#229056 - 31/07/2004 12:22 JEmplode 57 Bugs
(on Windows XP, against v3a8, Hijack v409)
  • In the empeg discovery dialog, the mouse cursor is an hourglass, but you can still click on things.
  • In the animation editor, attempting to download the animated logo doesn't do anything: JEmplode freezes.
  • Similarly with attempting to upload a GIF animation: it freezes.
Hijack reports "kftpd: ksock_rw(response) failed, rc=0"
Tony's Logo Editor can successfully upload static logos using Hijack.
#229057 - 31/07/2004 14:12 Re: JEmplode 57 Bugs [Re: Roger]
Those last two have been around for a couple of versions, as I recall. Mike? What's up with that?
#229058 - 31/07/2004 14:43 Re: JEmplode 57 Bugs [Re: Roger]
mschrag
Loc: Richmond, VA
Interesting ... Not sure how this code ever worked. I guess if Hijack used to immediately return a 226 from an ftp download request it would have. Uploading jEmplode 58 now.
Incidentally the discovery thing is actually intentional, albeit a bizarre interface. I wanted to show that it was doing something, but still allow you to click the cancel button. Not sure what the correct UI approach for that should be. I guess windows uses that searching flashlight animation ..... I don't think I have that at my fingertips. Maybe a candy-cane progress bar or something.
#229059 - 02/08/2004 05:39 Re: JEmplode 57 Bugs [Re: mschrag]
You could also use the pointer-and-hourglass cursor, but the animated flashlight is probably the right answer.
#229060 - 02/08/2004 10:12 Re: JEmplode 57 Bugs [Re: Roger]
mschrag
Loc: Richmond, VA
I forgot about that cursor ... I'll have to see if Java has access to that one.
#229061 - 03/08/2004 12:36 Re: JEmplode 57 Bugs [Re: Roger]
tms13
Loc: Lochcarron and Edinburgh
Also in the discovery dialog, here's one that's been around for a handful of versions:
Specifying only a specific address doesn't work: JEmplode still finds my colleagues' players and makes me choose.
And while we're here, syncing with only changes to config.ini used to be very, very quick. Now it does a database rebuild and reboots the player as well. Not quick. I'd edit over FTP if I could get it to work neatly with Tramp.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#229062 - 03/08/2004 13:30 Re: JEmplode 57 Bugs [Re: tms13]
mschrag
Loc: Richmond, VA
Even when broadcast discovery is disabled? If you disable it, then restart does it do the same thing?
#229063 - 03/08/2004 13:51 Re: JEmplode 57 Bugs [Re: mschrag]
tms13
Yes, and yes. It's been annoying me for a while now (probably months; my music-buying has slowed in the last year or so). In the connection options dialog I have only "Specific Address" checked, and the appropriate field filled in.
Toby Speight
#229064 - 03/08/2004 14:06 Re: JEmplode 57 Bugs [Re: tms13]
mschrag
Loc: Richmond, VA
Yeah I can imagine that would be pretty damn annoying. I'll take a look at what's going on there.
#229065 - 03/08/2004 14:57 Re: JEmplode 57 Bugs [Re: mschrag]
tms13
Thanks, Mike.
Toby Speight
