READ THIS FIRST (This System was Water Cooled NEVER OverClocked and works Fine I switched to a PCIe/PCIX motherboard The ICH Chipset Fan was removed to make room for a WaterBlock, I couldn't find the one that came with the board so I replaced it Asus one, This System included the Motherboard, Remote and Breakout box with Post code display 7.1 sound and all the other bells you would exspect from a board that sell for nearly 300 on zipzoomfly.com
100.00 and I'll split the cost of shipping 50/50 with you. Boxed up is it nealy 9 pounds.
ATX (305mm x 244mm)
CPU Supports Intel Socket 478 CPU with Hyper-Threading Technology
Supports Intel Celeron/Pentium4 system bus at 400/533/800MHz
Supports Intel Prescott CPU
Chipset Intel 875P + ICH5R, supports Hyper-Threading Technology
Main Memory Four 184-pin DDR DIMMs up to 4GB
Supports Dual-Channel DDR266/333/400 ECC/non-ECC memory
and Performance Acceleration Technology (PAT)
Expansion Slots One 1.5V AGP slot for 4X/8X AGP
Five 32-Bit PCI slots (v2.2 compliant)
One CMR (Chaintech Multimedia Riser) for Chaintech Multimedia
Card (CMC 7.1)
Audio Subsystem On-board 7.1-Channel audio
24-bit resolution audio format support
Sampling rates up to 96KHz
Multi-channel AC-link supported alternatively
Supports S/PDIF Out
Video Subsystem Video 4X/8X AGP
UltraDMA IDE Ports Supports PIO Mode 4 up to 16.6 Mbps, Multi-Word DMA Mode 2
and Ultra DMA mode 5 up to 100MB/s with Bus Mastering
Bus-Mastering software drivers for all common multitasking
operating systems
Embedded USB Controller Three EHCI USB 2.0 Controllers support total 8 USB 2.0/1.1 Ports
Support USB 2.0 High-Speed Device @480 Mb/s Transfer Rates
Optional USB adapters for additional USB2.0/1.1 ports
On Board Super I/O Controller ITE 8712 LPC I/O with system monitors hardware
Two UARTs support serial ports and IR function (up to 115.2Kbps)
for HPSIR and ASKIR
One SPP/ECP/EPP parallel port
One floppy disk drive connector supports up to 2.88MB
Embedded system monitoring 8 external voltage inputs
2 temperatures sensing for CPU and system
3 Fan speed (CPU, system and Case) monitoring
Boot-Block Flash ROM Award system BIOS support PnP, APM, DMI, ACPI, & Multi-device booting features
Software Driver CD (Chipset Autodetect) (WinDVD 7.1CH included)
Value Pack 2002/2003
APOGEE Overclocking
Other Feature Back panel I/O connector
One PS/2 mini-DIN mouse and keyboard ports
Four USB Ports and two RJ45 connectors
Two 9-pin D-SUB male Serial ports
One 25-pin D-SUB female Parallel port
Audio Line-in, Line-out and Mic-in jacks
Dual LAN
IntelR PRO/1000CT Network Connection (Gigabit LAN)
On-board IntelR 82547EI Gigabit Ethernet Controller supports 2X Gigabit performance through Communication Streaming Architecture and enable ASF 2.0-based secure remote management
Fast Ethernet Controller
On-board Realtek RTL8101L supports 10/100Mb Fast Ethernet
On-board SATA RAID Controller
Build-in ICH5R supports 2 Serial ATA devices for the highest data
transfer rates (1.5Gbps burst) with RAID 0/1 solution
On-board VIA VT6306 IEEE1394 Host Controller
Serial bus data tansfer rates of 400Mbps
IEEE P1394a compliant and IEEE 1394 Std 1394-1995
Programmable ATA/ATAPI interface supporting PIO modes 0-4, DMA modes 0-2 and Ultra DMA modes 0-4
On board connector for external device
Three 3x1 pin fan connectors
2x1 pin fan connector with housing for Northbridge
Two 5x2 pin USB connectors for additional 2 USB2.0 ports, CIR and
6 in 1 Card Reader on CBOX3
6x1 pin Infrared connector
3x1 pin wake on LAN connector with housing
3x1 pin wake on Modem connector with housing
9x2 pin front panel connector
5x2 pin Segment display connector for 2-digits Debug LED on CBOX3
8x1 pin IEEE1394 connector with housing for IEEE1394 port on CBOX3
17x2 pin floppy connector
______________________________________
Do not meddle in the affairs of Network
Administrators, for they are subtle and quick to
anger.
Worlds Lamest Wb Site (mine)
http://home.comcast.net/~jlipchitz/
