#259017 - 26/06/2005 19:30 MKIIA wont sync
kendrick
Whenever i try to sync using rio emplode or either Jemplode it gets to checking disk media and stays there forever, after maybe an hour or two it will finish doing that and sync.
How can i fix this?
#259018 - 26/06/2005 19:48 Re: MKIIA wont sync [Re: kendrick]
mtempsch
The fsck (file system check) probably errors out for some reason (how big drives?) A manual stepthrough of the fsck procedure from the command line is called for...
General procedure, sheck/follow the links as well...
#259019 - 26/06/2005 23:34 Re: MKIIA wont sync [Re: mtempsch]
Potentially misleading initial FAQ link for a newbie. He doesn't need to rebuild his databases, he's getting "Checking Media" which is a different thing (although a messed up filesystem might cause database screwup, he still needs to fix the filesystem first).
The proper launching-point FAQ entry is here.
