#273574 - 06/01/2006 12:50 Tale of Woe - Failed mem upgrade
bbowman
Loc: Virginia, USA
Well, all, I regret to say that after attempting the mem upgrade, I have failed and also killed my empeg in the proces. I've been soldering for more than half my life, so I thought I would be up to the task - but I suppose that I wasn't. Here is my taile of woe and horror.
I followed the instructions to dissaemble the empeg and smoothed down the extra solder on the test pads where the memory board would go. I also ground down the tip of my soldering iron so that I would fit nicely into the holes.
After adding some matching everything up, I taped the board into place and began filling the wholes. Then I added the two leads onto the capacitors. I decided to test it on just the 48MB before doing the challengin 64 MB line and after flipping the dip switchs 1 and 4 to off, I plugged it in and booted.
It booted fine, but no extra DRAM:
If there is anyone present who wants to upgrade the flash, let them
speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux..................................... done, booting
the ker.Linux version 2.2.17-rmk5-np17-empeg52-hijack-v444
(hijack@rtr.ca) (gcc versio5
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 10101307) 16MB DRAM
Command line: mem=16m
etc...
So I rechecked the connections - made sure that I had continuity and heated up the poads under the cpu again.
This time:
c1000000: wrote ffffffff, read efffffff
the wrote/read was changing which lead me to believe that I just had a bad connection some where.
So I when through the connections again. to no avail.
I went through this scenario several times without success and began doing one contact at a time between reboots.
It go to the point that after one resoldering of a contact, the empeg would not boot up. The red LED would not light up either, but the blue led in the ethernet connection would light up.
So I believed that I had bridged something under the board, so I used the braid to clean out the holes and lifted the board. To my horror, the test pads came up with it. I disconnected everything and still the empeg will not even post.
I have included the horrific pictures of the aftermath and on one is an arrow to the last contact that I attempted to solder. It was after this one that the empeg stopped working.
Is there anyway I can get this fixed? maybe a jumper wire?
Here is the last full boot message I got out of it:
speak now,
e000 v1.04
Copying kernel...
(hijack@rtr.ca) (gcc versio5Processor: Intel StrongARM-1100 revision 11
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9bb84
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface.
edit : Fixed title
--l0ser
Edited by l0ser (09/01/2006 20:25)
#273575 - 06/01/2006 20:03 Re: Tale of Woe - Faiiled mem upgrade [Re: bbowman]
Don't Panic!
This is fixable. I've done similar repairs to units in the past. But do see if you can get RobS to have a look at it -- he also can fix stuff like this, and is far more likely (odd as this may sound) to get 'round to it before I ever would.
But it IS fixable.
EDIT: A better (more clear, and brighter) photograph might help here
Edited by mlord (06/01/2006 20:07)
#273576 - 07/01/2006 13:44 Re: Tale of Woe - Faiiled mem upgrade [Re: mlord]
schofiel
Agreed. you need a better macro photo of this.
I am beginning to wonder if there is now going to be a flood of damaged empegs as this expansion board begins to arrive. Be aware people that this is a real precision job that may take more than a whole day to install. It is MOST DEFINITELY NOT for the inexperienced.
I am reconsidering whether I want to offer a service to install this board. I will make a decision and repost soon.
#273577 - 07/01/2006 13:53 Re: Tale of Woe - Faiiled mem upgrade [Re: mlord]
bbowman
Loc: Virginia, USA
Thank you for your comforting words. I have placed some more pictures on an external site:
Pictures of board
I realize that the memory upgrade is very unlikely at this point. I just want to get this thing working again.
Thank you.
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
#273578 - 07/01/2006 14:01 Re: Tale of Woe - Faiiled mem upgrade [Re: schofiel]
maczrool
Loc: Louisiana, USA
I agree; these boards are very tempermental and difficult to install. We install them, but it's not a particularly enjoyable task.
Brent, your pictures are still pretty unclear, but it looks like you damaged an inner layer trace.
