#261055 - 21/07/2005 01:53 empeg up in smoke (again)
SE_Sport_Driver
While driving today, the fuse blew in the empeg's wire harness....
Later tonight, I was playing the empeg for about the same time (1 hour or so) and while I was out of the room, I smelled something burning. The empeg was pulsing it's LED but did not resond. It was set to play on repeat, so something was wrong (Capt. Obvious here).
I opened the player and saw this part looked like burnt toast... any idea what it is? I know it's on the fan controller, but that's about it. Why is it getting so hot and by cooking like this, why would the player stop at "probing primary interface"? I assume it's not gettting beyond the kernal?
Edited by SE_Sport_Driver (21/07/2005 01:53)
#261056 - 21/07/2005 02:04 PLEASE HELP [Re: SE_Sport_Driver]
SE_Sport_Driver
I swapped my drives to my backup player and SEG FAULT appeard on the screen over and over...
TeraTerm Pro isn't storing much of the boot log, but I was able to copy this:
  player.cpp        : 579:empeg-car 3.00-alpha10 2005/07/09.
! memory_stream.cpp : 42:MemoryStream failed to allocate memory.
! tunedb_disk.cpp : player(21): user memory violation at pc=0x0206687c, lr=0x0
0000010 (bad address=0x000004c0, code 2)
878:Failepc : [<0206687c>] lr : [<00000010>]
sp : bffffa78 ip : bffffa90 fp : bffffa8c
d to builr10: 021d543c r9 : 0217c144 r8 : bffffacc
d database. Br7 : 00000010 r6 : 0220b350 r5 : 00000000 r4 : bffffa90
ad. 0xc00r3 : 00000010 r2 : bffffa90 r1 : 00000000 r0 : 000004c0
7000e
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0EF917D Table: C0EF917D DAC: 00000015
Function entered at [<02066864>] from [<02067268>]
r5 = BFFFFACC r4 = BFFFFA90
Function entered at [<0206722c>] from [<020681a0>]
r5 = 000004C0 r4 = 0220B340
Function entered at [<02068138>] from [<0203c38c>]
r10 = 021D543C r9 = 0217C144 r8 = 00000000 r7 = 021D543C
r6 = 00000000 r5 = BFFFFB74 r4 = 0220B340
Function entered at [<0203c2a0>] from [<0200d940>]
r8 = BFFFFDB8 r7 = BFFFFCD0 r6 = 021D52C4 r5 = 021D5308
r4 = BFFFFB74
Function entered at [<0200d900>] from [<02039c68>]
r6 = 0217C144 r5 = 00000000 r4 = BFFFFB74
Function entered at [<020399c0>] from [<020398d0>]
r10 = 0202ADAC r9 = 00000000 r8 = 00000001 r7 = BFFFFF64
r6 = BFFFFE08 r5 = BFFFFCD0 r4 = BFFFFCD0
Function entered at [<02039890>] from [<0203b080>]
r6 = BFFFFE08 r5 = FFFFFFFF r4 = BFFFFCD0
Function entered at [<0203af18>] from [<0203b1dc>]
r8 = 00000001 r7 = BFFFFF64 r6 = 021D5374 r5 = 00000001
r4 = 021D529C
Function entered at [<0203b13c>] from [<0202adbc>]
r8 = 0217B568 r7 = 00000000 r6 = 020000C0 r5 = BFFFFF64
r4 = 00000001
Function entered at [<0202adac>] from [<02131bb0>]
Function entered at [<02131ad4>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting playTimezone: Atlantic/South_Georgia
er
Using non-standard cache size -80 (bonus 0Mb, adjustment 180)
! tunedb_disk.cpp : player(25): user memory violation at pc=0x0206687c, lr=0x0
d to build dar10: 021d543c r9 : 0217c144 r8 : bffffacc
7000e
r4 = BFFFFB74
r4 = 021D529C
r4 = 00000001
er
Is this due to my config.ini having a ReserveCache of 180 on a stock Mk2a?
#261057 - 21/07/2005 02:23 Re: PLEASE HELP [Re: SE_Sport_Driver]
SE_Sport_Driver
I'm going about removing my config.ini as per here.
I also noticed that Mark Lord mentinoed SegFault indicates some internal error here.
I'm trying to make a new config.ini file by Configuring the player in emplode, but emplode crashes on sync. On boot, I can browse the player (segfaults are not on every boot now) and skip through playlists, but the player WILL NOT PLAY .
In addition to the removal the config.ini, I did a "./player -i" but no luck. I'm still not able to get a song to play. It stays at 0:00.
Edited by SE_Sport_Driver (21/07/2005 02:28)
#261058 - 21/07/2005 03:06 Re: empeg up in smoke (again) [Re: SE_Sport_Driver]
SE_Sport_Driver
Well... I finally decided to revert to 2.00final and all is well again. I'm hoping that the install of 2.00 helped more than it being "not alpha10" because I'd really like to get 3a10 to work - or at least 2.01.
Sorry about the panic. I value my hard drives and their contents (years of tweaking playlists) more than I value my empeg. I don't know how long the empeg was smoking before I came back into the room or if anything on the drives got fried. Since swapping the drives to another player brought about new problems, I feared the the drives were fubared along with the fan controller.
Maybe the smoke clouded my judgement.
This is the only thing I noticed during the standard database rebuilds that go with switching to 3 to 2: Code:
hdc4 is mounted.
! local_audio_component.cpp:1831:Invalid bitrate tag for FID 0x643d0.
#261059 - 21/07/2005 08:42 Re: empeg up in smoke (again) [Re: SE_Sport_Driver]
Sorry, I replied in the other thread.
2.00 is unaware of extra memory, so you do not have to worry about the caching subsystem grabbing gobs of space and stuffing audio in it to the exclusion of all else. Now that you have stability at 2.00, you might want to move to 2.01. Memory caching will be an issue here, and you probably want your reservecache variable at a high number to lock out as much memory as needed to keep your player responding.
I would recommend deleting and rebuilding the databases, along with an fsck, just to be safe. The errors you mentioned are not dangerous, to my knowledge. It just looks like a bad tag and that your mount table doesn't have the second drive in it (this is normal unless you tweak it).
#261060 - 21/07/2005 09:46 Re: empeg up in smoke (again) [Re: pgrzelak]
SE_Sport_Driver
Okay, I guess I didn't understand how the 2.01 and 3.x handle extra memory.
#261061 - 21/07/2005 10:01 Re: empeg up in smoke (again) [Re: SE_Sport_Driver]
Basically, 2.01 and 3.0 are aware of the memory and try to use it. The issue (at least one that I know of and have hit before) is the aggressive caching of the player application. It is great for limited memory, filling the buffer with audio and keeping the drives spun down. The problem is that the cache tries to fill as much as it can. With large amounts of memory available, the caching routine can choke out other applications and cause them to fail due to memory resource starvation.
There are better descriptions in other threads, but it comes down to the fact that the bulk disk reads are done in kernel memory. Competing applications (player, telnet, other daemons) cannot allocate the RAM needed while these reads are done, so those applications give memory allocation failures.
The reservecache option forces the player software not to use the extra space for caching, keeping cache operations quick and small enough not to interfere with the kernel (and other software) operations. The practical result is that 2.01 can use the extra memory, but you have to force it not to use that memory for cache beyond a certain "breakpoint".
Note that the memory is still very useful for hijack and other purposes.
#261062 - 21/07/2005 10:42 Re: PLEASE HELP [Re: SE_Sport_Driver]
Most likely bad connections on the extra memory..
