#261132 - 22/07/2005 21:38 Hijack v435 build errors
Defiler
I tried to build a copy of v435 using the arm toolchain, and I got some errors in /arch/arm/setup.c regarding an unexpected use of the
_16MB #define statement.
When I enabled the .config option for expanded memory support, they went away.
Anyone else tried to build one of these without expanded memory enabled?
#261133 - 23/07/2005 13:04 Re: Hijack v435 build errors [Re: Defiler]
Just edit that file, and move the definition of _16MB up 3 lines.
Fixed in Hijack v437.
#261134 - 23/07/2005 13:54 Re: Hijack v435 build errors [Re: Defiler]
Defiler
Cool. Thanks.
I'm building my own kernel images, since I need ext3 support, and the ext3 empeg site tends to have much older versions of Hijack.
If I put my builds on the web, do you want to link to them? I'm not sure how many other people are using ext3..
#261135 - 23/07/2005 19:52 Re: Hijack v435 build errors [Re: Defiler]
Not at the moment (very few ext3 users out there), but perhaps someday soon.
#261136 - 24/07/2005 08:54 Re: Hijack v435 build errors [Re: Defiler]
Hi Defiler,
If you do pop them somewhere, I am interested. My backup empeg is on ext3, but my compiler box is a bit flaky so I just use the ext3 available at the moment which means older hijack versions...and I do like my main empeg to be up to date.
#261137 - 25/07/2005 16:55 Re: Hijack v435 build errors [Re: frog51]
mcomb
Loc: San Carlos, CA
Sorry guys, I'm a slacker. I tend to forget to do ext3 builds unless I'm interested in something new in hijack. Feel free to ping me if the site is out of date and you want a newer version. I've just put up an ext3 build of hijack 437.
-Mike
#261138 - 25/07/2005 18:06 Re: Hijack v435 build errors [Re: mcomb]
Sorry Mike,
I didn't mean to imply you were a slacker at all. If I was in your shoes, I too probably wouldn't update for each hijack release (Mark does get them out with some high frequency) especially if I were busy.
I just appreciate any good things folk do for the empeg
#261139 - 25/07/2005 18:30 Re: Hijack v435 build errors [Re: frog51]
mcomb
Loc: San Carlos, CA
Don't worry, I didn't take it that way And now that I see there is a new empeg alpha out it was definitely time to get updated.
-Mike
