#238673 - 23/10/2004 05:34 Empeg Become Garbled And Cannot Display Any Character But Have Power
elmyda
I had changed the IC (ICT 18CV8-25) recently bcoz it has blowed. The technician at my local shop successfully do it for me bcoz i have no skill to install that tiny IC on Empeg. But there was another problem. The display cannot working very well (garbled). It has power but cannot display any character. I attach the file here (AVI DivX file showing the problem)
All 3 fuses are in good condition. The display VFD in good shape too. Remote sensor & volume switch also work fine. Can the display cable cause this problem?
Or is there any other IC can cause the display cannot working perfectly? Where can i get the diagram of Empeg board? The technician cannot check it without the diagram. I really love my Empeg. Please help ASAP.
237915-empeg_video.avi (113 downloads)
#238674 - 23/10/2004 06:35 Re: Empeg Become Garbled And Cannot Display Any Character But Have Power [Re: elmyda]
An ICT 18CV8-25 is likely to be programmable logic - part number sounds like it. Did you get a preprogrammed one? If you didn't, it will never work.
BTW: Your AVI was probably too big to attach.
#238675 - 23/10/2004 07:18 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: elmyda]
RobotCaleb
i deleted your duplicate thread
#238676 - 23/10/2004 11:57 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: elmyda]
Sounds like a blown display fuse. There are three of them very near to where the display plugs into the mainboard. Check the FAQ for photos.
#238677 - 23/10/2004 12:16 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: Shonky]
maczrool
Loc: Louisiana, USA
We sent him the one he used. Yes, they are preprogrammed with Empeg code.
Stu
#238678 - 23/10/2004 12:20 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: mlord]
maczrool
Loc: Louisiana, USA
He says the fuses are good in his post. I've seen the video. Basically, it gives little blips of random nondescript images. He has now conceded that the display cable is in bad shape- definitely a likely culprit.
Stu
#238679 - 23/10/2004 13:55 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: maczrool]
FireFox31
Loc: East Coast, USA
Stu, maybe there is a need for replacement display cables similar to the IDE cables that you provide. Though maybe a little longer to avoid the sled... or maybe round and a lot longer to get completely out of the way.
FireFox31
#238680 - 23/10/2004 14:13 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: FireFox31]
The display cable is soldered directly to the display board. It's not even remotely as easy to change out as the IDE cable.
#238681 - 24/10/2004 02:04 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: wfaulk]
webroach
Loc: Colorado
Maybe this is something that could be made a modification? That is, replace the hardwired connection with a socket so the cable could be replaced in the future if necessary?
Or would that change cause problems with the display?
Dave
#238682 - 24/10/2004 02:06 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: webroach]
Nope. Mark Lord's apparently done it a few times, but replacing the cable or soldering a header on is equally difficult. More or less. Just makes it easy the next time.
#238683 - 24/10/2004 18:21 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: wfaulk]
webroach
Loc: Colorado
...Just makes it easy the next time.
Sorry, Bitt. Just reread my post and realised I was a bit unclear. Your point is exactly what I was talking about. Since it seems there won't be a replacement for the empeg for some time, anything that helps keep it easy to fix in the future is a Good Thing.
Dave
#238684 - 25/10/2004 07:10 Re: Empeg Become Garbled And Cannot Display Any Character But Have Pow [Re: maczrool]
elmyda
Stuart, can the display cable cause this problem? u have seen the video, what do u think? All 3 fuses in a good shape. Can i get the replacement display cable & IC from u? I will pay u include the delivery cost. By the way, i've seen another 2 IC on Empeg board. It is the same IC code on display board. All with same program? I will email the video files on request bcoz the file size more than 1mb.
