#23839 - 21/12/2000 15:26 Suggestions Please
mardibloke
Loc: Penarth, UK
Any suggestions for things to check - when I power on the empeg, it takes rather a while to "build music database", this happens everytime although eventually music will play. This started after a failed sync, and now when I connect to the empeg ( ethernet ) it starts to sync but eventually the animation on the empeg freezes
Rod, UK Mk2 64gig Red S/No.341
Rod, UK
#23840 - 21/12/2000 18:21 Re: Suggestions Please [Re: mardibloke]
This one is an easy fix.
Just do a synchronize (whether or not you are adding or changing anything) and if the synchronization is successful, your empeg will be back to its normal 8-second bootup time.
#23841 - 22/12/2000 05:44 Re: Suggestions Please [Re: tanstaafl.]
mardibloke
Loc: Penarth, UK
Thanks, within an hour of posting I managed to get a connection with emplode and get a good sync - sorted !
Rod, UK
