#279448 - 13/04/2006 13:33 Gallery + binaries
CrackersMcCheese
I've got Gallery2 all nicely setup on my webspace but want to add a couple of modules namely Netpbm and Ffmpeg.
I have no experience whatseover so just blindly downloaded what I though was the right files but... its not right and Gallery says it cannot find the binaries. Do I need to do something else with the 2 zip files I downloaded? Theres no binaries there or so it says and I'm confused! Help please
Thanks,
Edit: I got the zip files from here
Edited by Phil. (13/04/2006 13:34)
#279449 - 13/04/2006 13:51 Re: Gallery + binaries [Re: CrackersMcCheese]
They're just the Gallery modules. You still need the actual NetPBM or FFMPEG applications.
#279450 - 13/04/2006 14:12 Re: Gallery + binaries [Re: tman]
CrackersMcCheese
So where would I get the applications from? I've looked but I'm getting easily confused today.
This is probably a good time to mention that I don't know what a binary is! Using an ftp client I have a gallery2/modules/ folder. I thought I could just unzip the file in there and then point to it in the control panel in Gallery but its having none of it
Edited by Phil. (13/04/2006 14:19)
#279451 - 13/04/2006 14:45 Re: Gallery + binaries [Re: CrackersMcCheese]
Depends on what OS/distribution you're running on...
#279452 - 13/04/2006 14:46 Re: Gallery + binaries [Re: Roger]
CrackersMcCheese
Apache server, (Linux). I can only use ftp to up load files - no shell stuff.
Edited by Phil. (13/04/2006 20:08)
#279453 - 13/04/2006 15:31 Re: Gallery + binaries [Re: CrackersMcCheese]
CrackersMcCheese
yeeeaaaah, found 'em.
#279454 - 13/04/2006 17:35 Re: Gallery + binaries [Re: CrackersMcCheese]
CrackersMcCheese
Actually scrub that. I got Netpbm working but I'm having a hard time finding a ffmeg binary precompiled for linux. Can anyone send me this file?
#279455 - 13/04/2006 17:43 Re: Gallery + binaries [Re: CrackersMcCheese]
I thought you were using XP.
#279456 - 13/04/2006 17:51 Re: Gallery + binaries [Re: wfaulk]
CrackersMcCheese
sorry I meant i was using XP for ftp carry-on. The server is linux. Sorry for any confusion.
From reading the Gallery forum, ffmpeg isn't made available for linux - you need to compile it yourself. If anyone has this file on their server I'd appreciate it. Its only a couple of MB or so I read.
#279457 - 13/04/2006 19:01 Re: Gallery + binaries [Re: CrackersMcCheese]
Eh? My Ubuntu machines have it (from somewhere).
#279458 - 13/04/2006 19:05 Re: Gallery + binaries [Re: mlord]
I have a rpm for RHEL 3 ES if you want it.
EDIT...I see you don't have shell access. I can send you the i386 binary if you wish.
#279459 - 13/04/2006 20:04 Re: Gallery + binaries [Re: mlord]
CrackersMcCheese
Sorry I should say there is no precompiled linux binary available for download - or so all the forums say. People do have it but they've had to make it themselves. I've trawled the web for ages now
Edited by Phil. (13/04/2006 20:07)
#279460 - 13/04/2006 20:06 Re: Gallery + binaries [Re: JBjorgen]
CrackersMcCheese
Thanks... but... that won't run on linux though? Or will it?
#279461 - 13/04/2006 20:34 Re: Gallery + binaries [Re: CrackersMcCheese]
matthew_k
It will as long as you're using an intel 386, 486 or pentium or amd/via equivalent. It just won't work if you've got linux installed on a strongarm, powerPC, sparc, 68k, alpha, mips, hp-parisc, itanium or s390 processor.
#279462 - 13/04/2006 20:36 Re: Gallery + binaries [Re: matthew_k]
CrackersMcCheese
Ah, ok. Well its worth a shot
philip (dot) ohare (at) ntlworld (dot) com
#279463 - 14/04/2006 13:46 Re: Gallery + binaries [Re: CrackersMcCheese]
CrackersMcCheese
All working now, cheers :-)
