#274254 - 13/01/2006 18:18 Sirius Receiver compatible with Empeg... which is a good unit?
Fuddy
I'm looking for a sirius receiver for my rio empeg.. which is a good one and what are your experiences with them.. .
tya
Edited by Fuddy (13/01/2006 18:18)
#274255 - 13/01/2006 18:27 Re: Sirius Receiver compatible with Empeg... which is a good unit? [Re: Fuddy]
Anything which has line outputs will work as the only way you can connect it is via the line inputs on the empeg/rio sled.
#274256 - 13/01/2006 18:31 Re: Sirius Receiver compatible with Empeg... which is a good unit? [Re: tman]
Fuddy
I'm thinking y cable from the output jack in a sirius receiver to the aux rca inputs on the empeg
Edited by Fuddy (13/01/2006 18:31)
#274257 - 13/01/2006 19:00 Re: Sirius Receiver compatible with Empeg... which is a good unit? [Re: Fuddy]
Why a Y cable?
#274258 - 13/01/2006 19:03 Re: Sirius Receiver compatible with Empeg... which is a good unit? [Re: tfabris]
robricc
Although not really a Y cable, he probably means a cable 1/8" mini headphone on one end and 2 RCAs on the other.
#274259 - 13/01/2006 19:07 Re: Sirius Receiver compatible with Empeg... which is a good unit? [Re: robricc]
Ah. Yes, that would work.
#274260 - 15/01/2006 01:46 Re: Sirius Receiver compatible with Empeg... which is a good unit? [Re: tfabris]
petteri
Loc: Helsinki, Finland
For what its worth I've got a Brix Streamer (older gen 2.0) hooked up to my Empeg. There was talk around here a while ago of getting a Sirius tuner to work directly with the Empeg but that project never got off the ground...
