#233231 - 12/09/2004 16:04 Carbon ?'s
JayF
This player will be fine to jog with correct? Thats one reason I never bought a nitrus or karma.
Also where is the best place to pick one up??
#233232 - 12/09/2004 18:10 Re: Carbon ?'s [Re: JayF]
Greetings!
It still has a disk drive in it, so it really should be treated with some level of caution. I have not heard any reports of people having trouble with it, but it still has moving parts, similar to the Nitrus and (to a lesser extent) Karma.
As to where, well, I am not really sure at the moment. I think Best Buy was reported to have some.
Not to helpful I will admit...
#233233 - 13/09/2004 00:52 Re: Carbon ?'s [Re: pgrzelak]
I went to best buy today to check out the carbon and they had one on display but I didn't get to see the package. The display one was actually working and had music loaded on it.
As for jogging I don't think the carbon would be any better than the nitrus or karma. I would either get it at a store that you can get an extended warranty from or buy a flash player.
#233234 - 13/09/2004 05:15 Re: Carbon ?'s [Re: msaeger]
On a semi related note.... I wonder how many ipods I could get apple to warranty after killing the hdd by waving it around like a moron like portrayed in the ipod commercials
#233235 - 14/09/2004 00:23 Re: Carbon ?'s [Re: msaeger]
JayF
forgive the dumb question here but I thought the carbon had a 5gb flash/microdrive in it? What parts are moving inside?
Would a muvo 2 or a ipod mini be more suitable for jogging? I'd really rather have Rio product but if it won't hold up for jogging then I guess it'll have to be muvo 2 or ipod.
Will check my local Best Buy.
#233236 - 14/09/2004 00:29 Re: Carbon ?'s [Re: JayF]
robricc
Microdrives are little hard drives inside a CompactFlash TypeII form factor. They are obviously moving parts....
Edited by robricc (14/09/2004 00:30)
#233237 - 14/09/2004 01:35 Re: Carbon ?'s [Re: JayF]
JeffS
Loc: Atlanta, GA
doesn't the iPod mini also have a micro drive as well, just like the Carbon?
-Jeff
#233238 - 14/09/2004 01:41 Re: Carbon ?'s [Re: JeffS]
Yep
#233239 - 14/09/2004 04:40 Re: Carbon ?'s [Re: JeffS]
...and so do all the other 5GB players...
#233240 - 14/09/2004 12:45 Re: Carbon ?'s [Re: andy]
The Rio Forge is what you're looking for (if 1 GB is enough space).
#233241 - 14/09/2004 13:12 Re: Carbon ?'s [Re: JayF]
Ezekiel
Loc: NH USA
It would seem that (in theory) it should be possible to replace the Carbon's Microdrive CF card with a solid-state flash memory CF card. Unfortunately the 2GB & 4 GB flash cards are now about $280 and $570 respectively. While expensive, this would give you a high capacity flash based player. The Micro-Drives are significantly less expensive than comparable flash memory devices per GB, but have lower I/O speeds (not so important with an mp3 player) and are prone to mechanical failure in higher vibration environments.
-Zeke
WWFSMD?
#233242 - 14/09/2004 15:38 Re: Carbon ?'s [Re: JBjorgen]
mldarm
Loc: Texas
Does anybody know the specifics on the "up to 1GB" for storage of the Forge? Does it mean that if I get a 1GB SD card, the total memory recognized is going to be 1GB whether I have the 126MB, 256MB, or 512MB Forge? Is there a chance that a future firmware update could change the max amount of storage (say, if someday 2GB SD cards are available for a reasonable price)?
#233243 - 15/09/2004 07:27 Re: Carbon ?'s [Re: mldarm]
adavidw
Loc: Utah, USA
The total storage is aggregate. A 512 MB Forge with a 1GB cards gives you ~1.5GB. As card sizes increase, I'd expect them to continue working. There's probably some upper limit somewhere, but nothing hard and fast.
-Aaron
#233244 - 15/09/2004 08:57 Re: Carbon ?'s [Re: adavidw]
Kind of like the empeg... (Sorry, I just could not resist...)