Stu
#273579 - 07/01/2006 18:02 Re: Tale of Woe - Faiiled mem upgrade [Re: bbowman]
Might as well delete the rest of them.
I would suggest you try removing the two largish solder blobs from the bottom row of traces, and then look for broken/damaged traces from under where the memboard was placed. There's at least one broken trace visible in the least blurry photo.
If that still doesn't help, then PUT THE SOLDERING GEAR AWAY!! You cannot do any more good without a circuit schematic or layout diagram (only RobS has access to those, and he's not allowed to share them). Or possibly a second empeg board to compare with could help -- preferably an unpopulated board. Again, RobS has those.
#273580 - 07/01/2006 19:56 Re: Tale of Woe - Faiiled mem upgrade [Re: mlord]
schofiel
I can see at least two shorts and a broken track. There's also a lot of very small blobs around the pads bottom left that really need to be removed. I really would like to see this under the microscope here to check.
I'm sad this has gone wrong for you. It may well be that the board was simply defective and your work was good - I hope not. A lot of care went into assembling these boards.
#273581 - 08/01/2006 05:45 Re: Tale of Woe - Faiiled mem upgrade [Re: schofiel]
genixia
I don't know how you can see anything in those pics!
IMO it's unlikely that the board was bad. The first log contains the classic result indicating bad RAS connections for both the high and low words chips. The later logs show evidence that the RAS connections were fixed. The final log suggested that D12 on the high word wasn't connected.
#273582 - 08/01/2006 13:17 Re: Tale of Woe - Faiiled mem upgrade [Re: genixia]
I concur. But I have had the odd bad RAM chip mess up an otherwise perfectly decent RAM upgrade.. (hi Taym!).
#273583 - 08/01/2006 22:59 Re: Tale of Woe - Faiiled mem upgrade [Re: mlord]
bbowman
Loc: Virginia, USA
Thanks, I have deleted those and uploaded a new set. I tell you, getting a good clear picture of this thing has been about as challenging as soldering this board!
Updated pictures
Thank you for that advice. I don't consider myself to be a soldering novice, but I'm not a pro either (even though I've done many soldering projects over the past 20 years). Believe me when I say that I am deeply embarrased that this has happenned, but for the love of my empeg, I am looking for a solution here.
Does anybody have a good picture of the traces (particularly of the bottom row) that they could send me? Also, once I find out those traces, Is ther a good way for me to figure out what pins (where) are being connected so I could do a jumper somewhere on the top of the board. I suppose that I am the mercy of Rob on some of that. Rob?
Any help would be greatly appreciated at this point.
Brent
Brent
#273584 - 09/01/2006 12:21 Re: Tale of Woe - Faiiled mem upgrade [Re: bbowman]
Attached -- taken with an old Nikon E990 3mp digicam, and a desk lamp.
#273585 - 09/01/2006 12:32 Re: Tale of Woe - Faiiled mem upgrade [Re: mlord]
And here is a better close-up of the area in question, after I adjusted a few camera settings.
#273586 - 09/01/2006 19:10 Re: Tale of Woe - Faiiled mem upgrade [Re: bbowman]
gogee2000
Hi there,
I don't have any advice, but I do share your feelings. I started an upgrade myself and stopped at the point where the install of the board would have taken place. Not feeling confident enough, I shipped it off to Eutronix and they were able to do it. There were problems though, but Eutronix did there absolute very best at getting my empeg back to life. I'm so very happy to have my empeg working again, even though I only have 16 of 64meg, but that's better than the 12meg :-)
Gregory
#273587 - 10/01/2006 01:15 Re: Tale of Woe - Faiiled mem upgrade [Re: mlord]
bbowman
Loc: Virginia, USA
Thank you, Lord. Those are excelent pictures. I'll look through to make sure that I'm not shortng any of those traces.
