#244850 - 29/12/2004 12:42 FM Modulator
I need to conect my Karma to the headunit in a VW Touran, there's no appropriate CD Changer to AUX/RCA cable, I assume that this means my only option is an FM modulator, but are they any good?
#244851 - 29/12/2004 13:16 Re: FM Modulator [Re: tahir]
cushman
Loc: Erie, CO
I have an Audiovox FM Modulator that I use with my Empeg. I get no interference, because it connects through the antenna jack on my stock HU of my car (I also cannot get a CD changer aux-in interface for my Subaru Outback). It sounds like the best radio station you have ever heard, basically. If you can live with that, then you'll be ok.
Here is a pic of my setup. I use a relay connected to the Empeg's amp sense line to turn on the FM mod, you'll have to hook up a hidden switch somewhere under the dash/glove compartment if you are using it with a portable.
Mark Cushman
#244852 - 29/12/2004 14:14 Re: FM Modulator [Re: cushman]
Thanks for that Mark, I'm looking at one by Veba which seems very similar to the Audiovox.
#244853 - 07/09/2005 13:54 Re: FM Modulator [Re: tahir]
jondle
Loc: San Diego, CA, USA
I've listened to a lot of brands of FM-Modulators, and they all pretty much sound satisfactory. The only thing I would suggest is get one that hooks into the antenna (as mentioned above) and not a wireless one. I have yet to hear a wireless one that is close to satisfactory. I would expect to pay around $40. You could find one cheaper, but you get what you pay for.
Mark IIa -- #30103119 -- 70 gig w/ ext3 fs-- Eutronix Light Kit -- Greenlight buttons
