All that really matters is whether it finds the drive or not at the end of it all. It looks like sometimes it works, and sometimes it does not work. Flakey hardware. Changing the software won't help here.
Not likely at all. Much more probable is a bad connection somewhere, almost certainly on the cable crimps or the mainboard IDE header. Same as for 99.99% of all other cases of this happening to anyone else here.
#282475 - 10/06/2006 15:05 Re: Sigbus Error? [Re: mlord]
newguy1
I did have the cable replaced and the header repaired by support.Don't remember exactly when but I guess the easiest is to try a new cable first or recrimp this one.
With a properly working player what should the boot log look like(the part after probing primary interface)
MIKE 80Gb RIO
#282476 - 10/06/2006 15:38 Re: Sigbus Error? [Re: newguy1]
The last log you posted above looks nice.
As long as the player works reliably, no need to fuss with it.
#282477 - 10/06/2006 16:12 Re: Sigbus Error? [Re: mlord]
newguy1
Great,thanks for your help
MIKE 80Gb RIO