Brent
#273588 - 14/01/2006 22:43 Re: Tale of Woe - Faiiled mem upgrade [Re: maczrool]
bbowman
Loc: Virginia, USA
Yes, I do believe that an inner trace was damaged. Hopefully it was only one. But suspect that it was just one since at the end, I was doing only one contact at a time between tests before it died.
I have repaired eight traces that were broken and with a little luck, I can find two connections somewhere on the board that would short the damaged inner trace. Any idea how I can find those? Since I have a good idea of under which test pad the damaged was done, I'm fairly confident of where it broke. It was bottom row, second from the left.
Also, is it reasonable to assume that the small holes next to the test pads go down to at least the next layer down? Maybe I could connect a couple of those? Also, this may seem like a stupid question, but how many internatl layers are there? Is it just one or two?
After fixing those other traces, I'm starting to get a little hope that I may be able to fix this thing.
Either way, I hope that this thread can serve to reinforce how important it is to be careful when installing this mem board.
Brent
#273589 - 17/01/2006 12:37 Re: Tale of Woe - Faiiled mem upgrade [Re: bbowman]
bbowman
Loc: Virginia, USA
Thinking back, Here is a method I would have used that would have made this install easier:
Before putting on the memory board, I would have made a bunch of small, flat coils with a head using very small wire. Kind of like small dancng cobra snakes where the head would stick up just high enough to poke through the holes of the memory board. This way, I could be sure that my connection is good without having to get the heat down to the test pad post board placement.
My problem what not being able to see below the board to know if the connection was being made. If I could see that pin (the cobra head) I would be almost certain that the connection was being made.
If I can fix that inner layer trace, than I may proceed with that strategy (I beliieve to be my only choice other than to abandon the upgrade alltogether). Of course, the salvation of the empeg relies on finding where that broken inner trace needs to be shorted.
Brent
#273590 - 17/01/2006 15:56 Re: Tale of Woe - Faiiled mem upgrade [Re: bbowman]
I used to design the conveyor machines that replaced thru-hole plating for innerlayer connection. The stuff the conveyor machines uses is, essentially, carbon powder and corn starch. It forms a very low resistance resistor between layers.
Two products I know of that do this are called "shadow" and "black hole".
It might be worth a look.
#273591 - 17/01/2006 19:19 Re: Tale of Woe - Faiiled mem upgrade [Re: bbowman]
peakmop
Loc: 384400 km from the Moon
I did several memory board upgrades without a hitch (knock on wood).
A couple of suggestions:
1) Based on your pictures I see that pads adjacent to the CPU ones are not completely flat. That could create problems while soldering CPU pads. I absolutely flattened entire area where the memory board would sit on. It takes a while but is a good way to ensure excellent connections from the get go.
2) In order to make sure you placed your board right the first time is to put small amounts of solder in several spots across the area where the board would be placed. This way you create small semi-circular spheres that will lock your board in place instantly. A better way is to make these solder spheres for all of the memory board holes so you never have to excessively heat the underlying pad.
#273592 - 17/01/2006 19:24 Re: Tale of Woe - Faiiled mem upgrade [Re: peakmop]
Here's an idea. Probably not a very good one. Put down those bits of solder and have a fine wire stick straight up out of them. Then you could thread the board onto those pieces of wire which would come loose when you soldered it down. Alternately, somehow make the wire itself solder (maybe a higher melting temp than the stuff used to tack it down?) so that you don't have to remove it at all.
#273593 - 17/01/2006 20:42 Re: Tale of Woe - Faiiled mem upgrade [Re: wfaulk]
schofiel
I have been looking at snap-off via pins to solder onto the pads BEFORE the board is dropped over them. The pin tips then protrude through the memory board. This would then be a straightforward matter of soldering.
However, there is the issue of clearance between the case and pin tips to address. WIP.
I am becoming more convinced that the RAS connectivity failures observed are due to the DIP switches not having good connectivity after they were soldered on: as Patrick observes, I suspect you need to snap the switches back and forth a few times to clean them then test for continuity/lack of in both positions to ensure they are OK.
